VR5510 compensation network component values.
1,765件の閲覧回数
ajnas-c
When VPRE = 4.2V @ 455KHZ, how can we calculate the compensation network component values.
Please let me know what the RCOMP, CCOMP, and CHF values are
3 返答(返信)
1,760件の閲覧回数
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
We highly recommend using the values mentioned on the datasheet. Unfortunately they are tested and guaranteed using VPRE=3.3/5V.
Based on previous design guidelines, I would like to recommend the following values based on your requirements.
RCOMP=2.2KΩ
CCOMP=16nF
CHF=330pF
Please note that I do recommend to perform your own tests.
I hope this information helps.
David
1,753件の閲覧回数
ajnas-c
Hi David,
Good Day!
Is any formula available for this compensation network calculation?
Ajnas
1,750件の閲覧回数
diazmarin09
You may find the formula at the previous versions of the datasheet. As mentioned before, we highly recommend using the values predefined on the current datasheet.
David
