Unable to boot Linux on imx8m plus evk
sjp
Source: IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
we are referring the above guide to build Linux bsp.
The below is the default boot flow layout,
# The disk layout used is:
# |   | imx-boot | boot | rootfs |
# 0  |                8MiB    72MiB     72MiB + rootfs + IMAGE_EXTRA_SPACE (default 10MiB)
# ${IMX_BOOT_SEEK} 32 or 33kiB, see reference manual
imx-boot = SPL + ATF + TEE + U-BOOT --> boots to linux
Modified boot flow layout,
# |   |   Bios.bin  | boot | rootfs |
Bios.bin = SPL + ATF + TEE + U-BOOT + UEFI Loader --> boot upto before linux login terminal
Attached the original and modified debug logs.
any suggestions ?
pengyong_zhang
HI @sjp
I have talk about your request with our internal team, our Linux BSP do not support UEFI boot. Only PC have this. The embedded test CPU does not use BIOS.
B.R
pengyong_zhang
hi @sjp
I do not think you can use another bootloader replace the uboot for the Embedded CPU.
B.R
sjp
Hi @pengyong_zhang
Thanks for all your response !!!
JP
pengyong_zhang
HI @sjp
1. Can we use a non-UEFI bootloader, similar to U-boot, to boot Linux with Linux BSP ?
>>> What do you mean similar U-boot? Why are you not use U-boot?
2. What types of bootloaders are supported for booting Linux ?
>>>It is the default linux bootloader, SPL->ATF->UBOOT->KERNAL->ROOTFS
B.R
sjp
Hi @pengyong_zhang
We are just analyzing to replace u-boot with another bootloader.
JP
pengyong_zhang
hi @sjp
Have you seen my previous reply?  Linux BSP do not support UEFI boot. Only PC have this. The embedded test CPU does not use BIOS.
B.R
B.R
sjp
Hi @pengyong_zhang
Sorry i missed it. Thank you !!!
I have another query,
JP
pengyong_zhang
HI @sjp
B.R
sjp
Hi @pengyong_zhang,
Is there any update from your internal team ?
JP
pengyong_zhang
HI @sjp
However, in our modified boot flow, U-Boot hands control over to the UEFI loader instead. The UEFI loader then takes on the responsibility of loading the device tree and kernel into memory before launching the system.
>>> How did you "modified boot flow" you mentioned?  And why are you need to change the boot flow?
B.R
sjp
Hi @pengyong_zhang
1. How did you "modified boot flow" you mentioned?
Step 1:
We used the source code from WIN10_1.5.0_SOURCE  built it with the following command:
./buildme64.sh -b MX8M_PLUS_EVK -t uefi -bc DEBUG
The resulting binary we used is located at imx-windows-iot/BSP/firmware/MX8M_PLUS_EVK/firmware_uuu.bin.
Note: Additionally, we added a driver to this source. The purpose of this driver is to load the device tree and Kernel into memory.
Step 2:
      1. Host machine setup:
            i) Essential Yocto Project host packages are:
                 $ sudo apt install gawk wget git diffstat unzip texinfo gcc build-essential chrpath socat cpio python3 python3-pip python3-pexpect xz-utils debianutils iputils-ping python3-git python3-jinja2 python3-subunit zstd liblz4-tool file locales libacl1
            ii) Setting up the Repo utility:
                 $ mkdir ~/bin (this step may not be needed if the bin folder already exists)
                 $ curl https://storage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
                 $ chmod a+x ~/bin/repo
                 $ export PATH=~/bin:$PATH
      2. Yocto Project Setup:
            i) Git set up:
                $ git config --global user.name "Your Name"
                 $ git config --global user.email "Your Email"
                 $ git config --list
            ii) Repo sync:
                 $ mkdir imx-yocto-bsp $ cd imx-yocto-bsp
                 $ repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-scarthgap -m imx-6.6.36-2.1.0.xml
                 $ repo sync
           3. Changes:
                    Replaced the imx-boot with firmware_uuu.bin.
       4. Build:
            $ DISTRO=fsl-imx-wayland MACHINE=imx8mp-lpddr4-evk source imx-setup-release.sh -b <build dir>
            $ bitbake core-image-minimal
Built image will be avilable in  imx-yocto-bsp/Build/tmp/deploy/images/imx8mp-lpddr4-evk/core-image-minimal-imx8mp-lpddr4-evk.rootfs-20241106063508.wic.zst
# The disk layout of "wic" image
# | | firmware_uuu.bin |     boot     |    rootfs    |
Flash:
$ zstdcat /home/bpcg/imx-yocto-bsp/Build/tmp/deploy/images/imx8mp-lpddr4-evk/core-image-minimal-imx8mp-lpddr4-evk.rootfs-20241106063508.wic.zst | sudo dd of=/dev/sda bs=1M conv=fsync
Kernel arguments used: console=ttymxc1,921600 root=/dev/mmcblk1p2 rootwait rw
2. why are you need to change the boot flow?
We modified the boot flow because our objective is to boot Linux using EDK2 (UEFI).
JP
pengyong_zhang
hi @sjp
What is your change about the code? and how did you compile the falsh.bin file?
B.R
sjp
Hi @pengyong_zhang
Ques:
1. What is your change about the code?
We haven’t modified the existing code directly. In the default boot flow, U-Boot loads the device tree and kernel into memory and then launches the system.
2. how did you compile the flash.bin file?
The UEFI loader is built using the EDK2 framework.
We used the mkimage tool for binary stitching, similar to how firmware is stitched in a Windows BSP. We provided the UEFI loader as a FIT image to U-Boot.
JP
sjp
Hi @pengyong,
Any updates on this ?
%3CLINGO-SUB%20id%3D%22lingo-sub-1988560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUnable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1988560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESource%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3Ewe%20are%20referring%20the%20above%20guide%20to%20build%20Linux%20bsp.%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20below%20is%20the%20default%20boot%20flow%20layout%2C%3C%2FP%3E%3CP%3E%23%20The%20disk%20layout%20used%20is%3A%3CBR%20%2F%3E%23%20-%20----------%20--------------%20--------------%3CBR%20%2F%3E%23%20%7C%26nbsp%3B%20%26nbsp%3B%7C%20imx-boot%20%7C%20boot%20%7C%20rootfs%20%7C%3CBR%20%2F%3E%23%20-%20----------%20--------------%20--------------%3CBR%20%2F%3E%23%20%5E%20%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%5E%3CBR%20%2F%3E%23%20%7C%26nbsp%3B%20%26nbsp%3B%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7C%3CBR%20%2F%3E%23%200%26nbsp%3B%20%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%208MiB%26nbsp%3B%20%26nbsp%3B%2072MiB%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B72MiB%20%2B%20rootfs%20%2B%20IMAGE_EXTRA_SPACE%20(default%2010MiB)%3CBR%20%2F%3E%23%20%24%7BIMX_BOOT_SEEK%7D%2032%20or%2033kiB%2C%20see%20reference%20manual%3C%2FP%3E%3CP%3Eimx-boot%20%3D%20SPL%20%2B%20ATF%20%2B%20TEE%20%2B%20U-BOOT%20--%26gt%3B%20boots%20to%20linux%3C%2FP%3E%3CP%3EModified%20boot%20flow%20layout%2C%3C%2FP%3E%3CP%3E%23%20The%20disk%20layout%20used%20is%3A%3CBR%20%2F%3E%23%20-%20----------%20--------------%20--------------%3CBR%20%2F%3E%23%20%7C%26nbsp%3B%20%26nbsp%3B%7C%26nbsp%3B%20%26nbsp%3BBios.bin%26nbsp%3B%20%7C%20boot%20%7C%20rootfs%20%7C%3CBR%20%2F%3E%23%20-%20----------%20--------------%20--------------%3CBR%20%2F%3E%23%20%5E%20%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%5E%3CBR%20%2F%3E%23%20%7C%26nbsp%3B%20%26nbsp%3B%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7C%3CBR%20%2F%3E%23%200%26nbsp%3B%20%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%208MiB%26nbsp%3B%20%26nbsp%3B%2072MiB%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B72MiB%20%2B%20rootfs%20%2B%20IMAGE_EXTRA_SPACE%20(default%2010MiB)%3CBR%20%2F%3E%23%20%24%7BIMX_BOOT_SEEK%7D%2032%20or%2033kiB%2C%20see%20reference%20manual%3C%2FP%3E%3CP%3EBios.bin%20%3D%20SPL%20%2B%20ATF%20%2B%20TEE%20%2B%20U-BOOT%20%2B%20UEFI%20Loader%20--%26gt%3B%20boot%20upto%20before%20linux%20login%20terminal%3C%2FP%3E%3CP%3EAttached%20the%20original%20and%20modified%20debug%20logs.%3C%2FP%3E%3CP%3Eany%20suggestions%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1997032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%20for%20all%20your%20response%20!!!%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3CBR%20%2F%3EJP%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1996977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1996977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230963%22%20target%3D%22_blank%22%3E%40sjp%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20do%20not%20think%20you%20can%20use%20another%20bootloader%20replace%20the%20uboot%20for%20the%20Embedded%20CPU.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1996963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1996963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhat%20do%20you%20mean%20similar%20U-boot%3F%20Why%20are%20you%20not%20use%20U-boot%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EWe%20are%20just%20analyzing%20to%20replace%20u-boot%20with%20another%20bootloader.%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EJP%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1996692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1996692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230963%22%20target%3D%22_blank%22%3E%40sjp%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E1.%20Can%20we%20use%20a%20non-UEFI%20bootloader%2C%20similar%20to%20U-boot%2C%20to%20boot%20Linux%20with%20Linux%20BSP%20%3F%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26gt%3B%26gt%3B%26gt%3B%20What%20do%20you%20mean%20similar%20U-boot%3F%20Why%20are%20you%20not%20use%20U-boot%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E2.%20What%20types%20of%20bootloaders%20are%20supported%20for%20booting%20Linux%20%3F%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26gt%3B%26gt%3B%26gt%3BIt%20is%20the%20default%20linux%20bootloader%2C%20SPL-%26gt%3BATF-%26gt%3BUBOOT-%26gt%3BKERNAL-%26gt%3BROOTFS%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1995467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1995467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3ESorry%20i%20missed%20it.%20Thank%20you%20!!!%3CBR%20%2F%3E%3CBR%20%2F%3EI%20have%20another%20query%2C%3CBR%20%2F%3E%3CBR%20%2F%3E1.%20Can%20we%20use%20a%20non-UEFI%20bootloader%2C%20similar%20to%20U-boot%2C%20to%20boot%20Linux%20with%20Linux%20BSP%20%3F%3CBR%20%2F%3E%3CBR%20%2F%3E2.%20What%20types%20of%20bootloaders%20are%20supported%20for%20booting%20Linux%20%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3CBR%20%2F%3EJP%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1995194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1995194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230963%22%20target%3D%22_blank%22%3E%40sjp%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHave%20you%20seen%20my%20previous%20reply%3F%26nbsp%3B%26nbsp%3B%3CSPAN%3ELinux%20BSP%20do%20not%20support%20UEFI%20boot.%20Only%20PC%20have%20this.%20The%20embedded%20test%20CPU%20does%20not%20use%20BIOS.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1994634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1994634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%2C%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20there%20any%20update%20from%20your%20internal%20team%20%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3CBR%20%2F%3EJP%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230963%22%20target%3D%22_blank%22%3E%40sjp%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20have%20talk%20about%20your%20request%20with%20our%20internal%20team%2C%20our%20Linux%20BSP%20do%20not%20support%20UEFI%20boot.%20Only%20PC%20have%20this.%20The%20embedded%20test%20CPU%20does%20not%20use%20BIOS.%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%20How%20did%20you%20%22modified%20boot%20flow%22%20you%20mentioned%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3EStep%201%3A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3EWe%20used%20the%20source%20code%20from%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DWIN10_1.5.0_SOURCE%26amp%3BappType%3Dlicense%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EWIN10_1.5.0_SOURCE%3C%2FA%3E%26nbsp%3B%20built%20it%20with%20the%20following%20command%3A%3C%2FP%3E%3CP%3E%3CSTRONG%3E.%2Fbuildme64.sh%20-b%20MX8M_PLUS_EVK%20-t%20uefi%20-bc%20DEBUG%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EThe%20resulting%20binary%20we%20used%20is%20located%20at%26nbsp%3B%3CSTRONG%3Eimx-windows-iot%2FBSP%2Ffirmware%2FMX8M_PLUS_EVK%2Ffirmware_uuu.bin.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ENote%3A%3C%2FSTRONG%3E%20Additionally%2C%20we%20added%20a%20driver%20to%20this%20source.%20The%20purpose%20of%20this%20driver%20is%20to%20load%20the%20device%20tree%20and%20Kernel%20into%20memory.%3C%2FP%3E%3CP%3E%3CU%3E%3CSTRONG%3EStep%202%3A%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FP%3E%3CP%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%3CSTRONG%3E%E2%80%821.%26nbsp%3BHost%20machine%20setup%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%3CSTRONG%3E%E2%80%82i)%20Essential%20Yocto%20Project%20host%20packages%20are%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20sudo%20apt%20install%20gawk%20wget%20git%20diffstat%20unzip%20texinfo%20gcc%20build-essential%20chrpath%20socat%20cpio%20python3%20python3-pip%20python3-pexpect%20xz-utils%20debianutils%20iputils-ping%20python3-git%20python3-jinja2%20python3-subunit%20zstd%20liblz4-tool%20file%20locales%20libacl1%3C%2FP%3E%3CP%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%3CSTRONG%3Eii)%20Setting%20up%20the%20Repo%20utility%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20mkdir%20~%2Fbin%20(this%20step%20may%20not%20be%20needed%20if%20the%20bin%20folder%20already%20exists)%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20curl%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fstorage.googleapis.com%2Fgit-repo-downloads%2Frepo%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fstorage.googleapis.com%2Fgit-repo-downloads%2Frepo%3C%2FA%3E%26nbsp%3B%26gt%3B%20~%2Fbin%2Frepo%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20chmod%20a%2Bx%20~%2Fbin%2Frepo%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20export%20PATH%3D~%2Fbin%3A%24PATH%3CBR%20%2F%3E%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%3CSTRONG%3E2.%20Yocto%20Project%20Setup%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%3CSTRONG%3Ei)%20Git%20set%20up%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20git%20config%20--global%20user.name%20%22Your%20Name%22%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20git%20config%20--global%20user.email%20%22Your%20Email%22%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20git%20config%20--list%3CBR%20%2F%3E%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%3CSTRONG%3Eii)%20Repo%20sync%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20mkdir%20imx-yocto-bsp%20%24%20cd%20imx-yocto-bsp%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20repo%20init%20-u%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%3C%2FA%3E%26nbsp%3B-b%20imx-linux-scarthgap%20-m%20imx-6.6.36-2.1.0.xml%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20repo%20sync%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3CSTRONG%3E3.%20Changes%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Replaced%20the%26nbsp%3Bimx-boot%26nbsp%3Bwith%26nbsp%3Bfirmware_uuu.bin.%3CBR%20%2F%3E%26nbsp%3B%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%20%3CSTRONG%3E4.%20Build%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20DISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8mp-lpddr4-evk%20source%20imx-setup-release.sh%20-b%20%3CBUILD%20dir%3D%22%22%3E%3CBR%20%2F%3E%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%E2%80%82%24%20bitbake%20core-image-minimal%3C%2FBUILD%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3ERefer%3A%3CSPAN%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EIMX_YOCTO_PROJECT_USERS_GUIDE.pdf%3C%2FA%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EBuilt%20image%20will%20be%20avilable%20in%26nbsp%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Eimx-yocto-bsp%2FBuild%2Ftmp%2Fdeploy%2Fimages%2Fimx8mp-lpddr4-evk%2Fcore-image-minimal-imx8mp-lpddr4-evk.rootfs-20241106063508.wic.zst%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%23%20The%20disk%20layout%20of%20%22wic%22%20image%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%23%20%26nbsp%3B-%20----------%20--------------%20--------------%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%23%20%7C%20%7C%20%3CSPAN%3Efirmware_uuu.bin%3C%2FSPAN%3E%20%7C%20%26nbsp%3B%20%26nbsp%3B%20boot%20%26nbsp%3B%20%26nbsp%3B%20%7C%20%26nbsp%3B%20%26nbsp%3Brootfs%20%26nbsp%3B%20%26nbsp%3B%7C%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%23%20%26nbsp%3B-%20----------%20--------------%20--------------%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%23%20%5E%20%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5E%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%23%20%7C%20%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%7C%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%23%200%20%7C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B8MiB%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B72MiB%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B72MiB%20%2B%20rootfs%20%2B%20IMAGE_EXTRA_SPACE%20(default%2010MiB)%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%23%20%26nbsp%3B%20%24%7BIMX_BOOT_SEEK%7D%2032%20or%2033kiB%2C%20see%20reference%20manual%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CU%3EFlash%3A%3C%2FU%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CU%3E%26nbsp%3B%3C%2FU%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3E%24%20zstdcat%20%2Fhome%2Fbpcg%2Fimx-yocto-bsp%2FBuild%2Ftmp%2Fdeploy%2Fimages%2Fimx8mp-lpddr4-evk%2Fcore-image-minimal-imx8mp-lpddr4-evk.rootfs-20241106063508.wic.zst%20%7C%20sudo%20dd%20of%3D%2Fdev%2Fsda%20bs%3D1M%20conv%3Dfsync%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSTRONG%3EKernel%20arguments%20used%3A%26nbsp%3B%3C%2FSTRONG%3Econsole%3Dttymxc1%2C921600%20root%3D%2Fdev%2Fmmcblk1p2%20rootwait%20rw%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSTRONG%3E2.%20why%20are%20you%20need%20to%20change%20the%26nbsp%3Bboot%20flow%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EWe%20modified%20the%20boot%20flow%20because%20our%20objective%20is%20to%20boot%20Linux%20using%20EDK2%20(UEFI).%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EJP%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230963%22%20target%3D%22_blank%22%3E%40sjp%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHowever%2C%20in%20our%20modified%20boot%20flow%2C%20U-Boot%20hands%20control%20over%20to%20the%20UEFI%20loader%20instead.%20The%20UEFI%20loader%20then%20takes%20on%20the%20responsibility%20of%20loading%20the%20device%20tree%20and%20kernel%20into%20memory%20before%20launching%20the%20system.%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%26gt%3B%26gt%3B%26gt%3B%20How%20did%20you%20%22modified%20boot%20flow%22%20you%20mentioned%3F%26nbsp%3B%20And%20why%20are%20you%20need%20to%20change%20the%26nbsp%3Bboot%20flow%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%40pengyong%2C%3CBR%20%2F%3E%3CBR%20%2F%3EAny%20updates%20on%20this%20%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EQues%3A%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%20What%20is%20your%20change%20about%20the%20code%3F%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EWe%20haven%E2%80%99t%20modified%20the%20existing%20code%20directly.%20In%20the%20default%20boot%20flow%2C%20U-Boot%20loads%20the%20device%20tree%20and%20kernel%20into%20memory%20and%20then%20launches%20the%20system.%3C%2FP%3E%3CP%3EHowever%2C%20in%20our%20modified%20boot%20flow%2C%20U-Boot%20hands%20control%20over%20to%20the%20UEFI%20loader%20instead.%20The%20UEFI%20loader%20then%20takes%20on%20the%20responsibility%20of%20loading%20the%20device%20tree%20and%20kernel%20into%20memory%20before%20launching%20the%20system.%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%20how%20did%20you%20compile%20the%20flash.bin%20file%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EThe%20UEFI%20loader%20is%20built%20using%20the%20EDK2%20framework.%3C%2FP%3E%3CP%3EWe%20used%20the%20%3CSTRONG%3Emkimage%3C%2FSTRONG%3E%20tool%20for%20binary%20stitching%2C%20similar%20to%20how%20firmware%20is%20stitched%20in%20a%20Windows%20BSP.%20We%20provided%20the%20UEFI%20loader%20as%20a%20FIT%20image%20to%20U-Boot.%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EJP%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Unable%20to%20boot%20Linux%20on%20imx8m%20plus%20evk%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230963%22%20target%3D%22_blank%22%3E%40sjp%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EWhat%20is%20your%20change%20about%20the%20code%3F%20and%20how%20did%20you%20compile%20the%20falsh.bin%20file%3F%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E
