[URGENT] SD8997 WiFi Module — 5GHz STA Throughput Frequently Drops to 0 Mbps During iperf3 Testing
8,090 次查看
yangyaoguang
Dear NXP Support Team,
I hope this message finds you well.
We are currently evaluating the performance of the NXP SD8997 WiFi module (SDIO interface) on an i.MX6ULL-based platform running Linux 5.4.24, using the official moal/mlan driver stack. The firmware in use is sdiouart8997_combo_v4.bin, version 16.92.21.p84.4 (FP92), along with the associated tx_power_test.bin power table. Firmware loads correctly, and the driver reports successful initialization without errors.
However, we are encountering a critical and reproducible issue: when operating in 5GHz STA mode, the WiFi throughput frequently drops to 0 Mbps during iperf3 testing, even in stable open-air environments. This issue significantly impacts our validation process and raises concerns about the module’s reliability in real-world deployments.
In our test setup, the SD8997 module connects as a station to a 5GHz AP (HT40, channel 161). We initiate standard iperf3 throughput tests (e.g., iperf3 -c <AP IP> -t 20 -i 1 -P 10), during which multiple threads consistently show zero throughput, despite minimal retransmissions. Disabling power save features (ps_mode=0, auto_ds=0) does not alleviate the issue. Firmware initialization and WLAN association complete successfully, and the interface transitions into the CONNECTED state normally. The problem begins only after traffic starts flowing.
This issue is currently blocking our development progress, as 5GHz STA stability is a critical requirement in our target application.
We kindly seek your urgent support on the following:
  1. Is this a known issue with firmware version 16.92.21.p84.4 (FP92)?
  2. What is the recommended firmware and driver pairing for Linux 5.4 platforms using the moal stack?
  3. Are there known firmware-level limitations in STA mode that may cause Tx path stall or data flow blockage?
  4. Is there any debug firmware, patch, or recommended workaround available to help isolate or resolve the issue?
We are happy to provide additional test data, full dmesg logs, configuration files, or conduct further diagnostic testing as needed.
Thank you very much for your time and support. We sincerely appreciate your assistance in helping us move forward.
Yangguang
32 回复数
1,806 次查看
Christine_Li
Hi, @yangyaoguang
1.Can you please share the dts file to me?
To save your project info, you can sent it to my email:[email protected].
2.To enable the ADMA, you need add below line in dts:
dma-coherent;
3.To check whether ADMA has been enabled, you can check the dmesg(from device boot-up), dmesg | grep usdhc
mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
Christine.
1,801 次查看
yangyaoguang
Hi Christine,
Please find below the DTS configuration for usdhc1 on our platform:
usdhc1: usdhc@2190000 {
        compatible = "fsl,imx6ul-usdhc", "fsl,imx6sx-usdhc";
        reg = <0x02190000 0x4000>;
        interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>;
        clocks = <&clks IMX6UL_CLK_USDHC1>,
                 <&clks IMX6UL_CLK_USDHC1>;
        clock-names = "ipg", "ahb", "per";
        fsl,tuning-step = <2>;
        fsl,tuning-start-tap = <20>;
        bus-width = <4>;
        status = "disabled";
&usdhc1 {
        compatible = "fsl,imx6ull-usdhc", "fsl,imx6sx-usdhc";
        assigned-clocks = <&clks IMX6UL_CLK_USDHC1_SEL>, <&clks IMX6UL_CLK_USDHC1>;
        assigned-clock-parents = <&clks IMX6UL_CLK_PLL2_PFD2>;
        assigned-clock-rates = <0>, <132000000>;
fragment@1 {
        target = <&usdhc1>;
        __overlay__ {
                pinctrl-names = "default", "state_100mhz", "state_200mhz";
                pinctrl-0 = <&pinctrl_usdhc1>;
                pinctrl-1 = <&pinctrl_usdhc1_100mhz>;
                pinctrl-2 = <&pinctrl_usdhc1_200mhz>;
                non-removable;
                keep-power-in-suspend;
                wakeup-source;
                fsl,sdio-interrupt-enabled;
                status = "okay";
Please confirm if this matches the requirements for enabling ADMA on USDHC1.
Yangyaoguang
标记 (1)
1,800 次查看
yangyaoguang
We have checked the logs, and ADMA is already enabled on our platform.
Here is the dmesg output:
root@Voice-Gateway:~# dmesg | grep ADMA
[    5.808617] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    5.873090] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
标记 (1)
1,788 次查看
Christine_Li
Hi, @yangyaoguang
Thanks for your info.
Yes, from your logs, I think ADMA already enabled on your board.
And I will escalated this issue to our internal team to ask help.
Christine.
1,749 次查看
Christine_Li
Hi, @yangyaoguang
Please help to provide below info:
  1.  Please help provide complete DTS file.
  2. Use latest available release and help get the sniffer traces if issue is observed.
  3. Also please help get the in-sync dmesg log. Do not use any drvdbg.
  4. What is the ext. AP used? Can we get the ext. AP model/FW version details?
  5. Is issue observed on Channel-161 only? Can you check the issue scenario on other channels (36 or 40, etc) ?
Christine.
1,715 次查看
yangyaoguang
Hi Christine,
Thanks for your support.
After internal discussion and evaluation, we decided to adopt the following measures to address the issue:
  • Updated to the latest available Wi-Fi driver, and
  • Reduced the SDIO bus speed to 50MHz.
With these changes in place, the issue is no longer observed in our environment.
Currently, no further testing is planned beyond this scope.
YangYaoguang
标记 (1)
1,709 次查看
Christine_Li
Hi, @yangyaoguang
Thanks for letting me know your plan.
So, Can we close this ticket for now?
And please do not hesitate to create new case to us if you need our help.
Christine.
1,698 次查看
yangyaoguang
Hi Christine,
Yes, we can close this ticket as the issue has been resolved.
Noted, and thank you for the support.
YangYaoguang
标记 (1)
1,744 次查看
Christine_Li
Hi, @yangyaoguang
Any updates on our requested info?
Christine.
1,723 次查看
Christine_Li
Hi, @yangyaoguang
Please help to provide the requested info, so that we can help to resolve this issue ASAP.
Thanks.
Christine.
2,398 次查看
Christine_Li
Hi, @yangyaoguang
Any updates on this case?
If you did any experiment or test related to this thread, please share me your information. So that we can keep moving forward on this thread.
Thanks.
Christine.
2,481 次查看
yangyaoguang
Hi Christine,
No, we were only using the Wi-Fi interface of the SD8997 during the performance test. Bluetooth was not enabled.
Yaoguang
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2142614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5B%E7%B4%A7%E6%80%A5%5D%20SD8997%20WiFi%20%E6%A8%A1%E5%9D%97%20-%20iperf3%20%E6%B5%8B%E8%AF%95%E6%9C%9F%E9%97%B4%205GHz%20STA%20%E5%90%9E%E5%90%90%E9%87%8F%E7%BB%8F%E5%B8%B8%E9%99%8D%E8%87%B3%200%20Mbps%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E5%9B%A2%E9%98%9F%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E6%9D%A1%E4%BF%A1%E6%81%AF%E8%83%BD%E6%89%BE%E5%88%B0%E6%82%A8%EF%BC%8C%E7%A5%9D%E6%82%A8%E4%B8%80%E5%88%87%E5%AE%89%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%9F%BA%E4%BA%8E%20i.MX6ULL%20%E7%9A%84%E5%B9%B3%E5%8F%B0%E4%B8%8A%E8%AF%84%E4%BC%B0%E6%81%A9%E6%99%BA%E6%B5%A6%20SD8997%20WiFi%20%E6%A8%A1%E5%9D%97%EF%BC%88SDIO%20%E6%8E%A5%E5%8F%A3%EF%BC%89%E7%9A%84%E6%80%A7%E8%83%BD%EF%BC%8C%E8%AF%A5%E5%B9%B3%E5%8F%B0%E4%BD%BF%E7%94%A8%E5%AE%98%E6%96%B9%20moal%2Fmlan%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%A0%88%E8%BF%90%E8%A1%8C%20Linux%205.4.24%E3%80%82%E4%BD%BF%E7%94%A8%E7%9A%84%E5%9B%BA%E4%BB%B6%E6%98%AF%20sdiouart8997_combo_v4.bin%E3%80%81%E7%89%88%E6%9C%AC%2016.92.21.p84.4%20(FP92)%EF%BC%8C%E4%BB%A5%E5%8F%8A%E7%9B%B8%E5%85%B3%E7%9A%84%20tx_power_test.bin%20%E5%8A%9F%E7%8E%87%E8%A1%A8%E3%80%82%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E6%AD%A3%E7%A1%AE%EF%BC%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8A%A5%E5%91%8A%E5%88%9D%E5%A7%8B%E5%8C%96%E6%88%90%E5%8A%9F%EF%BC%8C%E6%97%A0%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E4%BB%AC%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%85%B3%E9%94%AE%E4%B8%94%E5%8F%AF%E9%87%8D%E5%A4%8D%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%E5%9C%A8%205GHz%20STA%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8CWiFi%20%E5%90%9E%E5%90%90%E9%87%8F%E5%9C%A8%20iperf3%20%E6%B5%8B%E8%AF%95%E4%B8%AD%E7%BB%8F%E5%B8%B8%E9%99%8D%E8%87%B3%3CSTRONG%3E0%20Mbps%3C%2FSTRONG%3E%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%9C%A8%E7%A8%B3%E5%AE%9A%E7%9A%84%E9%9C%B2%E5%A4%A9%E7%8E%AF%E5%A2%83%E4%B8%AD%E4%B9%9F%E6%98%AF%E5%A6%82%E6%AD%A4%E3%80%82%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%A5%E9%87%8D%E5%BD%B1%E5%93%8D%E4%BA%86%E6%88%91%E4%BB%AC%E7%9A%84%E9%AA%8C%E8%AF%81%E8%BF%87%E7%A8%8B%EF%BC%8C%E5%B9%B6%E5%BC%95%E5%8F%91%E4%BA%86%E5%AF%B9%E6%A8%A1%E5%9D%97%E5%9C%A8%E5%AE%9E%E9%99%85%E9%83%A8%E7%BD%B2%E4%B8%AD%E5%8F%AF%E9%9D%A0%E6%80%A7%E7%9A%84%E6%8B%85%E5%BF%A7%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E6%B5%8B%E8%AF%95%E8%AE%BE%E7%BD%AE%E4%B8%AD%EF%BC%8CSD8997%20%E6%A8%A1%E5%9D%97%E4%BD%9C%E4%B8%BA%E4%B8%80%E4%B8%AA%E7%AB%99%E7%82%B9%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%80%E4%B8%AA%205GHz%20%E6%8E%A5%E5%85%A5%E7%82%B9%EF%BC%88HT40%EF%BC%8C%E4%BF%A1%E9%81%93%20161%EF%BC%89%E3%80%82%E6%88%91%E4%BB%AC%E5%90%AF%E5%8A%A8%E4%BA%86%E6%A0%87%E5%87%86%E7%9A%84%20iperf3%20%E5%90%9E%E5%90%90%E9%87%8F%E6%B5%8B%E8%AF%95%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8Ciperf3%20-c%3CAP%20ip%3D%22%22%3E%20-t%2020%20-i%201%20-P%2010%EF%BC%89%EF%BC%8C%E5%9C%A8%E6%AD%A4%E6%9C%9F%E9%97%B4%EF%BC%8C%E5%B0%BD%E7%AE%A1%E9%87%8D%E4%BC%A0%E6%AC%A1%E6%95%B0%E6%9E%81%E5%B0%91%EF%BC%8C%E4%BD%86%E5%A4%9A%E4%B8%AA%E7%BA%BF%E7%A8%8B%E5%A7%8B%E7%BB%88%E6%98%BE%E7%A4%BA%E5%90%9E%E5%90%90%E9%87%8F%E4%B8%BA%E9%9B%B6%E3%80%82%E7%A6%81%E7%94%A8%E7%9C%81%E7%94%B5%E5%8A%9F%E8%83%BD%EF%BC%88ps_mode%3D0%E3%80%81auto_ds%3D0%EF%BC%89%E5%B9%B6%E4%B8%8D%E8%83%BD%E7%BC%93%E8%A7%A3%E9%97%AE%E9%A2%98%E3%80%82%E5%9B%BA%E4%BB%B6%E5%88%9D%E5%A7%8B%E5%8C%96%E5%92%8C%20WLAN%20%E5%85%B3%E8%81%94%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%EF%BC%8C%E6%8E%A5%E5%8F%A3%E6%AD%A3%E5%B8%B8%E8%BD%AC%E5%85%A5%20CONNECTED%EF%BC%88%E8%BF%9E%E6%8E%A5%EF%BC%89%E7%8A%B6%E6%80%81%E3%80%82%E5%8F%AA%E6%9C%89%E5%9C%A8%E8%BD%A6%E6%B5%81%E5%BC%80%E5%A7%8B%E6%B5%81%E5%8A%A8%E4%B9%8B%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E6%89%8D%E5%BC%80%E5%A7%8B%E5%87%BA%E7%8E%B0%E3%80%82%3C%2FAP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9B%AE%E5%89%8D%3CSTRONG%3E%E9%98%BB%E7%A2%8D%E4%BA%86%E6%88%91%E4%BB%AC%E7%9A%84%E5%BC%80%E5%8F%91%E8%BF%9B%E5%BA%A6%3C%2FSTRONG%3E%EF%BC%8C%E5%9B%A0%E4%B8%BA%205GHz%20STA%20%E7%9A%84%E7%A8%B3%E5%AE%9A%E6%80%A7%E6%98%AF%E6%88%91%E4%BB%AC%E7%9B%AE%E6%A0%87%E5%BA%94%E7%94%A8%E7%9A%84%E5%85%B3%E9%94%AE%E8%A6%81%E6%B1%82%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%81%B3%E8%AF%B7%E6%82%A8%E5%9C%A8%E4%BB%A5%E4%B8%8B%E6%96%B9%E9%9D%A2%E6%8F%90%E4%BE%9B%E7%B4%A7%E6%80%A5%E6%94%AF%E6%8C%81%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%2016.92.21.p84.4%20(FP92)%20%E7%9A%84%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E4%BD%BF%E7%94%A8%20moal%20%E5%8D%8F%E8%AE%AE%E6%A0%88%E7%9A%84%20Linux%205.4%20%E5%B9%B3%E5%8F%B0%EF%BC%8C%E6%8E%A8%E8%8D%90%E7%9A%84%E5%9B%BA%E4%BB%B6%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%85%8D%E5%AF%B9%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%20STA%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%8C%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E5%B7%B2%E7%9F%A5%E7%9A%84%E5%9B%BA%E4%BB%B6%E7%BA%A7%E9%99%90%E5%88%B6%EF%BC%8C%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%20Tx%20%E8%B7%AF%E5%BE%84%E5%81%9C%E6%BB%9E%E6%88%96%E6%95%B0%E6%8D%AE%E6%B5%81%E9%98%BB%E5%A1%9E%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E8%B0%83%E8%AF%95%E5%9B%BA%E4%BB%B6%E3%80%81%E8%A1%A5%E4%B8%81%E6%88%96%E5%BB%BA%E8%AE%AE%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%9D%A5%E5%B8%AE%E5%8A%A9%E9%9A%94%E7%A6%BB%E6%88%96%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%BE%88%E4%B9%90%E6%84%8F%E6%8F%90%E4%BE%9B%E9%A2%9D%E5%A4%96%E7%9A%84%E6%B5%8B%E8%AF%95%E6%95%B0%E6%8D%AE%E3%80%81%E5%AE%8C%E6%95%B4%E7%9A%84%20dmesg%20%E6%97%A5%E5%BF%97%E3%80%81%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%96%E6%A0%B9%E6%8D%AE%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%9A%84%E8%AF%8A%E6%96%AD%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E6%97%B6%E9%97%B4%E5%92%8C%E6%94%AF%E6%8C%81%E3%80%82%E6%88%91%E4%BB%AC%E8%A1%B7%E5%BF%83%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%8D%8F%E5%8A%A9%EF%BC%8C%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E5%90%91%E5%89%8D%E8%BF%88%E8%BF%9B%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E9%98%B3%E5%85%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%85%B3%E9%97%AD%E6%AD%A4%E7%A5%A8%E6%8D%AE%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%E5%88%B0%E4%BA%86%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EYangYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168468%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168468%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%20%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E5%91%8A%E8%AF%89%E6%88%91%E4%BD%A0%E7%9A%84%E8%AE%A1%E5%88%92%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E6%9A%82%E6%97%B6%E5%85%B3%E9%97%AD%E6%AD%A4%E7%A5%A8%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%88%91%E4%BB%AC%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E5%90%91%E6%88%91%E4%BB%AC%E6%8F%90%E4%BA%A4%E6%96%B0%E7%9A%84%E6%A1%88%E4%BE%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%3CP%3E%E7%BB%8F%E8%BF%87%E5%86%85%E9%83%A8%E8%AE%A8%E8%AE%BA%E5%92%8C%E8%AF%84%E4%BC%B0%EF%BC%8C%E6%88%91%E4%BB%AC%E5%86%B3%E5%AE%9A%E9%87%87%E5%8F%96%E4%BB%A5%E4%B8%8B%E6%8E%AA%E6%96%BD%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%9B%B4%E6%96%B0%E4%B8%BA%E6%9C%80%E6%96%B0%E7%9A%84%20Wi-Fi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%EF%BC%8C%E4%BB%A5%E5%8F%8A%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%B0%86%20%3CSTRONG%3ESDIO%20%E6%80%BB%E7%BA%BF%E9%80%9F%E5%BA%A6%E9%99%8D%E4%BD%8E%E5%88%B0%2050%3C%2FSTRONG%3E%20MHz%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%9C%89%E4%BA%86%E8%BF%99%E4%BA%9B%E5%8F%98%E5%8C%96%EF%BC%8C%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E7%8E%AF%E5%A2%83%E4%B8%AD%E5%B0%B1%E5%86%8D%E4%B9%9F%E8%A7%82%E5%AF%9F%E4%B8%8D%E5%88%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%3CSTRONG%3E%E6%B2%A1%E6%9C%89%E8%AE%A1%E5%88%92%3C%2FSTRONG%3E%E5%9C%A8%E6%AD%A4%E8%8C%83%E5%9B%B4%E4%B9%8B%E5%A4%96%E8%BF%9B%E8%A1%8C%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%9A%84%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EYangYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E8%A6%81%E6%B1%82%E7%9A%84%E4%BF%A1%E6%81%AF%E6%9C%89%E6%9B%B4%E6%96%B0%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%8F%90%E4%BE%9B%E6%89%80%E9%9C%80%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E4%BB%AC%E5%B0%BD%E5%BF%AB%E5%B8%AE%E5%8A%A9%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E8%A6%81%E6%B1%82%E7%9A%84%E4%BF%A1%E6%81%AF%E6%9C%89%E6%9B%B4%E6%96%B0%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2165603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%20%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%8F%90%E4%BE%9B%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%8F%90%E4%BE%9B%E5%AE%8C%E6%95%B4%E7%9A%84%20DTS%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%E5%A6%82%E6%9E%9C%E5%8F%91%E7%8E%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%9A%84%E5%8F%AF%E7%94%A8%E7%89%88%E6%9C%AC%E5%B8%AE%E5%8A%A9%E8%8E%B7%E5%8F%96%E5%97%85%E6%8E%A2%E5%99%A8%E7%97%95%E8%BF%B9%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%E8%BF%98%E8%AF%B7%E5%B8%AE%E5%8A%A9%E8%8E%B7%E5%8F%96%E5%90%8C%E6%AD%A5%E7%9A%84%20dmesg%20%E6%97%A5%E5%BF%97%E3%80%82%3CSTRONG%3E%E4%B8%8D%E8%A6%81%E4%BD%BF%E7%94%A8%E4%BB%BB%E4%BD%95%20drvdbg%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3Eext.%E4%BD%BF%E7%94%A8%E4%BA%86%20AP%EF%BC%9F%E6%88%91%E4%BB%AC%E8%83%BD%E6%8B%BF%E5%88%B0%E5%A4%96%E7%BA%BF%E7%94%B5%E8%AF%9D%E5%90%97%EF%BC%9FAP%20%E5%9E%8B%E5%8F%B7%2FFW%20%E7%89%88%E6%9C%AC%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%E6%98%AF%E5%90%A6%E4%BB%85%E5%9C%A8%20161%20%E9%A2%91%E9%81%93%E4%B8%8A%E5%8F%91%E7%8E%B0%E9%97%AE%E9%A2%98%EF%BC%9F%E6%82%A8%E8%83%BD%E5%9C%A8%E5%85%B6%E4%BB%96%E9%A2%91%E9%81%93%EF%BC%8836%20%E6%88%96%2040%20%E7%AD%89%EF%BC%89%E4%B8%8A%E6%A3%80%E6%9F%A5%E9%97%AE%E9%A2%98%E7%9A%84%E5%8F%91%E7%94%9F%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22uiOutputText%22%3EChristine%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%20%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BB%8E%E4%BD%A0%E7%9A%84%E6%97%A5%E5%BF%97%E6%9D%A5%E7%9C%8B%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%A0%E7%9A%84%E6%9D%BF%E4%B8%8A%E5%B7%B2%E7%BB%8F%E5%90%AF%E7%94%A8%E4%BA%86%20ADMA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%86%E6%8A%8A%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8A%E6%8A%A5%E7%BB%99%E6%88%91%E4%BB%AC%E7%9A%84%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%EF%BC%8C%E8%AF%B7%E6%B1%82%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%A3%80%E6%9F%A5%E4%BA%86%E6%97%A5%E5%BF%97%EF%BC%8CADMA%20%E5%B7%B2%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E5%B9%B3%E5%8F%B0%E4%B8%8A%E5%90%AF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%20dmesg%20%E8%BE%93%E5%87%BA%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3Eroot%40Voice-Gateway%3A~%3CSPAN%20class%3D%22%22%3E%23%20dmesg%20%7C%20grep%20ADMA%3C%2FSPAN%3E%0A%5B%20%20%20%205.808617%5D%20mmc0%3A%20SDHCI%20controller%20on%202190000.usdhc%20%5B2190000.usdhc%5D%20using%20ADMA%0A%5B%20%20%20%205.873090%5D%20mmc1%3A%20SDHCI%20controller%20on%202194000.usdhc%20%5B2194000.usdhc%5D%20using%20ADMA%3C%2FSPAN%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E4%BB%AC%E5%B9%B3%E5%8F%B0%E4%B8%8A%3CSTRONG%3Eusdhc1%3C%2FSTRONG%3E%E7%9A%84%20DTS%20%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3Eusdhc1%3A%20usdhc%402190000%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22fsl%2Cimx6ul-usdhc%22%2C%20%22fsl%2Cimx6sx-usdhc%22%3B%0A%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0x02190000%200x4000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20interrupts%20%3D%20%3CGIC_SPI%2022%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%0A%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1%26gt%3B%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1%26gt%3B%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20clock-names%20%3D%20%22ipg%22%2C%20%22ahb%22%2C%20%22per%22%3B%0A%20%20%20%20%20%20%20%20fsl%2Ctuning-step%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20fsl%2Ctuning-start-tap%20%3D%20%26lt%3B20%26gt%3B%3B%0A%20%20%20%20%20%20%20%20bus-width%20%3D%20%26lt%3B4%26gt%3B%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22disabled%22%3B%0A%7D%3B%0A%0A%26amp%3Busdhc1%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22fsl%2Cimx6ull-usdhc%22%2C%20%22fsl%2Cimx6sx-usdhc%22%3B%0A%20%20%20%20%20%20%20%20assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1_SEL%26gt%3B%2C%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20assigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_PLL2_PFD2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20assigned-clock-rates%20%3D%20%26lt%3B0%26gt%3B%2C%20%26lt%3B132000000%26gt%3B%3B%0A%7D%3B%0A%0Afragment%401%20%7B%0A%20%20%20%20%20%20%20%20target%20%3D%20%26lt%3B%26amp%3Busdhc1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20__overlay__%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-names%20%3D%20%22default%22%2C%20%22state_100mhz%22%2C%20%22state_200mhz%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc1_100mhz%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-2%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc1_200mhz%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20non-removable%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20keep-power-in-suspend%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20wakeup-source%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20fsl%2Csdio-interrupt-enabled%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%7D%3B%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%E8%AF%B7%E7%A1%AE%E8%AE%A4%E8%BF%99%E6%98%AF%E5%90%A6%E7%AC%A6%E5%90%88%E5%9C%A8%3CSTRONG%3EUSDHC1%3C%2FSTRONG%3E%20%E4%B8%8A%E5%90%AF%E7%94%A8%20ADMA%20%E7%9A%84%E8%A6%81%E6%B1%82%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EYangyaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E1.%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E4%B8%8E%E6%88%91%E5%85%B1%E4%BA%AB%20dts%20%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E4%BF%9D%E5%AD%98%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%8F%91%E9%80%81%E5%88%B0%E6%88%91%E7%9A%84%20email%3Achristine.li%40nxp.com%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%E8%A6%81%E5%90%AF%E7%94%A8%20ADMA%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20dts%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E4%B8%80%E8%A1%8C%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3C!--ScriptorStartFragment--%3Edma-coherent%EF%BC%9B%3C!--ScriptorEndFragment--%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3.%20%E8%A6%81%E6%A3%80%E6%9F%A5%20ADMA%20%E6%98%AF%E5%90%A6%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%20dmesg%EF%BC%88%E4%BB%8E%E8%AE%BE%E5%A4%87%E5%90%AF%E5%8A%A8%E5%BC%80%E5%A7%8B%EF%BC%89%EF%BC%8C%3C!--ScriptorStartFragment--%3Edmesg%20%7C%20grep%20usdhc%3C!--ScriptorEndFragment--%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20translate%3D%22no%22%3E%3CCODE%20translate%3D%22no%22%3Emmc0%3A%20SDHCI%20controller%20on%2030b40000.usdhc%20%5B30b40000.usdhc%5D%20using%20ADMA%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E7%AC%AC%E4%B8%80%E7%82%B9%EF%BC%9A%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%EF%BC%8C%3CSTRONG%3E%E5%9C%A8%E6%95%B4%E4%B8%AA%E6%B5%8B%E8%AF%95%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%B2%A1%E6%9C%89%E4%BA%BA%E5%B7%A5%E5%B9%B2%E9%A2%84%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E4%BB%8E%E6%97%A5%E5%BF%97%E6%9D%A5%E7%9C%8B%EF%BC%8CWi-Fi%20%E8%BF%9E%E6%8E%A5%E4%BC%BC%E4%B9%8E%E6%98%AF%3CSTRONG%3E%E8%87%AA%E5%8A%A8%E6%96%AD%E5%BC%80%E5%B9%B6%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E7%9A%84%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%EF%BC%88%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E8%AE%BE%E8%AE%A1%E4%B8%BA%E5%9C%A8%E6%A3%80%E6%B5%8B%E5%88%B0%E5%BC%82%E5%B8%B8%E6%96%AD%E5%BC%80%3CSTRONG%3E%E8%BF%9E%E6%8E%A5%E6%97%B6%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%3C%2FSTRONG%3E%E8%BF%9E%E6%8E%A5%E3%80%82%EF%BC%89%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E5%8F%AA%E6%98%AF%3CSTRONG%3E%E7%9F%AD%E6%9C%9F%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%3C%2FSTRONG%3E%EF%BC%8C%E4%BB%8E%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E8%A7%92%E5%BA%A6%E6%9D%A5%E7%9C%8B%EF%BC%8C%E8%BF%99%E4%B9%9F%E8%AE%B8%E6%98%AF%E5%8F%AF%E4%BB%A5%E6%8E%A5%E5%8F%97%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%3CSTRONG%3E%E7%AC%AC%202%20%E7%82%B9%E5%92%8C%E7%AC%AC%3C%2FSTRONG%3E%20%3CSTRONG%3E3%3C%2FSTRONG%3E%20%E7%82%B9%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E9%80%9A%E8%BF%87%E5%9C%A8%E8%AE%BE%E5%A4%87%E5%92%8C%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%A6%81%E7%94%A8%E7%9C%81%E7%94%B5%E6%A8%A1%E5%BC%8F%E5%92%8C%E8%87%AA%E5%8A%A8%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%AE%9E%E9%AA%8C%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%3CSTRONG%3E%E5%AE%83%E5%B9%B6%E6%B2%A1%E6%9C%89%E4%BA%A7%E7%94%9F%E9%87%8D%E5%A4%A7%E5%BD%B1%E5%93%8D%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E7%AC%AC%3CSTRONG%3E4%3C%2FSTRONG%3E%20%E7%82%B9%EF%BC%8C%E6%88%91%E4%BB%AC%E6%83%B3%E7%9F%A5%E9%81%93%3CSTRONG%3E%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%20SDIO%20%E4%BB%8E%20DMA%20%E6%A8%A1%E5%BC%8F%E5%88%87%E6%8D%A2%E5%88%B0%20ADMA%20%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E6%83%B3%E8%AF%95%E8%AF%95%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%EF%BC%8C%E7%9C%8B%E7%9C%8B%E6%98%AF%E5%90%A6%E8%83%BD%E6%8F%90%E9%AB%98%E7%A8%B3%E5%AE%9A%E6%80%A7%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%9C%E4%B8%BA%E4%B8%B4%E6%97%B6%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%3CSTRONG%3E%E5%B0%86%20SDIO%20%E9%80%9F%E5%BA%A6%E9%99%8D%E8%87%B3%2050%20MHz%3C%2FSTRONG%3E%EF%BC%8C%E5%B9%B6%3CSTRONG%3E%E6%9B%B4%E6%96%B0%E4%BA%86%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%E4%BB%A5%E8%A7%A3%E5%86%B3%E7%9B%AE%E5%89%8D%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A8%E8%80%80%E5%85%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E1.%E5%BD%93%20iperf%205G%20%E5%90%9E%E5%90%90%E9%87%8F%E9%99%8D%E8%87%B3%200Mbps%20%E6%97%B6%EF%BC%8C%E6%8E%A5%E5%85%A5%E7%82%B9%E5%92%8C%20STA%20%E4%B9%8B%E9%97%B4%E7%9A%84%E8%BF%9E%E6%8E%A5%E6%98%AF%E5%90%A6%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%9F%E8%BF%98%E6%98%AF%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%E6%97%A5%E5%BF%97%E4%B8%AD%E7%9C%8B%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%E6%98%AF%E8%87%AA%E5%8A%A8%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E8%BF%98%E6%98%AF%E4%BD%A0%E6%89%8B%E5%8A%A8%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%0A%3CP%3E%5B41972.636502%5D%20wlan%EF%BC%9A%E6%8E%A5%E6%94%B6%E5%88%B0%20wlan0%20%E4%B8%8A%E7%9A%84%E8%A7%A3%E9%99%A4%E5%85%B3%E8%81%94%E8%AF%B7%E6%B1%82%EF%BC%8C%E5%8E%9F%E5%9B%A0%EF%BC%9A3%3CBR%20%2F%3E%5B41972.677171%5Dwlan%EF%BC%9A%E5%8E%9F%E5%9B%A0%EF%BC%9A%EF%BC%88Deauth%EF%BC%89%E5%8F%91%E9%80%81%20STA%20%E6%AD%A3%E5%9C%A8%E7%A6%BB%E5%BC%80%EF%BC%88%E6%88%96%E5%B7%B2%E7%BB%8F%E7%A6%BB%E5%BC%80%EF%BC%89IBSS%20%E6%88%96%20ESS%3CBR%20%2F%3E%5B41972.716536%5D%E5%B7%B2%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%3C%2FP%3E%0A%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%0A%3CP%3E2.%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20wifi_mod_para.conf%20%E4%B8%AD%E7%9A%84%E4%BB%A5%E4%B8%8B%E6%AE%B5%E8%90%BD%E7%A6%81%E7%94%A8%E7%9C%81%E7%94%B5%E6%A8%A1%E5%BC%8F%E5%92%8C%E8%87%AA%E5%8A%A8%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E3%80%82%20%3C%2FP%3E%0A%3CDIV%3E%3CSTRONG%3E%20ps_mode%3D2%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E%20auto_ds%3D2%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E3.%E5%A6%82%E6%9E%9C%E4%B8%BB%E6%9C%BA%E7%AB%AF%E6%9C%89%E4%BB%BB%E4%BD%95%E4%B8%8E%E7%9C%81%E7%94%B5%E7%9B%B8%E5%85%B3%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%B9%9F%E8%AF%B7%E5%B0%86%E5%85%B6%E5%85%B3%E9%97%AD%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E4.%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%88%91%E4%BB%AC%E7%9A%84%E5%86%85%E9%83%A8%E6%A1%88%E4%BE%8B%EF%BC%8C%E5%85%B6%E4%BB%96%E5%AE%A2%E6%88%B7%E5%9C%A8%E4%BD%BF%E7%94%A8%20DMA%20%E6%A8%A1%E5%BC%8F%E7%9A%84%20SDIO%20%E6%97%B6%E4%B9%9F%E4%BC%9A%E9%81%87%E5%88%B0%E8%BF%99%E7%A7%8D%E9%97%AE%E9%A2%98%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%94%B9%E4%B8%BA%20ADMA%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%A5%BD%E8%B5%B7%E6%9D%A5%E3%80%82%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156446%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156446%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84i.MX6ULL%E5%B9%B3%E5%8F%B0%E4%B8%8A%EF%BC%8C%E5%9C%A8%E9%95%BF%E6%9C%9F%E7%9A%84iperf3%E6%B5%8B%E8%AF%95%E4%B8%AD%EF%BC%8C%E5%B0%86SDIO%E6%97%B6%E9%92%9F%E4%BF%9D%E6%8C%81%E5%9C%A8100%20MHz%E5%BE%80%E5%BE%80%E4%BC%9A%E6%9B%B4%E9%A2%91%E7%B9%81%E5%9C%B0%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E5%90%9E%E5%90%90%E9%87%8F%E4%B8%8B%E9%99%8D%E8%87%B30%20Mbps%E3%80%82%3C%2FP%3E%3CP%3E%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8C%E5%9C%A8%E5%AF%B9%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20i.MX8%20%E5%B9%B3%E5%8F%B0%E7%9A%84%E5%8F%A6%E4%B8%80%E6%9D%A1%E4%BA%A7%E5%93%81%E7%BA%BF%E8%BF%9B%E8%A1%8C%E5%B9%B6%E8%A1%8C%E6%B5%8B%E8%AF%95%E6%97%B6%EF%BC%8C%E4%BB%A5%20100%20MHz%20SDIO%20%E6%97%B6%E9%92%9F%E8%BF%90%E8%A1%8C%E4%B9%9F%E4%BC%9A%E5%AF%BC%E8%87%B4%20CMD53%20%E5%9C%A8%E8%BF%9E%E7%BB%AD%E6%89%BF%E5%8F%97%203-5%20%E5%B0%8F%E6%97%B6%E5%8E%8B%E5%8A%9B%E5%90%8E%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E3%80%82%E5%8F%AA%E6%9C%89%E5%B0%86%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E9%99%8D%E4%BD%8E%E5%88%B0%2050%20MHz%EF%BC%8C%E6%89%8D%E8%83%BD%E5%AE%9E%E7%8E%B0%E7%A8%B3%E5%AE%9A%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%90%9E%E5%90%90%E9%87%8F%E7%95%A5%E6%9C%89%E9%99%8D%E4%BD%8E%E3%80%82%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22478%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yangyaoguang_0-1755832598173.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yangyaoguang_0-1755832598173.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F353603i83A6234E965C3664%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yangyaoguang_0-1755832598173.png%22%20alt%3D%22yangyaoguang_0-1755832598173.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3E5.4.70-imx8mp%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E9%97%AE%E9%A2%98%E4%BC%BC%E4%B9%8E%E6%B6%89%E5%8F%8A%20Wi-Fi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%20SDIO%20%E6%97%B6%E9%92%9F%E9%80%9F%E5%BA%A6%E3%80%82%E6%82%A8%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E8%A7%81%E8%A7%A3%E6%88%96%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EYangyaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E1.%E5%A6%82%E6%9E%9C%E5%B0%86%3CSPAN%3E%20Wi-Fi%20%E6%A8%A1%E5%9D%97%E7%9A%84%3C%2FSPAN%3E%3CSTRONG%3E%20SDIO%20%E6%8E%A5%E5%8F%A3%E6%9C%80%E9%AB%98%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%3C%2FSTRONG%3E%3CSTRONG%3E%20%E6%8E%A7%E5%88%B6%E5%9C%A8%20100MHz%EF%BC%8C%E8%83%BD%E5%90%A6%E6%BB%A1%E8%B6%B3%E6%82%A8%E7%9A%84%E8%A6%81%E6%B1%82%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%BD%93%E4%BD%A0%E5%B0%86%E9%A2%91%E7%8E%87%E9%99%8D%E8%87%B3%2050MHz%20%E6%97%B6%EF%BC%8CWi-Fi%20%E7%9A%84%E6%95%B4%E4%BD%93%E6%80%A7%E8%83%BD%E4%B9%9F%3CSTRONG%3E%E7%95%A5%E6%9C%89%3C%2FSTRONG%3E%E4%B8%8B%E9%99%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%82%A8%E5%B7%B2%E7%BB%8F%E6%9B%B4%E6%8D%A2%E4%BA%86%3CSTRONG%3E%E5%85%B6%E4%BB%96%20AP%EF%BC%88%E4%B8%8D%E6%98%AF%2088W8997%EF%BC%89%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E3.%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E6%A8%A1%E5%9D%97%EF%BC%9FAzureWave%20%E7%9A%84%20AW-CM276MA-SUR%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%89%8B%E4%B8%8A%E6%B2%A1%E6%9C%89%2088W8997%20%E7%9A%84%20SD-UART%20%E6%A8%A1%E5%9D%97%EF%BC%8C%E5%90%A6%E5%88%99%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E7%94%A8%20I.MX6ULL-EVK%20%E5%9C%A8%E6%9C%AC%E5%9C%B0%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%B7%9F%E8%BF%9B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E5%B0%9D%E8%AF%95%E8%B0%83%E6%95%B4%20Wi-Fi%20%E6%A8%A1%E5%9D%97%E7%9A%84%3CSTRONG%3E%E6%9C%80%E5%A4%A7%20SDIO%20%E6%8E%A5%E5%8F%A3%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%3C%2FSTRONG%3E%E3%80%82%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E9%A2%91%E7%8E%87%E4%BB%8E%3CSTRONG%3E100-200%20%E5%85%86%E8%B5%AB%3C%2FSTRONG%3E%E9%99%8D%E8%87%B3%3CSTRONG%3E50%20%E5%85%86%E8%B5%AB%3C%2FSTRONG%3E%E3%80%82%E5%9C%A8%E8%BF%99%E4%B8%80%E5%8F%98%E5%8C%96%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%91%E7%8E%B0%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EWi-Fi%20%E5%90%9E%E5%90%90%E9%87%8F%3CSTRONG%3E%E9%99%8D%E8%87%B3%200%20Mbps%3C%2FSTRONG%3E%E7%9A%84%E6%A6%82%E7%8E%87%E4%BC%BC%E4%B9%8E%E6%9C%89%E6%89%80%E4%B8%8B%E9%99%8D%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%3CSTRONG%3EWi-Fi%20%E7%9A%84%E6%95%B4%E4%BD%93%E6%80%A7%E8%83%BD%E4%B9%9F%E7%95%A5%E6%9C%89%E4%B8%8B%E9%99%8D%3C%2FSTRONG%3E%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E7%94%B1%E4%BA%8E%20SDIO%20%E5%B8%A6%E5%AE%BD%E5%87%8F%E5%B0%91%E6%89%80%E8%87%B4%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E4%BA%86%E8%A7%A3%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%3CSTRONG%3E%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%9A%84%E5%BB%BA%E8%AE%AE%3C%2FSTRONG%3E%EF%BC%8C%3CSTRONG%3E%E5%9C%A8%E4%B8%8D%E5%A4%A7%E5%B9%85%E9%99%8D%E4%BD%8E%E5%90%9E%E5%90%90%E9%87%8F%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%3C%2FSTRONG%3E%E8%B0%83%E6%95%B4%E6%88%96%E6%8F%90%E9%AB%98%E7%A8%B3%E5%AE%9A%E6%80%A7%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E8%80%80%E5%85%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E5%A6%82%E4%BD%95%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%98%E8%83%BD%E4%B8%BA%E8%BF%99%E4%BB%B6%E4%BA%8B%E5%81%9A%E4%BA%9B%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E5%A6%82%E4%BD%95%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%98%E8%83%BD%E4%B8%BA%E8%BF%99%E4%BB%B6%E4%BA%8B%E5%81%9A%E4%BA%9B%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%AF%B4%E6%98%8E%E5%92%8C%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%8C%89%E7%85%A7%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E6%A1%88%E4%BE%8B%E6%9D%A5%E5%8D%95%E7%8B%AC%E8%B7%9F%E8%B8%AA%E8%BF%99%E4%B8%AA%E5%B8%A6%E5%86%85RESET%E6%81%A2%E5%A4%8D%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E9%93%BE%E6%8E%A5%E5%A6%82%E4%B8%8B%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FSD8997-Wi-Fi-Fails-to-Recover-After-In-Band-Reset-Triggered-by%2Fm-p%2F2152650%2Fhighlight%2Ffalse%23M29696%22%20target%3D%22_new%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FSD8997-Wi-Fi-Fails-to-Recover-After-In-Band-Reset-Triggered-by%2Fm-p%2F2152650%2Fhighlight%2Ffalse%23M29696%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E5%9C%A8%E6%AD%A4%E4%B8%BB%E9%A2%98%E4%B8%AD%E7%BB%A7%E7%BB%AD%E8%B7%9F%E8%B8%AA%E6%9C%80%E5%88%9D%E7%9A%84%E5%90%9E%E5%90%90%E9%87%8F%E4%B8%8B%E9%99%8D%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%3CSTRONG%3EYaoguang%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E6%96%B0%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%B8%AE%E5%8A%A9%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E6%A1%88%E4%BE%8B%E6%9D%A5%E8%AE%A8%E8%AE%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%A7%8B%E7%BB%88%E5%BB%BA%E8%AE%AE%E5%AE%A2%E6%88%B7%E6%A0%B9%E6%8D%AE%E4%B8%8D%E5%90%8C%E7%9A%84%E6%A1%88%E4%BE%8B%E5%85%B3%E6%B3%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E6%9B%B4%E5%A5%BD%E5%9C%B0%E8%B7%9F%E8%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E5%92%8C%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E4%BB%A5%E5%A4%87%E5%B0%86%E6%9D%A5%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%EF%BC%8C%E6%AD%A4%E9%97%AE%E9%A2%98%E4%B8%8E%E5%9B%BA%E4%BB%B6%20RESET%20%E6%9C%89%E5%85%B3%EF%BC%8C%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E6%88%91%E4%BB%AC%E5%86%85%E9%83%A8%20SAE%20%E5%9B%A2%E9%98%9F%E7%9A%84%E5%B8%AE%E5%8A%A9%E6%9D%A5%E8%B7%9F%E8%B8%AA%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%80%82%E6%8D%A2%E5%8F%A5%E8%AF%9D%E8%AF%B4%EF%BC%8C%E5%85%A8%E7%90%83%E9%80%9A%E4%BF%A1%E9%9C%80%E8%A6%81%E6%9B%B4%E9%95%BF%E7%9A%84%E6%97%B6%E9%97%B4%E3%80%82%E8%AF%B7%E5%AF%B9%E6%AD%A4%E5%A4%9A%E4%B8%80%E4%BA%9B%E8%80%90%E5%BF%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E5%9C%A8%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%E4%B8%AD%E7%BB%A7%E7%BB%AD%E8%BF%BD%E8%B8%AA%E6%9C%80%E5%88%9D%E7%9A%84%E9%99%8D%E5%88%B0%200%20%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%90%86%E8%A7%A3%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%80%E7%9B%B4%E4%BB%A5%E6%9D%A5%E5%AF%B9%3CSTRONG%3E5GHz%20STA%20%E5%90%9E%E5%90%90%E9%87%8F%E9%99%8D%E8%87%B3%200%20Mbps%3C%2FSTRONG%3E%E9%97%AE%E9%A2%98%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%3CSTRONG%3E%E6%8C%81%E7%BB%AD%E7%9A%84%E7%A8%B3%E5%AE%9A%E6%80%A7%E5%92%8C%E5%8F%8D%E5%A4%8D%E7%9A%84%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E6%B5%8B%E8%AF%95%3C%2FSTRONG%3E%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%91%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%3CSTRONG%3E%E6%96%B0%E9%97%AE%E9%A2%98%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%A4%9A%E6%AC%A1%20EAPOL%20%E8%B6%85%E6%97%B6%E5%90%8E%EF%BC%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BC%9A%E8%A7%A6%E5%8F%91%3CSTRONG%3E%E5%B8%A6%E5%86%85%20RESET%3C%2FSTRONG%3E%EF%BC%8C%E4%BD%86%E9%9A%8F%E5%90%8E%E5%9B%BA%E4%BB%B6%3CSTRONG%3E%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20SDIO%20%E9%87%8D%E6%96%B0%E5%8A%A0%E8%BD%BD%3C%2FSTRONG%3E%EF%BC%8C%E4%BD%BF%20Wi-Fi%20%E5%9C%A8%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E4%B9%8B%E5%89%8D%E5%A4%84%E4%BA%8E%E9%9D%9E%E5%B7%A5%E4%BD%9C%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%BC%BC%E4%B9%8E%E5%8F%AA%E6%9C%89%E5%9C%A8%E5%A4%9A%E6%AC%A1%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%E5%90%8E%E6%89%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8E%E5%9B%BA%E4%BB%B6%E6%88%96%20SDIO%20%E6%8E%A5%E5%8F%A3%E5%A6%82%E4%BD%95%E5%A4%84%E7%90%86%E5%B8%A6%E5%86%85%20RESET%20%E5%90%8E%E7%9A%84%E6%81%A2%E5%A4%8D%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E7%9B%B8%E5%85%B3%E7%9A%84%20dmesg%20%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3E%5B%3CSPAN%20class%3D%22%22%3E87697.429777%3C%2FSPAN%3E%5D%20WiFi%20Reset%20due%20to%20EAPOL%20timeout%20cnt%20%3CSPAN%20class%3D%22%22%3E5%3C%2FSPAN%3E%0A%5B%3CSPAN%20class%3D%22%22%3E87697.499968%3C%2FSPAN%3E%5D%20%3D%3D%3D%3D%3D%3D%3D%3DSTART%20IN-BAND%20RESET%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%5B%3CSPAN%20class%3D%22%22%3E87704.130302%3C%2FSPAN%3E%5D%20wlan_sdio_poll_card_status%20failed%2C%20tries%20%3D%20%3CSPAN%20class%3D%22%22%3E10000%3C%2FSPAN%3E%2C%20cs%20%3D%20%3CSPAN%20class%3D%22%22%3E0xc%3C%2FSPAN%3E%0A%5B%3CSPAN%20class%3D%22%22%3E87704.259872%3C%2FSPAN%3E%5D%20wlan_dnld_fw%20fail%20ret%3D%3CSPAN%20class%3D%22%22%3E0xffffffff%3C%2FSPAN%3E%0A%5B%3CSPAN%20class%3D%22%22%3E87705.481337%3C%2FSPAN%3E%5D%20woal_request_fw%20failed%0A%5B%3CSPAN%20class%3D%22%22%3E87705.484769%3C%2FSPAN%3E%5D%20Firmware%20Init%20Failed%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%E8%AF%B7%E7%A1%AE%E8%AE%A4%E8%BF%99%E6%98%AF%E5%90%A6%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%88%96%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BC%9A%E5%8F%8A%E6%97%B6%E9%80%9A%E7%9F%A5%E4%BD%A0%E4%BB%AC%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E8%80%80%E5%85%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%BD%93%E7%84%B6%EF%BC%8C%E8%AE%A9%E6%88%91%E4%BB%AC%E7%BB%A7%E7%BB%AD%E8%AE%A8%E8%AE%BA%E8%BF%99%E4%B8%AA%E6%A1%88%E5%AD%90%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BB%BB%E4%BD%95%E9%9C%80%E8%A6%81%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8A%AA%E5%8A%9B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BB%8D%E5%9C%A8%E5%AF%B9%3CSTRONG%3ESD8997%20WiFi%20%E6%A8%A1%E5%9D%97%3C%2FSTRONG%3E%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95--%E5%9C%A8%20iperf3%20%E6%B5%8B%E8%AF%95%E4%B8%AD%EF%BC%8C5%20GHz%20STA%20%E5%90%9E%E5%90%90%E9%87%8F%E7%BB%8F%E5%B8%B8%E9%99%8D%E8%87%B3%200%20Mbps%E3%80%82%3CBR%20%2F%3E%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9C%89%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%9B%B4%E6%96%B0%E4%BA%86%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%9B%BA%E4%BB%B6%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%20DTS%20%E4%B8%AD%E8%B0%83%E6%95%B4%3CSTRONG%3ESDIO%20%E6%9C%80%E5%A4%A7%E9%A2%91%E7%8E%87%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%BF%99%E4%BA%9B%E5%8F%98%E5%8C%96%E4%BC%BC%E4%B9%8E%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9--%E5%90%9E%E5%90%90%E9%87%8F%E9%99%8D%E8%87%B3%200%20Mbps%20%E7%9A%84%E6%A6%82%E7%8E%87%E9%99%8D%E4%BD%8E%E4%BA%86%E3%80%82%E6%88%91%E4%BB%AC%E5%B0%86%E7%BB%A7%E7%BB%AD%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%94%B6%E9%9B%86%E5%88%B0%E6%9B%B4%E5%A4%9A%E6%95%B0%E6%8D%AE%E5%90%8E%E4%B8%8E%E5%A4%A7%E5%AE%B6%E5%88%86%E4%BA%AB%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E8%80%80%E5%85%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E4%B8%AA%E6%A1%88%E5%AD%90%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%81%9A%E8%BF%87%E4%BB%BB%E4%BD%95%E4%B8%8E%E6%9C%AC%E4%B8%BB%E9%A2%98%E7%9B%B8%E5%85%B3%E7%9A%84%E5%AE%9E%E9%AA%8C%E6%88%96%E6%B5%8B%E8%AF%95%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%E8%BF%99%E6%A0%B7%E6%88%91%E4%BB%AC%E5%B0%B1%E8%83%BD%E7%BB%A7%E7%BB%AD%E6%8E%A8%E8%BF%9B%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E4%B8%AA%E6%A1%88%E5%AD%90%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%81%9A%E8%BF%87%E4%BB%BB%E4%BD%95%E4%B8%8E%E6%9C%AC%E4%B8%BB%E9%A2%98%E7%9B%B8%E5%85%B3%E7%9A%84%E5%AE%9E%E9%AA%8C%E6%88%96%E6%B5%8B%E8%AF%95%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%E8%BF%99%E6%A0%B7%E6%88%91%E4%BB%AC%E5%B0%B1%E8%83%BD%E7%BB%A7%E7%BB%AD%E6%8E%A8%E8%BF%9B%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E8%AF%A6%E7%BB%86%E7%AD%94%E5%A4%8D%E5%92%8C%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E9%A6%96%E5%85%88%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%E5%88%87%E6%8D%A2%E5%88%B0%E5%8F%A6%E4%B8%80%E4%B8%AA%20AP%20%E6%9D%A5%E5%B0%9D%E8%AF%95%E6%9B%BF%E4%BB%A3%E6%B5%8B%E8%AF%95%E6%96%B9%E6%B3%95%EF%BC%8C%E5%B9%B6%E6%9F%A5%E7%9C%8B%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%E3%80%82%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E6%9B%B4%E5%A5%BD%E5%9C%B0%E7%90%86%E8%A7%A3%E5%92%8C%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%85%8B%E8%8E%89%E4%B8%9D%E6%B1%80%E3%80%81%3C%2FP%3E%3CP%3E%E4%B8%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E5%9C%A8%E6%80%A7%E8%83%BD%E6%B5%8B%E8%AF%95%E4%B8%AD%E5%8F%AA%E4%BD%BF%E7%94%A8%E4%BA%86%20SD8997%20%E7%9A%84%20Wi-Fi%20%E6%8E%A5%E5%8F%A3%E3%80%82%E8%93%9D%E7%89%99%E6%9C%AA%E5%90%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%20%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E7%94%A8%E5%85%B6%E4%BB%96%20AP%20%E6%B5%8B%E8%AF%95%E8%BF%87%E5%90%97%EF%BC%9F%E4%BE%8B%E5%A6%82%EF%BC%8CSD8997%20%E5%9C%A8%20STA%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%B9%B6%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%8F%A6%E4%B8%80%E4%B8%AA%20AP%EF%BC%88%E4%B8%8D%E4%BD%BF%E7%94%A8%20SD8997%EF%BC%89%E3%80%82%E8%BF%99%E6%A0%B7%EF%BC%8C%E6%82%A8%E8%BF%98%E8%83%BD%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CP%3E%E5%BD%93%E5%89%8D%E5%9B%BA%E4%BB%B6%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%E5%9C%A8%E9%AB%98%E5%B9%B6%E5%8F%91%E6%B5%81%E9%87%8F%E4%B8%8B%E7%9A%84%20STA%20%E6%A8%A1%E5%BC%8F%E4%B8%AD%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%EF%BC%9F%20%3D%3D%26gt%3BNo.%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E7%9B%B4%E5%88%B0%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E8%BF%98%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E5%85%B6%E4%BB%96%E5%AE%A2%E6%88%B7%E6%8A%A5%E5%91%8A%E6%9C%80%E6%96%B0%20FW%20%E5%AD%98%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E8%B0%83%E8%AF%95%E7%89%88%E6%9C%AC%E7%9A%84%E5%9B%BA%E4%BB%B6%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E6%9B%B4%E8%AF%A6%E7%BB%86%E7%9A%84%E6%97%A5%E5%BF%97%E8%AE%B0%E5%BD%95%E6%88%96%E6%96%AD%E8%A8%80%E8%B7%9F%E8%B8%AA%EF%BC%9F%3D%3D%26gt%3B%20%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%8A%A0%E8%BD%BD%20Wi-Fi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E5%8F%82%E6%95%B0%EF%BC%8C%E4%BB%A5%E5%90%AF%E7%94%A8%E6%9B%B4%E5%A4%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Arial%3B%20font-size%3A%2014.0pt%3B%20color%3A%20black%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3Edrvdbg%20%3D%200x20037%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%E8%A1%A5%E4%B8%81%E6%88%96%E5%86%85%E6%A0%B8%E4%BE%A7%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%88%E5%A6%82%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%E8%B0%83%E6%95%B4%E3%80%81SDIO%20IRQ%20%E8%81%9A%E5%90%88%EF%BC%89%EF%BC%9F%3D%3D%26gt%3B%E6%B2%A1%E6%9C%89%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E5%9C%A8%E6%9C%80%E6%96%B0%E7%9A%84%20FW%20%E4%B8%8A%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E6%AD%A4%E7%B1%BB%E9%97%AE%E9%A2%98%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%A1%A5%E4%B8%81%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%E5%85%B3%E4%BA%8E%E5%90%9E%E5%90%90%E9%87%8F%E6%80%A7%E8%83%BD%E8%B0%83%E6%95%B4%EF%BC%8C%E4%B9%9F%E8%AE%B8%E8%BF%99%E4%B8%AA%E9%93%BE%E6%8E%A5%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FRM00297%2Fpage%2Fconnectivity-features%2Ftopics%2Fthroughput_performance_tuning.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FRM00297%2Fpage%2Fconnectivity-features%2Ftopics%2Fthroughput_performance_tuning.html%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E6%82%A8%E6%8A%A5%E5%91%8A%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%B0%86%E7%BB%A7%E7%BB%AD%E8%B0%83%E8%AF%95%EF%BC%8C%E5%B9%B6%E5%B0%9D%E8%AF%95%E5%9C%A8%E6%9C%AC%E5%9C%B0%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%9C%8B%E7%9C%8B%E8%83%BD%E5%90%A6%E9%87%8D%E7%8E%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%20dmesg%20%E6%97%A0%E6%95%88%EF%BC%8C%E8%AF%B7%E5%86%8D%E6%AC%A1%E6%8F%90%E4%BE%9B%E7%BB%99%E6%88%91%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E5%85%8B%E9%87%8C%E6%96%AF%E8%92%82%E5%A8%9C%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B9%8B%E5%89%8D%E7%9A%84%E5%9B%9E%E5%A4%8D%E4%BB%A5%E5%8F%8A%E6%8F%90%E4%BE%9B%E6%9B%B4%E6%96%B0%E7%9A%84%E5%9B%BA%E4%BB%B6%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%B5%84%E6%BA%90%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E7%8E%B0%E5%B7%B2%E6%88%90%E5%8A%9F%E5%8D%87%E7%BA%A7%E5%88%B0%E4%BB%A5%E4%B8%8B%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%9B%BA%E4%BB%B6%3C%2FSTRONG%3E%EF%BC%9A%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%20-b%20lf-6.12.20-2.0.0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmwifiex.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3Ahttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmwifiex.git%3C%2FA%3E%3CSPAN%3E%20-b%20lf-6.12.20-2.0.0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%BA%94%E7%94%A8%E8%BF%99%E4%BA%9B%E6%9B%B4%E6%96%B0%E5%90%8E%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%20iperf3%20%E4%BB%A5%2010%20%E4%B8%AA%E5%B9%B6%E8%A1%8C%E6%95%B0%E6%8D%AE%E6%B5%81%20(-P%2010)%20%E9%87%8D%E6%96%B0%E8%BF%9B%E8%A1%8C%E4%BA%86%205GHz%20STA%20%E6%80%A7%E8%83%BD%E6%B5%8B%E8%AF%95%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E2%80%94%E2%80%94%E5%A6%82%E9%9A%8F%E9%99%84%E7%9A%84%E6%97%A5%E5%BF%97%E6%89%80%E7%A4%BA%EF%BC%8C%3CSTRONG%3E%E5%A4%9A%E4%B8%AA%20iperf3%20%E7%BA%BF%E7%A8%8B%E6%8A%A5%E5%91%8A%E9%95%BF%E6%97%B6%E9%97%B4%E5%90%9E%E5%90%90%E9%87%8F%E4%B8%BA%200.00%20%E4%BD%8D%2F%E9%AB%98%E6%95%88%E5%AF%86%E7%A0%81%E5%AD%A6%E6%A0%87%E5%87%86(SEC)%3C%2FSTRONG%3E%E3%80%82%E5%8D%B3%E4%BD%BF%E5%9C%A8%E9%87%8D%E4%BC%A0%E6%AC%A1%E6%95%B0%E6%9E%81%E5%B0%91%E3%80%81%E7%9C%81%E7%94%B5%E5%8A%9F%E8%83%BD%E8%A2%AB%E7%A6%81%E7%94%A8%EF%BC%88ps_mode%3D0%EF%BC%8Cauto_ds%3D0%EF%BC%89%E7%9A%84%E7%A8%B3%E5%AE%9A%E6%B5%8B%E8%AF%95%E7%8E%AF%E5%A2%83%E4%B8%AD%EF%BC%8C%E4%B9%9F%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E7%A7%8D%E6%A8%A1%E5%BC%8F%E8%A1%A8%E6%98%8E%EF%BC%8C%E5%B0%BD%E7%AE%A1%E6%88%90%E5%8A%9F%E5%85%B3%E8%81%94%E5%92%8C%3CSTRONG%3E%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E4%BD%86%E4%BB%8D%E5%8F%AF%E8%83%BD%E5%87%BA%E7%8E%B0%20Tx%20%E8%B7%AF%E5%BE%84%E5%81%9C%E9%A1%BF%E6%88%96%E9%98%9F%E5%88%97%E4%B8%8D%E8%B6%B3%E9%97%AE%E9%A2%98%3C%2FSTRONG%3E%EF%BC%8C%E5%8F%AF%E8%83%BD%E5%8F%91%E7%94%9F%E5%9C%A8%E5%9B%BA%E4%BB%B6%E6%88%96%20SDIO%20%E4%BC%A0%E8%BE%93%E5%B1%82%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E5%B0%B1%E4%BB%A5%E4%B8%8B%E5%87%A0%E7%82%B9%E6%8F%90%E4%BE%9B%E6%94%AF%E6%8C%81%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%E5%BD%93%E5%89%8D%E5%9B%BA%E4%BB%B6%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%E5%9C%A8%E9%AB%98%E5%B9%B6%E5%8F%91%E6%B5%81%E9%87%8F%E4%B8%8B%E7%9A%84%20STA%20%E6%A8%A1%E5%BC%8F%E4%B8%AD%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E8%B0%83%E8%AF%95%E7%89%88%E6%9C%AC%E7%9A%84%E5%9B%BA%E4%BB%B6%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E6%9B%B4%E8%AF%A6%E7%BB%86%E7%9A%84%E6%97%A5%E5%BF%97%E8%AE%B0%E5%BD%95%E6%88%96%E6%96%AD%E8%A8%80%E8%B7%9F%E8%B8%AA%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%E4%BF%AE%E8%A1%A5%E7%A8%8B%E5%BA%8F%E6%88%96%E5%86%85%E6%A0%B8%E4%BE%A7%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%88%E5%A6%82%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%E8%B0%83%E6%95%B4%E3%80%81SDIO%20IRQ%20%E8%81%9A%E5%90%88%EF%BC%89%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E9%9A%8F%E6%97%B6%E4%B8%BA%E6%82%A8%E6%8F%90%E4%BE%9B%E5%AE%8C%E6%95%B4%E7%9A%84%20dmesg%20%E6%97%A5%E5%BF%97%E3%80%81%E6%A8%A1%E5%9D%97%E5%8A%A0%E8%BD%BD%E5%8F%82%E6%95%B0%E6%88%96%E6%89%80%E9%9C%80%E7%9A%84%E5%85%B6%E4%BB%96%E8%AF%8A%E6%96%AD%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E4%B8%80%E5%A6%82%E6%97%A2%E5%BE%80%E7%9A%84%E5%8D%8F%E5%8A%A9%E5%92%8C%E6%94%AF%E6%8C%81%E3%80%82%E6%88%91%E4%BB%AC%E8%A1%B7%E5%BF%83%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E5%B8%AE%E5%8A%A9%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%3CSTRONG%3EYaoguang%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E9%99%84%E4%BB%B6%E5%8C%85%E5%90%AB%E5%AE%8C%E6%95%B4%E7%9A%84%E6%B5%8B%E8%AF%95%E6%97%A5%E5%BF%97%EF%BC%8C%E5%8C%85%E6%8B%AC%20dmesg%20%E8%BE%93%E5%87%BA%E3%80%81iperf3%20%E5%90%9E%E5%90%90%E9%87%8F%E7%BB%93%E6%9E%9C%E5%92%8C%20Wi-Fi%20%E9%85%8D%E7%BD%AE%E8%AF%A6%E6%83%85%EF%BC%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%80%9A%E8%BF%87%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%20%E5%8A%A0%E8%BD%BD%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40%E6%9D%A8%E8%80%80%E5%85%89%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%BA%E6%88%91%E4%BB%AC%E5%88%9B%E5%BB%BA%E6%A1%88%E4%BE%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9C%8B%E8%A7%81%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%9C%A8%20%3CSPAN%3E2023%20%E5%B9%B4%2012%20%E6%9C%88%2014%20%E6%97%A5%E7%89%88%E6%9C%AC%E6%97%A7%E5%9B%BA%E4%BB%B6%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E5%BF%99%E7%94%A8%E6%88%91%E4%BB%AC%E6%9C%80%E6%96%B0%E7%9A%84%20FW%20%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%AF%95%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%9C%89%E5%85%B3%E8%8E%B7%E5%8F%96%E6%9C%80%E6%96%B0%20FW%20%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8B%E6%96%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH4%20class%3D%22title-and-elements%22%20id%3D%22toc-hId-175886418%22%20id%3D%22toc-hId-202816491%22%3E%E5%AF%B9%E4%BA%8E%20FW%EF%BC%9A%3C%2FH4%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%3E%23%20git%20clone%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E-b%20lf-6.12.20-2.0.0%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CFONT%20size%3D%224%22%3E%23%20cd%20imx-firmware%2Fnxp%2F%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3E%E5%8F%B8%E6%9C%BA%E4%B8%93%E7%94%A8%EF%BC%9A%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%23%20git%20clone%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmwifiex.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmwifiex.git%3C%2FA%3E-b%20lf-6.12.20-2.0.0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%3E%23%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BB%8D%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%B9%B6%E6%8F%90%E4%BE%9B%20Wifi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E8%BD%BD%E5%8F%82%E6%95%B0%E5%92%8C%20dmesg%20%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EChristine%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BURGENT%5D%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH4%20id%3D%22toc-hId-175861344%22%20id%3D%22toc-hId--1604637972%22%3E%3CSTRONG%3E%E5%B9%B3%E5%8F%B0%E8%AF%A6%E6%83%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ESoC%3C%2FSTRONG%3E%EF%BC%9A%E6%81%A9%E6%99%BA%E6%B5%A6%20i.MX6ULL%EF%BC%88ARMv7%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%86%85%E6%A0%B8%3C%2FSTRONG%3ELinux%205.4.24-imx6ull%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EWiFi%20%E6%A8%A1%E5%9D%97%3C%2FSTRONG%3E%EF%BC%9A%E6%81%A9%E6%99%BA%E6%B5%A6%20SD8997%EF%BC%88SDIO%20%E6%8E%A5%E5%8F%A3%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%A0%86%E6%A0%88%3C%2FSTRONG%3E%EF%BC%9AMOAL%2FMLAN%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%9B%BA%E4%BB%B6%3C%2FSTRONG%3E%EF%BC%9A%20sdiouart8997_combo_v4.bin%3CBR%20%2F%3E%E2%86%92%20%E7%89%88%E6%9C%AC%EF%BC%9A16.92.21.p84.4%20(FP92)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%8A%9F%E7%8E%87%E8%A1%A8%3C%2FSTRONG%3E%EF%BC%9Atx_power_test.bin%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EWiFi%20%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%EF%BC%9ASTA%EF%BC%88%E4%BB%85%E9%99%90%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%A8%A1%E5%BC%8F%EF%BC%89ps_mode%3D0%3CBR%20%2F%3Eauto_ds%3D0%3CBR%20%2F%3Efw_name%3Dnxp%2Fsdiouart8997_combo_v4.bin%3CBR%20%2F%3Etxpwrlimit_cfg%3Dnxp%2Ftx_power_test.bin%3CBR%20%2F%3Edrv_mode%3D3%3CBR%20%2F%3Esta_name%3Dwlan%3CBR%20%2F%3Ecfg80211_wext%3D0xf%3C%2FP%3E%3CH3%20id%3D%22toc-hId-165358240%22%20id%3D%22toc-hId--1615141076%22%3E%3CSTRONG%3E%E6%B5%8B%E8%AF%95%E8%AE%BE%E7%BD%AE%E5%92%8C%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ESTA%3C%2FSTRONG%3E(SD8997)%20%E2%86%90%E2%86%92%3CSTRONG%3EAP%3C%2FSTRONG%3E(SD8997)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E9%80%9A%E9%81%93%EF%BC%9A%3CSTRONG%3E5GHz%3C%2FSTRONG%3E%E3%80%81HT40%E3%80%81CH161%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E7%8E%AF%E5%A2%83%EF%BC%9A%3CSTRONG%3E%E9%9D%9E%E5%B1%8F%E8%94%BD%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%B7%A5%E5%85%B7%EF%BC%9A%20iperf3%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%9A%20iperf3%20-s%20-p%207777%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%9A%20iperf3%20-c%3CAP%20ip%3D%22%22%3E%20-t%2020%20-i%201%20-P%2010%3C%2FAP%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E
