[URGENT] SD8997 WiFi Module — 5GHz STA Throughput Frequently Drops to 0 Mbps During iperf3 Testing
yangyaoguang
Dear NXP Support Team,
I hope this message finds you well.
We are currently evaluating the performance of the NXP SD8997 WiFi module (SDIO interface) on an i.MX6ULL-based platform running Linux 5.4.24, using the official moal/mlan driver stack. The firmware in use is sdiouart8997_combo_v4.bin, version 16.92.21.p84.4 (FP92), along with the associated tx_power_test.bin power table. Firmware loads correctly, and the driver reports successful initialization without errors.
However, we are encountering a critical and reproducible issue: when operating in 5GHz STA mode, the WiFi throughput frequently drops to 0 Mbps during iperf3 testing, even in stable open-air environments. This issue significantly impacts our validation process and raises concerns about the module’s reliability in real-world deployments.
In our test setup, the SD8997 module connects as a station to a 5GHz AP (HT40, channel 161). We initiate standard iperf3 throughput tests (e.g., iperf3 -c <AP IP> -t 20 -i 1 -P 10), during which multiple threads consistently show zero throughput, despite minimal retransmissions. Disabling power save features (ps_mode=0, auto_ds=0) does not alleviate the issue. Firmware initialization and WLAN association complete successfully, and the interface transitions into the CONNECTED state normally. The problem begins only after traffic starts flowing.
This issue is currently blocking our development progress, as 5GHz STA stability is a critical requirement in our target application.
We kindly seek your urgent support on the following:
  1. Is this a known issue with firmware version 16.92.21.p84.4 (FP92)?
  2. What is the recommended firmware and driver pairing for Linux 5.4 platforms using the moal stack?
  3. Are there known firmware-level limitations in STA mode that may cause Tx path stall or data flow blockage?
  4. Is there any debug firmware, patch, or recommended workaround available to help isolate or resolve the issue?
We are happy to provide additional test data, full dmesg logs, configuration files, or conduct further diagnostic testing as needed.
Thank you very much for your time and support. We sincerely appreciate your assistance in helping us move forward.
Yangguang
Christine_Li
Hi, @yangyaoguang
1.Can you please share the dts file to me?
To save your project info, you can sent it to my email:[email protected].
2.To enable the ADMA, you need add below line in dts:
dma-coherent;
3.To check whether ADMA has been enabled, you can check the dmesg(from device boot-up), dmesg | grep usdhc
mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
Christine.
yangyaoguang
Hi Christine,
Please find below the DTS configuration for usdhc1 on our platform:
usdhc1: usdhc@2190000 {
        compatible = "fsl,imx6ul-usdhc", "fsl,imx6sx-usdhc";
        reg = <0x02190000 0x4000>;
        interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>;
        clocks = <&clks IMX6UL_CLK_USDHC1>,
                 <&clks IMX6UL_CLK_USDHC1>;
        clock-names = "ipg", "ahb", "per";
        fsl,tuning-step = <2>;
        fsl,tuning-start-tap = <20>;
        bus-width = <4>;
        status = "disabled";
&usdhc1 {
        compatible = "fsl,imx6ull-usdhc", "fsl,imx6sx-usdhc";
        assigned-clocks = <&clks IMX6UL_CLK_USDHC1_SEL>, <&clks IMX6UL_CLK_USDHC1>;
        assigned-clock-parents = <&clks IMX6UL_CLK_PLL2_PFD2>;
        assigned-clock-rates = <0>, <132000000>;
fragment@1 {
        target = <&usdhc1>;
        __overlay__ {
                pinctrl-names = "default", "state_100mhz", "state_200mhz";
                pinctrl-0 = <&pinctrl_usdhc1>;
                pinctrl-1 = <&pinctrl_usdhc1_100mhz>;
                pinctrl-2 = <&pinctrl_usdhc1_200mhz>;
                non-removable;
                keep-power-in-suspend;
                wakeup-source;
                fsl,sdio-interrupt-enabled;
                status = "okay";
Please confirm if this matches the requirements for enabling ADMA on USDHC1.
Yangyaoguang
yangyaoguang
We have checked the logs, and ADMA is already enabled on our platform.
Here is the dmesg output:
root@Voice-Gateway:~# dmesg | grep ADMA
[    5.808617] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    5.873090] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
Christine_Li
Hi, @yangyaoguang
Thanks for your info.
Yes, from your logs, I think ADMA already enabled on your board.
And I will escalated this issue to our internal team to ask help.
Christine.
Christine_Li
Hi, @yangyaoguang
Please help to provide below info:
  1.  Please help provide complete DTS file.
  2. Use latest available release and help get the sniffer traces if issue is observed.
  3. Also please help get the in-sync dmesg log. Do not use any drvdbg.
  4. What is the ext. AP used? Can we get the ext. AP model/FW version details?
  5. Is issue observed on Channel-161 only? Can you check the issue scenario on other channels (36 or 40, etc) ?
Christine.
yangyaoguang
Hi Christine,
Thanks for your support.
After internal discussion and evaluation, we decided to adopt the following measures to address the issue:
  • Updated to the latest available Wi-Fi driver, and
  • Reduced the SDIO bus speed to 50MHz.
With these changes in place, the issue is no longer observed in our environment.
Currently, no further testing is planned beyond this scope.
YangYaoguang
Christine_Li
Hi, @yangyaoguang
Thanks for letting me know your plan.
So, Can we close this ticket for now?
And please do not hesitate to create new case to us if you need our help.
Christine.
yangyaoguang
Hi Christine,
Yes, we can close this ticket as the issue has been resolved.
Noted, and thank you for the support.
YangYaoguang
Christine_Li
Hi, @yangyaoguang
Any updates on our requested info?
Christine.
Christine_Li
Hi, @yangyaoguang
Please help to provide the requested info, so that we can help to resolve this issue ASAP.
Thanks.
Christine.
Christine_Li
Hi, @yangyaoguang
Any updates on this case?
If you did any experiment or test related to this thread, please share me your information. So that we can keep moving forward on this thread.
Thanks.
Christine.
yangyaoguang
Hi Christine,
No, we were only using the Wi-Fi interface of the SD8997 during the performance test. Bluetooth was not enabled.
Yaoguang
%3CLINGO-SUB%20id%3D%22lingo-sub-2142614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BURGENT%5D%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142614%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%20Support%20Team%2C%3C%2FP%3E%3CP%3EI%20hope%20this%20message%20finds%20you%20well.%3C%2FP%3E%3CP%3EWe%20are%20currently%20evaluating%20the%20performance%20of%20the%20NXP%20SD8997%20WiFi%20module%20(SDIO%20interface)%20on%20an%20i.MX6ULL-based%20platform%20running%20Linux%205.4.24%2C%20using%20the%20official%20moal%2Fmlan%20driver%20stack.%20The%20firmware%20in%20use%20is%20sdiouart8997_combo_v4.bin%2C%20version%2016.92.21.p84.4%20(FP92)%2C%20along%20with%20the%20associated%20tx_power_test.bin%20power%20table.%20Firmware%20loads%20correctly%2C%20and%20the%20driver%20reports%20successful%20initialization%20without%20errors.%3C%2FP%3E%3CP%3EHowever%2C%20we%20are%20encountering%20a%20critical%20and%20reproducible%20issue%3A%20when%20operating%20in%205GHz%20STA%20mode%2C%20the%20WiFi%20throughput%20frequently%20drops%20to%20%3CSTRONG%3E0%20Mbps%3C%2FSTRONG%3E%20during%20iperf3%20testing%2C%20even%20in%20stable%20open-air%20environments.%20This%20issue%20significantly%20impacts%20our%20validation%20process%20and%20raises%20concerns%20about%20the%20module%E2%80%99s%20reliability%20in%20real-world%20deployments.%3C%2FP%3E%3CP%3EIn%20our%20test%20setup%2C%20the%20SD8997%20module%20connects%20as%20a%20station%20to%20a%205GHz%20AP%20(HT40%2C%20channel%20161).%20We%20initiate%20standard%20iperf3%20throughput%20tests%20(e.g.%2C%20iperf3%20-c%20%3CAP%20ip%3D%22%22%3E%20-t%2020%20-i%201%20-P%2010)%2C%20during%20which%20multiple%20threads%20consistently%20show%20zero%20throughput%2C%20despite%20minimal%20retransmissions.%20Disabling%20power%20save%20features%20(ps_mode%3D0%2C%20auto_ds%3D0)%20does%20not%20alleviate%20the%20issue.%20Firmware%20initialization%20and%20WLAN%20association%20complete%20successfully%2C%20and%20the%20interface%20transitions%20into%20the%20CONNECTED%20state%20normally.%20The%20problem%20begins%20only%20after%20traffic%20starts%20flowing.%3C%2FAP%3E%3C%2FP%3E%3CP%3EThis%20issue%20is%20currently%20%3CSTRONG%3Eblocking%20our%20development%20progress%3C%2FSTRONG%3E%2C%20as%205GHz%20STA%20stability%20is%20a%20critical%20requirement%20in%20our%20target%20application.%3C%2FP%3E%3CP%3EWe%20kindly%20seek%20your%20urgent%20support%20on%20the%20following%3A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3EIs%20this%20a%20known%20issue%20with%20firmware%20version%2016.92.21.p84.4%20(FP92)%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EWhat%20is%20the%20recommended%20firmware%20and%20driver%20pairing%20for%20Linux%205.4%20platforms%20using%20the%20moal%20stack%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EAre%20there%20known%20firmware-level%20limitations%20in%20STA%20mode%20that%20may%20cause%20Tx%20path%20stall%20or%20data%20flow%20blockage%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EIs%20there%20any%20debug%20firmware%2C%20patch%2C%20or%20recommended%20workaround%20available%20to%20help%20isolate%20or%20resolve%20the%20issue%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3EWe%20are%20happy%20to%20provide%20additional%20test%20data%2C%20full%20dmesg%20logs%2C%20configuration%20files%2C%20or%20conduct%20further%20diagnostic%20testing%20as%20needed.%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20time%20and%20support.%20We%20sincerely%20appreciate%20your%20assistance%20in%20helping%20us%20move%20forward.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EYangguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EYes%2C%20we%20can%20close%20this%20ticket%20as%20the%20issue%20has%20been%20resolved.%3CBR%20%2F%3ENoted%2C%20and%20thank%20you%20for%20the%20support.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EYangYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168468%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168468%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20letting%20me%20know%20your%20plan.%3C%2FP%3E%0A%3CP%3ESo%2C%20Can%20we%20close%20this%20ticket%20for%20now%3F%3C%2FP%3E%0A%3CP%3EAnd%20please%20do%20not%20hesitate%20to%20create%20new%20case%20to%20us%20if%20you%20need%20our%20help.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20support.%3C%2FP%3E%3CP%3EAfter%20internal%20discussion%20and%20evaluation%2C%20we%20decided%20to%20adopt%20the%20following%20measures%20to%20address%20the%20issue%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EUpdated%20to%20the%20latest%20available%20Wi-Fi%20driver%3C%2FSTRONG%3E%2C%20and%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EReduced%20the%20SDIO%20bus%20speed%20to%2050MHz%3C%2FSTRONG%3E.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EWith%20these%20changes%20in%20place%2C%20the%20issue%20is%20no%20longer%20observed%20in%20our%20environment.%3CBR%20%2F%3ECurrently%2C%20%3CSTRONG%3Eno%20further%20testing%20is%20planned%3C%2FSTRONG%3E%20beyond%20this%20scope.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EYangYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167664%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAny%20updates%20on%20our%20requested%20info%3F%3C%2FP%3E%0A%3CP%3EPlease%20help%20to%20provide%20the%20requested%20info%2C%20so%20that%20we%20can%20help%20to%20resolve%20this%20issue%20ASAP.%3C%2FP%3E%0A%3CP%3EThanks.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAny%20updates%20on%20our%20requested%20info%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2165603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2165603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20help%20to%20provide%20below%20info%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3E%26nbsp%3BPlease%20help%20provide%20complete%20DTS%20file.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3EUse%20latest%20available%20release%20and%20help%20get%20the%20sniffer%20traces%20if%20issue%20is%20observed.%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3EAlso%20please%20help%20get%20the%20in-sync%20dmesg%20log.%20%3CSTRONG%3EDo%20not%20use%20any%20drvdbg.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3EWhat%20is%20the%20ext.%20AP%20used%3F%20Can%20we%20get%20the%20ext.%20AP%20model%2FFW%20version%20details%3F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22uiOutputText%22%3EIs%20issue%20observed%20on%20Channel-161%20only%3F%20Can%20you%20check%20the%20issue%20scenario%20on%20other%20channels%20(36%20or%2040%2C%20etc)%20%3F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%20class%3D%22uiOutputText%22%3EBest%20regards%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22uiOutputText%22%3EChristine.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20info.%3C%2FP%3E%0A%3CP%3EYes%2C%20from%20your%20logs%2C%20I%20think%20ADMA%20already%20enabled%20on%20your%20board.%3C%2FP%3E%0A%3CP%3EAnd%20I%20will%20escalated%20this%20issue%20to%20our%20internal%20team%20to%20ask%20help.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EWe%20have%20checked%20the%20logs%2C%20and%20ADMA%20is%20already%20enabled%20on%20our%20platform.%3CBR%20%2F%3EHere%20is%20the%20dmesg%20output%3A%3C%2FP%3E%3CPRE%3E%3CSPAN%3Eroot%40Voice-Gateway%3A~%3CSPAN%20class%3D%22%22%3E%23%20dmesg%20%7C%20grep%20ADMA%3C%2FSPAN%3E%0A%5B%20%20%20%205.808617%5D%20mmc0%3A%20SDHCI%20controller%20on%202190000.usdhc%20%5B2190000.usdhc%5D%20using%20ADMA%0A%5B%20%20%20%205.873090%5D%20mmc1%3A%20SDHCI%20controller%20on%202194000.usdhc%20%5B2194000.usdhc%5D%20using%20ADMA%3C%2FSPAN%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EPlease%20find%20below%20the%20DTS%20configuration%20for%20%3CSTRONG%3Eusdhc1%3C%2FSTRONG%3E%20on%20our%20platform%3A%3C%2FP%3E%3CPRE%3E%3CSPAN%3Eusdhc1%3A%20usdhc%402190000%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22fsl%2Cimx6ul-usdhc%22%2C%20%22fsl%2Cimx6sx-usdhc%22%3B%0A%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0x02190000%200x4000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20interrupts%20%3D%20%3CGIC_SPI%2022%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%0A%20%20%20%20%20%20%20%20clocks%20%3D%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1%26gt%3B%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1%26gt%3B%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20clock-names%20%3D%20%22ipg%22%2C%20%22ahb%22%2C%20%22per%22%3B%0A%20%20%20%20%20%20%20%20fsl%2Ctuning-step%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20fsl%2Ctuning-start-tap%20%3D%20%26lt%3B20%26gt%3B%3B%0A%20%20%20%20%20%20%20%20bus-width%20%3D%20%26lt%3B4%26gt%3B%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22disabled%22%3B%0A%7D%3B%0A%0A%26amp%3Busdhc1%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22fsl%2Cimx6ull-usdhc%22%2C%20%22fsl%2Cimx6sx-usdhc%22%3B%0A%20%20%20%20%20%20%20%20assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1_SEL%26gt%3B%2C%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_USDHC1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20assigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bclks%20IMX6UL_CLK_PLL2_PFD2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20assigned-clock-rates%20%3D%20%26lt%3B0%26gt%3B%2C%20%26lt%3B132000000%26gt%3B%3B%0A%7D%3B%0A%0Afragment%401%20%7B%0A%20%20%20%20%20%20%20%20target%20%3D%20%26lt%3B%26amp%3Busdhc1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20__overlay__%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-names%20%3D%20%22default%22%2C%20%22state_100mhz%22%2C%20%22state_200mhz%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc1_100mhz%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20pinctrl-2%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc1_200mhz%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20non-removable%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20keep-power-in-suspend%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20wakeup-source%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20fsl%2Csdio-interrupt-enabled%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%7D%3B%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3EPlease%20confirm%20if%20this%20matches%20the%20requirements%20for%20enabling%20ADMA%20on%20%3CSTRONG%3EUSDHC1%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EYangyaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E1.Can%20you%20please%20share%20the%20dts%20file%20to%20me%3F%3C%2FP%3E%0A%3CP%3ETo%20save%20your%20project%20info%2C%20you%20can%20sent%20it%20to%20my%20email%3Achristine.li%40nxp.com.%3C%2FP%3E%0A%3CP%3E2.To%20enable%20the%20ADMA%2C%20you%20need%20add%20below%20line%20in%20dts%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3C!--ScriptorStartFragment--%3Edma-coherent%3B%3C!--ScriptorEndFragment--%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3.To%20check%20whether%20ADMA%20has%20been%20enabled%2C%20you%20can%20check%20the%20dmesg(from%20device%20boot-up)%2C%26nbsp%3B%3C!--ScriptorStartFragment--%3Edmesg%20%7C%20grep%20usdhc%3C!--ScriptorEndFragment--%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%3E%3CCODE%3Emmc0%3A%20SDHCI%20controller%20on%2030b40000.usdhc%20%5B30b40000.usdhc%5D%20using%20ADMA%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3ERegarding%20your%20first%20point%3A%3CBR%20%2F%3EWe%20can%20confirm%20that%20%3CSTRONG%3Ethere%20was%20no%20manual%20intervention%20during%20the%20entire%20test%3C%2FSTRONG%3E.%3CBR%20%2F%3EFrom%20the%20logs%2C%20it%20seems%20like%20the%20Wi-Fi%20connection%20is%20%3CSTRONG%3Eautomatically%20disconnecting%20and%20reconnecting%3C%2FSTRONG%3E.%3CBR%20%2F%3E(Our%20product%20is%20designed%20to%20%3CSTRONG%3Etrigger%20a%20reconnect%3C%2FSTRONG%3E%20if%20an%20abnormal%20disconnection%20is%20detected.)%3CBR%20%2F%3EIf%20it%E2%80%99s%20just%20a%20%3CSTRONG%3Eshort-term%20reconnection%3C%2FSTRONG%3E%2C%20this%20may%20be%20acceptable%20from%20our%20product%20perspective.%3C%2FP%3E%3CP%3EFor%20point%20%3CSTRONG%3E2%3C%2FSTRONG%3E%20and%20%3CSTRONG%3E3%3C%2FSTRONG%3E%2C%20we%20have%20already%20conducted%20experiments%20by%20disabling%20power%20saving%20mode%20and%20auto%20deep%20sleep%20mode%20on%20both%20the%20device%20and%20the%20host%2C%20but%20unfortunately%20%3CSTRONG%3Eit%20didn%E2%80%99t%20have%20a%20significant%20impact%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3EFor%20point%20%3CSTRONG%3E4%3C%2FSTRONG%3E%2C%20we%20would%20like%20to%20know%20%3CSTRONG%3Ehow%20to%20configure%20SDIO%20to%20switch%20from%20DMA%20mode%20to%20ADMA%20mode%3C%2FSTRONG%3E.%3CBR%20%2F%3EWe%E2%80%99d%20like%20to%20try%20this%20approach%20to%20see%20if%20it%20improves%20the%20stability.%3C%2FP%3E%3CP%3EAs%20a%20temporary%20solution%2C%20we%20have%20%3CSTRONG%3Ereduced%20the%20SDIO%20speed%20to%2050%E2%80%AFMHz%3C%2FSTRONG%3E%20and%20%3CSTRONG%3Eupdated%20the%20driver%3C%2FSTRONG%3E%20to%20address%20the%20current%20issue.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EYang%20Yaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E1.When%20the%20iperf%205G%20throughput%20drops%20to%200Mbps%2C%20does%20the%20connection%20between%20AP%20and%20STA%20is%20still%20there%3F%20Or%20disconnected%3F%3C%2FP%3E%0A%3CP%3EI%20seen%20below%20info%20in%20logs%2C%20but%20I%20am%20not%20sure%20the%20disconnection%20is%20triggered%20automatically%20or%20you%20trigger%20it%20manually.%3C%2FP%3E%0A%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%0A%3CP%3E%5B41972.636502%5D%20wlan%3A%20Received%20disassociation%20request%20on%20wlan0%2C%20reason%3A%203%3CBR%20%2F%3E%5B41972.677171%5D%20wlan%3A%20REASON%3A%20(Deauth)%20Sending%20STA%20is%20leaving%20(or%20has%20left)%20IBSS%20or%20ESS%3CBR%20%2F%3E%5B41972.716536%5D%20Already%20disconnected%3C%2FP%3E%0A%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%0A%3CP%3E2.%20Please%20have%20a%20try%20with%20below%20para%20in%20wifi_mod_para.conf%2C%20to%20disable%20power%20saving%20mode%20and%20auto%20deep%20sleep%20mode.%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3E%3CSTRONG%3E%20ps_mode%3D2%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E%20auto_ds%3D2%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E3.%20If%20on%20your%20host%20side%2C%20there%20is%20any%20power%20saving%20related%20configurations%2C%20please%20also%20turn%20it%20off.%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E4.%20I%20checked%20our%20internal%20case%2C%20other%20customer%20meet%20this%20kind%20of%20issue%20when%20their%20SDIO%20is%20using%20DMA%20mode%2C%20if%20changing%20to%20ADMA%20mode%2C%20it%20will%20be%20ok.%20You%20can%20also%20check%20this%20point.%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156446%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156446%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EOn%20our%20i.MX6ULL%20platform%2C%20keeping%20the%20SDIO%20clock%20at%20100%E2%80%AFMHz%20tends%20to%20trigger%20throughput%20drops%20to%200%20Mbps%20more%20frequently%20during%20long-term%20iperf3%20tests.%3C%2FP%3E%3CP%3EIn%20fact%2C%20during%20parallel%20testing%20on%20our%20another%20product%20line%20using%20the%20i.MX8%20platform%2C%20running%20at%20100%E2%80%AFMHz%20SDIO%20clock%20also%20led%20to%20CMD53%20errors%20after%203%E2%80%935%20hours%20of%20continuous%20stress.%20Only%20reducing%20the%20clock%20to%2050%E2%80%AFMHz%20resulted%20in%20stable%20operation%2C%20though%20with%20slightly%20lower%20throughput.%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22478%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yangyaoguang_0-1755832598173.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yangyaoguang_0-1755832598173.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F353603i83A6234E965C3664%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yangyaoguang_0-1755832598173.png%22%20alt%3D%22yangyaoguang_0-1755832598173.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CP%3E5.4.70-imx8mp%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3EThe%20issue%20seems%20to%20involve%20both%20the%20Wi-Fi%20driver%20and%20the%20SDIO%20clock%20speed.%20Do%20you%20have%20any%20further%20insights%20or%20suggestions%3F%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EYangyaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156436%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E1.If%20you%20keep%20the%26nbsp%3B%3CSTRONG%3Emaximum%20SDIO%20interface%20clock%20frequency%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3Bfor%20the%20Wi-Fi%20module%20to%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E100MHz%2C%20whether%20can%20meet%20you%20requirement%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EI%20noticed%20that%20when%20you%20reduced%20it%20to%2050MHz%2C%26nbsp%3Bthe%26nbsp%3Boverall%20Wi-Fi%20performance%20also%20%3CSTRONG%3Eslightly%3C%2FSTRONG%3E%20dropped.%3C%2FP%3E%0A%3CP%3E2.And%20also%2C%20you%20have%20changed%20to%20%3CSTRONG%3Eother%20AP(not%2088W8997)%20right%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E3.Which%20module%20are%20you%20using%3F%20AW-CM276MA-SUR%20from%20AzureWave%3F%3C%2FP%3E%0A%3CP%3EI%20don't%20have%20SD-UART%20module%20of%2088W8997%20on%20my%20hand%2C%20otherwise%2C%20I%20can%20try%20to%20test%20locally%20with%20I.MX6ULL-EVK.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EThanks%20for%20the%20follow-up.%3C%2FP%3E%3CP%3EWe%E2%80%99ve%20tried%20adjusting%20the%20%3CSTRONG%3Emaximum%20SDIO%20interface%20clock%20frequency%3C%2FSTRONG%3E%20for%20the%20Wi-Fi%20module.%20Specifically%2C%20we%20reduced%20it%20from%20%3CSTRONG%3E100%E2%80%93200%E2%80%AFMHz%3C%2FSTRONG%3E%20down%20to%20%3CSTRONG%3E50%E2%80%AFMHz%3C%2FSTRONG%3E.%20After%20this%20change%2C%20we%20observed%20that%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EThe%20probability%20of%20Wi-Fi%20throughput%20%3CSTRONG%3Edropping%20to%200%20Mbps%3C%2FSTRONG%3E%20appears%20to%20have%20decreased.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EHowever%2C%20the%20%3CSTRONG%3Eoverall%20Wi-Fi%20performance%20also%20slightly%20dropped%3C%2FSTRONG%3E%2C%20likely%20due%20to%20the%20reduced%20SDIO%20bandwidth.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EWe%E2%80%99d%20like%20to%20check%20if%20you%20have%20any%20%3CSTRONG%3Efurther%20suggestions%3C%2FSTRONG%3E%20for%20tuning%20or%20improving%20stability%20%3CSTRONG%3Ewithout%20significantly%20reducing%20throughput%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3ELooking%20forward%20to%20your%20guidance.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHow%20is%20your%20test%3F%3C%2FP%3E%0A%3CP%3EAnything%20else%20I%20can%20do%20for%20this%20case%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHow%20is%20your%20test%3F%3C%2FP%3E%0A%3CP%3EAnything%20else%20I%20can%20do%20for%20this%20case%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EThanks%20for%20the%20clarification%20and%20suggestion.%3C%2FP%3E%3CP%3EI%E2%80%99ve%20created%20a%20new%20case%20to%20track%20this%20in-band%20reset%20recovery%20issue%20separately%2C%20as%20recommended.%3CBR%20%2F%3EHere%20is%20the%20link%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FSD8997-Wi-Fi-Fails-to-Recover-After-In-Band-Reset-Triggered-by%2Fm-p%2F2152650%2Fhighlight%2Ffalse%23M29696%22%20target%3D%22_new%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FSD8997-Wi-Fi-Fails-to-Recover-After-In-Band-Reset-Triggered-by%2Fm-p%2F2152650%2Fhighlight%2Ffalse%23M29696%3C%2FA%3E%3C%2FP%3E%3CP%3EWe%E2%80%99ll%20continue%20to%20follow%20the%20original%20throughput%20drop%20issue%20in%20this%20thread.%3C%2FP%3E%3CP%3EThanks%20again%20for%20your%20support.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3E%3CSTRONG%3EYaoguang%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThis%20is%20a%20new%20issue.%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20help%20to%20create%20a%20new%20case%20to%20discuss%20this%20issue%3F%3C%2FP%3E%0A%3CP%3EWe%20always%20recommend%20our%20customer%20to%20follow%20different%20issue%20with%20different%20case%20so%20that%20we%20can%20better%20track%20the%20issue%20root%20cause%20and%20solution%20for%20future%20reference.%3C%2FP%3E%0A%3CP%3EAnd%20for%20your%20information%2C%20this%20issue%20is%20related%20to%20FW%20reset%2C%20it%20might%20need%20our%20internal%20SAE%20team's%20help%20for%20tracking%20root%20cause.%20In%20other%20words%2C%20it%20will%20take%20longer%20time%20for%20global%20communications.%20Please%20pay%20more%20patient%20about%20this.%3C%2FP%3E%0A%3CP%3ELet's%20keep%20tracking%20the%20original%20dropping%20to%200%20issue%20in%20this%20thread.%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20understandings!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20continued%20support%20on%20the%20%3CSTRONG%3E5GHz%20STA%20throughput%20dropping%20to%200%20Mbps%3C%2FSTRONG%3E%20issue.%3C%2FP%3E%3CP%3EDuring%20%3CSTRONG%3Eongoing%20stability%20and%20repeated%20reconnection%20testing%3C%2FSTRONG%3E%2C%20we%E2%80%99ve%20discovered%20a%20%3CSTRONG%3Enew%20problem%3C%2FSTRONG%3E%3A%3C%2FP%3E%3CP%3EAfter%20multiple%20EAPOL%20timeouts%2C%20the%20driver%20triggers%20an%20%3CSTRONG%3Ein-band%20reset%3C%2FSTRONG%3E%2C%20but%20the%20firmware%20then%20%3CSTRONG%3Efails%20to%20reload%20via%20SDIO%3C%2FSTRONG%3E%2C%20leaving%20Wi-Fi%20in%20a%20non-functional%20state%20until%20reboot.%3C%2FP%3E%3CP%3EThis%20issue%20seems%20to%20occur%20only%20after%20repeated%20connection%20failures.%20It%20may%20be%20related%20to%20how%20the%20firmware%20or%20SDIO%20interface%20handles%20recovery%20after%20in-band%20resets.%3C%2FP%3E%3CP%3EHere%20is%20the%20relevant%20dmesg%20log%3A%3C%2FP%3E%3CPRE%3E%3CSPAN%3E%5B%3CSPAN%20class%3D%22%22%3E87697.429777%3C%2FSPAN%3E%5D%20WiFi%20Reset%20due%20to%20EAPOL%20timeout%20cnt%20%3CSPAN%20class%3D%22%22%3E5%3C%2FSPAN%3E%0A%5B%3CSPAN%20class%3D%22%22%3E87697.499968%3C%2FSPAN%3E%5D%20%3D%3D%3D%3D%3D%3D%3D%3DSTART%20IN-BAND%20RESET%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0A%5B%3CSPAN%20class%3D%22%22%3E87704.130302%3C%2FSPAN%3E%5D%20wlan_sdio_poll_card_status%20failed%2C%20tries%20%3D%20%3CSPAN%20class%3D%22%22%3E10000%3C%2FSPAN%3E%2C%20cs%20%3D%20%3CSPAN%20class%3D%22%22%3E0xc%3C%2FSPAN%3E%0A%5B%3CSPAN%20class%3D%22%22%3E87704.259872%3C%2FSPAN%3E%5D%20wlan_dnld_fw%20fail%20ret%3D%3CSPAN%20class%3D%22%22%3E0xffffffff%3C%2FSPAN%3E%0A%5B%3CSPAN%20class%3D%22%22%3E87705.481337%3C%2FSPAN%3E%5D%20woal_request_fw%20failed%0A%5B%3CSPAN%20class%3D%22%22%3E87705.484769%3C%2FSPAN%3E%5D%20Firmware%20Init%20Failed%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3ECould%20you%20please%20confirm%20whether%20this%20is%20a%20known%20issue%2C%20and%20if%20there%20is%20any%20workaround%20or%20firmware%20update%20available%3F%3C%2FP%3E%3CP%3EThanks%20again%20for%20your%20support.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20support.%20I%E2%80%99ll%20keep%20you%20posted%20if%20we%20find%20any%20other%20issues.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20feedback.%3C%2FP%3E%0A%3CP%3ESure%2C%20let's%20keep%20touching%20on%20this%20case.%20If%20anything%20need%20from%20my%20side%2C%20please%20do%20not%20hesitate%20to%20let%20me%20know.%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20efforts.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EWe%20are%20still%20conducting%20ongoing%20tests%20on%20the%20%3CSTRONG%3ESD8997%20WiFi%20Module%20%E2%80%94%205%20GHz%20STA%20throughput%20frequently%20dropping%20to%200%20Mbps%20during%20iperf3%20testing%3C%2FSTRONG%3E.%3CBR%20%2F%3ESo%20far%2C%20we%20have%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EUpdated%20the%20driver%20and%20firmware%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ETuned%20the%20%3CSTRONG%3ESDIO%20max%20frequency%3C%2FSTRONG%3E%20in%20the%20DTS%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EThese%20changes%20appear%20to%20help%20%E2%80%94%20the%20probability%20of%20throughput%20dropping%20to%200%20Mbps%20has%20decreased.%20We%E2%80%99ll%20keep%20testing%20and%20share%20more%20data%20as%20we%20collect%20it.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAny%20updates%20on%20this%20case%3F%3C%2FP%3E%0A%3CP%3EIf%20you%20did%20any%20experiment%20or%20test%20related%20to%20this%20thread%2C%20please%20share%20me%20your%20information.%20So%20that%20we%20can%20keep%20moving%20forward%20on%20this%20thread.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks.%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAny%20updates%20on%20this%20case%3F%3C%2FP%3E%0A%3CP%3EIf%20you%20did%20any%20experiment%20or%20test%20related%20to%20this%20thread%2C%20please%20share%20me%20your%20information.%20So%20that%20we%20can%20keep%20moving%20forward%20on%20this%20thread.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks.%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20detailed%20response%20and%20suggestions.%3C%2FP%3E%3CP%3EWe%20will%20first%20try%20the%20alternative%20test%20method%20by%20switching%20to%20another%20AP%2C%20and%20review%20the%20reference%20materials%20you%20provided.%20Hopefully%2C%20this%20will%20help%20us%20better%20understand%20and%20address%20the%20issue.%3C%2FP%3E%3CP%3EThanks%20again%20for%20your%20support!%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Christine%2C%3C%2FP%3E%3CP%3ENo%2C%20we%20were%20only%20using%20the%20Wi-Fi%20interface%20of%20the%20SD8997%20during%20the%20performance%20test.%20Bluetooth%20was%20not%20enabled.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EYaoguang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHave%20you%20test%20with%20other%20AP%3F%20For%20example%2C%20SD8997%20works%20in%20STA%20mode%2C%20and%20connects%20to%20another%20AP(Not%20using%20SD8997).%20In%20this%20way%2C%20can%20you%20still%20reproduce%20this%20issue%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CP%3EAre%20there%20any%20known%20issues%20in%20STA%20mode%20under%20high-concurrency%20traffic%20with%20the%20current%20firmware%2Fdriver%20version%3F%26nbsp%3B%20%3D%3D%26gt%3BNo.%20As%20I%20know%2C%20until%20now%2C%20we%20do%20not%20receive%20other%20customers%20report%20this%20issue%20with%20the%20latest%20FW.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EIs%20there%20a%20debug%20version%20of%20the%20firmware%20that%20enables%20more%20detailed%20logging%20or%20assert%20tracing%3F%20%3D%3D%26gt%3B%20you%20can%20add%20below%20parameter%20when%20loading%20Wi-Fi%20driver%20to%20enable%20more%20driver%20logs.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Arial%3B%20font-size%3A%2014.0pt%3B%20color%3A%20black%3B%22%20lang%3D%22en-US%22%3E%3CSPAN%3Edrvdbg%26nbsp%3B%3D%26nbsp%3B0x20037%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EAre%20there%20any%20available%20patches%20or%20kernel-side%20workarounds%20(e.g.%2C%20flow%20control%20tuning%2C%20SDIO%20IRQ%20coalescing)%3F%20%3D%3D%26gt%3BNo%2C%20as%20we%20didn't%20receive%20this%20kind%20of%20issue%20on%20the%20latest%20FW%2C%20we%20do%20not%20have%20patches%20workarounds.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3EFor%20throughput%20performance%20tunning%2C%20maybe%20this%20link%20can%20help%20you%20somehow%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FRM00297%2Fpage%2Fconnectivity-features%2Ftopics%2Fthroughput_performance_tuning.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FRM00297%2Fpage%2Fconnectivity-features%2Ftopics%2Fthroughput_performance_tuning.html%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EFor%20the%20issue%20you%20reported%2C%20I%20will%20continue%20to%20debug%20and%20try%20to%20test%20locally%20to%20see%20whether%20can%20reproduce%20it.%3C%2FP%3E%0A%3CP%3EThe%20dmesg%20you%20provided%20was%20null%2C%20please%20help%20to%20provide%20me%20again.%20Thanks.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Christine%2C%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20previous%20response%20and%20for%20providing%20the%20updated%20firmware%20and%20driver%20resources.%3C%2FP%3E%3CP%3EWe%20have%20now%20successfully%20upgraded%20to%20the%20following%20versions%20as%20per%20your%20recommendation%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EFirmware%3C%2FSTRONG%3E%3A%20%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%26nbsp%3B-b%20lf-6.12.20-2.0.0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EDriver%3C%2FSTRONG%3E%3A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmwifiex.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmwifiex.git%3C%2FA%3E%3CSPAN%3E%26nbsp%3B-b%20lf-6.12.20-2.0.0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EAfter%20applying%20these%20updates%2C%20we%20reran%20our%205GHz%20STA%20performance%20tests%20using%20iperf3%20with%2010%20parallel%20streams%20(-P%2010).%20Unfortunately%2C%20the%20issue%20still%20persists%20%E2%80%94%20%3CSTRONG%3Emultiple%20iperf3%20threads%20report%200.00%20bits%2Fsec%20throughput%20for%20prolonged%20periods%3C%2FSTRONG%3E%2C%20as%20shown%20in%20the%20attached%20log.%20This%20behavior%20occurs%20even%20in%20a%20stable%20test%20environment%20with%20minimal%20retransmissions%20and%20power-saving%20features%20disabled%20(ps_mode%3D0%2C%20auto_ds%3D0).%3C%2FP%3E%3CP%3EThis%20pattern%20suggests%20a%20possible%20%3CSTRONG%3ETx%20path%20stall%20or%20queue%20starvation%20issue%3C%2FSTRONG%3E%2C%20potentially%20at%20the%20firmware%20or%20SDIO%20transport%20layer%2C%20despite%20successful%20association%20and%20initialization.%3C%2FP%3E%3CP%3EWe%20would%20greatly%20appreciate%20your%20kind%20support%20on%20the%20following%20points%3A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3EAre%20there%20any%20known%20issues%20in%20STA%20mode%20under%20high-concurrency%20traffic%20with%20the%20current%20firmware%2Fdriver%20version%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EIs%20there%20a%20debug%20version%20of%20the%20firmware%20that%20enables%20more%20detailed%20logging%20or%20assert%20tracing%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EAre%20there%20any%20available%20patches%20or%20kernel-side%20workarounds%20(e.g.%2C%20flow%20control%20tuning%2C%20SDIO%20IRQ%20coalescing)%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3EWe%20remain%20at%20your%20disposal%20to%20provide%20complete%20dmesg%20logs%2C%20module%20load%20parameters%2C%20or%20additional%20diagnostics%20as%20needed.%3C%2FP%3E%3CP%3EThank%20you%20again%20for%20your%20continued%20assistance%20and%20support.%20We%20truly%20appreciate%20your%20help%20in%20resolving%20this%20issue.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3E%3CSTRONG%3EYaoguang%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3EThe%20attachment%20contains%20the%20full%20test%20log%2C%20including%20dmesg%20output%2C%20iperf3%20throughput%20results%2C%20and%20Wi-Fi%20configuration%20details%2C%20with%20the%20driver%20loaded%20via%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf.%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F216219%22%20target%3D%22_blank%22%3E%40yangyaoguang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20creating%20case%20to%20us.%3C%2FP%3E%0A%3CP%3EI%20saw%20you%20are%20using%20an%20old%20FW%20which%20is%20released%20on%26nbsp%3B%3CSPAN%3EDec%2014%2C%202023.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EWould%20you%20please%20help%20to%20try%20with%20our%20latest%20FW%20and%20driver%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EPlease%20see%20below%20for%20getting%20latest%20FW%20and%20driver.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CH4%20class%3D%22title-and-elements%22%20id%3D%22toc-hId-175886418%22%20id%3D%22toc-hId-202816464%22%3EFor%20FW%3A%3C%2FH4%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CFONT%20size%3D%224%22%3E%3CSPAN%3E%23%20git%20clone%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fimx-firmware.git%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%20-b%20lf-6.12.20-2.0.0%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CFONT%20size%3D%224%22%3E%23%20cd%20imx-firmware%2Fnxp%2F%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3EFor%20driver%3A%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%23%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmwifiex.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmwifiex.git%3C%2FA%3E%20-b%20lf-6.12.20-2.0.0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20'Microsoft%20YaHei'%3B%20font-size%3A%2011.0pt%3B%22%3E%23%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIf%20still%20have%20same%20problem%2C%20please%20let%20me%20know%20and%20provide%20us%20wifi%20driver%20load%20parameters%2C%20dmesg%20logs.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BURGENT%5D%20SD8997%20WiFi%20Module%20%E2%80%94%205GHz%20STA%20Throughput%20Frequently%20Drops%20to%200%20Mbps%20During%20iperf3%20Testi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH4%20id%3D%22toc-hId-175861344%22%20id%3D%22toc-hId--1604637999%22%3E%3CSTRONG%3EPlatform%20Details%3A%3C%2FSTRONG%3E%3C%2FH4%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ESoC%3C%2FSTRONG%3E%3A%20NXP%20i.MX6ULL%20(ARMv7)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EKernel%3C%2FSTRONG%3E%3A%20Linux%205.4.24-imx6ull%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EWiFi%20Module%3C%2FSTRONG%3E%3A%20NXP%20SD8997%20(SDIO%20interface)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EDriver%20Stack%3C%2FSTRONG%3E%3A%20moal%2Fmlan%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EFirmware%3C%2FSTRONG%3E%3A%20sdiouart8997_combo_v4.bin%3CBR%20%2F%3E%E2%86%92%20Version%3A%2016.92.21.p84.4%20(FP92)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EPower%20Table%3C%2FSTRONG%3E%3A%20tx_power_test.bin%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EWiFi%20Mode%3C%2FSTRONG%3E%3A%20STA%20(client%20mode%20only)ps_mode%3D0%3CBR%20%2F%3Eauto_ds%3D0%3CBR%20%2F%3Efw_name%3Dnxp%2Fsdiouart8997_combo_v4.bin%3CBR%20%2F%3Etxpwrlimit_cfg%3Dnxp%2Ftx_power_test.bin%3CBR%20%2F%3Edrv_mode%3D3%3CBR%20%2F%3Esta_name%3Dwlan%3CBR%20%2F%3Ecfg80211_wext%3D0xf%3C%2FP%3E%3CH3%20id%3D%22toc-hId-165358240%22%20id%3D%22toc-hId--1615141103%22%3E%3CSTRONG%3ETest%20Setup%20and%20Procedure%3A%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ESTA%3C%2FSTRONG%3E%20(SD8997)%20%E2%86%90%E2%86%92%20%3CSTRONG%3EAP%3C%2FSTRONG%3E%20(SD8997)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EChannel%3A%20%3CSTRONG%3E5GHz%3C%2FSTRONG%3E%2C%20HT40%2C%20CH161%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EEnvironment%3A%20%3CSTRONG%3Enon-shielded%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ETool%3A%20iperf3%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EServer%3A%20iperf3%20-s%20-p%207777%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EClient%3A%20iperf3%20-c%20%3CAP%20ip%3D%22%22%3E%20-t%2020%20-i%201%20-P%2010%3C%2FAP%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E
