Trouble implementing ios app using Taplinx SDK
3,536 次查看
DamianD
Hi, i'm trying to follow UG10045.pdf - Starting development with TapLinx iOS SDK. Below is excerpt from that guide:
3.4 Implementing the delegate method for APDU communication
To communicate with the TapLinx iOS Library and the Tag (or Card), a delegate method which is created inside
the MIFAREApduHandler must be implemented in your class. Below is the delegate method.
However i do not understand where i should implement that TapLinxApduHandlerProtocol, on what class? Where/how should i pass my class to something in Taplinx SDK to indicate where i implemented that hander? Is there a ios sample app like for Android? It would be very helpful. In case there is no such app, could someone share a code sample with full sdk initialization on ios?
标记 (1)
3,313 次查看
KaiLi
Hello @DamianD
Since your problem involves the level of code debugging, we do not have such a test environment as yours, so your problem needs to be debugged by you, say sorry for that.
4 回复数
3,435 次查看
DamianD
hi @KaiLi  - unfortunately there is only swiftsourceinfo file inside Project folder and it is of no use to me. When i add libTapLinxLibrary.a to xcode app project (and set up search paths) during compilation i get error:
/Users/xxx/Projects/xcodeproj/facilityapp/SampleTaplinxApp/SampleTaplinxApp/ContentView.swift:9:8 Compiled module was created by a different version of the compiler '5.10.0.13'; rebuild 'TapLinxLibrary' and try again: /Users/xxx/Projects/xcodeproj/facilityapp/SampleTaplinxApp/TapLinxLibrary2/TapLinxLibrary.swiftmodule/arm64-apple-ios.swiftmodule\
Could you hint me at what to do?
3,314 次查看
KaiLi
Hello @DamianD
3,492 次查看
DamianD
thanks, i will give it a try and let you know
3,507 次查看
KaiLi
Hello @DamianD
Unfortunately, there is not the dedicated sample for ios, but I think there should be something in SDK could refer to, like
sdk_TapLinx_Library_iOS\TapLinxv1.0.1\TapLinxiOSSDK\TapLinxiOSSDK\TapLinxLibrary\TapLinxLibrary.swiftmodule\Project.
Please try it.
%3CLINGO-SUB%20id%3D%22lingo-sub-1974526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20Taplinx%20SDK%20%E5%AE%9E%E7%8E%B0%20iOS%20%E5%BA%94%E7%94%A8%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1974526%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E9%81%B5%E5%BE%AA%20UG10045.pdf%20-%20%E4%BD%BF%E7%94%A8%20TapLinx%20iOS%20SDK%20%E5%BC%80%E5%A7%8B%E5%BC%80%E5%8F%91%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E8%AF%A5%E6%8C%87%E5%8D%97%E7%9A%84%E6%91%98%E5%BD%95%EF%BC%9A%3C%2FP%3E%3CP%3E3.4%20%E5%AE%9E%E7%8E%B0APDU%E9%80%9A%E4%BF%A1%E7%9A%84%E5%A7%94%E6%89%98%E6%96%B9%E6%B3%95%3CBR%20%2F%3E%E4%B8%BA%E4%BA%86%E4%B8%8E%20TapLinx%20iOS%20%E5%BA%93%E5%92%8C%E6%A0%87%E7%AD%BE%EF%BC%88%E6%88%96%E5%8D%A1%EF%BC%89%E8%BF%9B%E8%A1%8C%E9%80%9A%E4%BF%A1%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%E5%86%85%E9%83%A8%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%A7%94%E6%89%98%E6%96%B9%E6%B3%95%3CBR%20%2F%3E%E6%82%A8%E7%9A%84%E7%B1%BB%E4%B8%AD%E5%BF%85%E9%A1%BB%E5%AE%9E%E7%8E%B0%20MIFAREpduHandler%E3%80%82%E4%B8%8B%E9%9D%A2%E6%98%AF%E5%A7%94%E6%89%98%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E5%AE%9E%E7%8E%B0%20TapLinxApduHandlerProtocol%EF%BC%8C%E5%9C%A8%E5%93%AA%E4%B8%AA%E7%B1%BB%E4%B8%8A%EF%BC%9F%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%93%AA%E9%87%8C%2F%E5%A6%82%E4%BD%95%E5%B0%86%E6%88%91%E7%9A%84%E7%B1%BB%E4%BC%A0%E9%80%92%E7%BB%99%20Taplinx%20SDK%20%E4%B8%AD%E7%9A%84%E6%9F%90%E4%B8%AA%E4%B8%9C%E8%A5%BF%E6%9D%A5%E6%8C%87%E7%A4%BA%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%AE%9E%E7%8E%B0%E4%BA%86%E8%AF%A5%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%EF%BC%9F%E6%98%AF%E5%90%A6%E6%9C%89%E7%B1%BB%E4%BC%BC%20Android%20%E7%9A%84%20iOS%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%E8%BF%99%E5%B0%86%E4%BC%9A%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%9C%89%E4%BA%BA%E5%8F%AF%E4%BB%A5%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%AA%E5%9C%A8%20ios%20%E4%B8%8A%E5%85%B7%E6%9C%89%E5%AE%8C%E6%95%B4%20sdk%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Taplinx%20SDK%20%E5%AE%9E%E7%8E%B0%20iOS%20%E5%BA%94%E7%94%A8%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242019%22%20target%3D%22_blank%22%3E%40DamianD%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E6%B6%89%E5%8F%8A%E5%88%B0%E4%BB%A3%E7%A0%81%E8%B0%83%E8%AF%95%E5%B1%82%E9%9D%A2%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E6%82%A8%E8%BF%99%E6%A0%B7%E7%9A%84%E6%B5%8B%E8%AF%95%E7%8E%AF%E5%A2%83%EF%BC%8C%E6%89%80%E4%BB%A5%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E9%9C%80%E8%A6%81%E6%82%A8%E8%87%AA%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E5%AF%B9%E6%AD%A4%E6%88%91%E4%BB%AC%E6%B7%B1%E6%84%9F%E6%8A%B1%E6%AD%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Taplinx%20SDK%20%E5%AE%9E%E7%8E%B0%20iOS%20%E5%BA%94%E7%94%A8%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205266%22%20target%3D%22_blank%22%3E%40KaiLi%3C%2FA%3E%20-%20%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E5%8F%AA%E6%9C%89%20swiftsourceinfo%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%AE%83%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E6%B2%A1%E7%94%A8%E3%80%82%E5%BD%93%E6%88%91%E5%9C%A8%E7%BC%96%E8%AF%91%E6%9C%9F%E9%97%B4%E5%B0%86%20libTapLinxLibrary.a%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20xcode%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%EF%BC%88%E5%B9%B6%E8%AE%BE%E7%BD%AE%E6%90%9C%E7%B4%A2%E8%B7%AF%E5%BE%84%EF%BC%89%E6%97%B6%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%EF%BC%9A%3CBR%20%2F%3E%20%2F%E7%94%A8%E6%88%B7%2Fxxx%2F%E9%A1%B9%E7%9B%AE%2Fxcodeproj%2Ffacilityapp%2FSampleTaplinxApp%2FSampleTaplinxApp%2FContentView.swift%3A9%3A8%E7%BC%96%E8%AF%91%E6%A8%A1%E5%9D%97%E6%98%AF%E7%94%B1%E4%B8%8D%E5%90%8C%E7%89%88%E6%9C%AC%E7%9A%84%E7%BC%96%E8%AF%91%E5%99%A8%E2%80%9C5.10.0.13%E2%80%9D%E5%88%9B%E5%BB%BA%E7%9A%84%EF%BC%9B%E9%87%8D%E5%BB%BA%E2%80%9CTapLinxLibrary%E2%80%9D%E5%B9%B6%E9%87%8D%E8%AF%95%EF%BC%9A%2FUsers%2Fxxx%2FProjects%2Fxcodeproj%2Ffacilityapp%2FSampleTaplinxApp%2FTapLinxLibrary2%2FTapLinxLibrary.swiftmodule%2Farm64-apple-ios.swiftmodule%5C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E8%83%BD%E6%8F%90%E7%A4%BA%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1977032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Taplinx%20SDK%20%E5%AE%9E%E7%8E%B0%20iOS%20%E5%BA%94%E7%94%A8%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E5%B9%B6%E5%91%8A%E8%AF%89%E4%BD%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1975885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20Taplinx%20SDK%20%E5%AE%9E%E7%8E%B0%20iOS%20%E5%BA%94%E7%94%A8%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1975885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242019%22%20target%3D%22_blank%22%3E%40DamianD%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%B8%93%E9%97%A8%E9%92%88%E5%AF%B9%20iOS%20%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%20SDK%20%E4%B8%AD%E5%BA%94%E8%AF%A5%E6%9C%89%E4%B8%80%E4%BA%9B%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E7%9A%84%E4%B8%9C%E8%A5%BF%EF%BC%8C%E6%AF%94%E5%A6%82%3C%2FP%3E%0A%3CP%3Esdk_TapLinx_Library_iOS%5CTapLinxv1.0.1%5CTapLinxiOSSDK%5CTapLinxiOSSDK%5CTapLinxLibrary%5CTapLinxLibrary.swiftmodule%5C%E9%A1%B9%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
