The debugger to work with NXP Processors
3,315 次查看
kumar_086
Dear NXP Team,
We are having the custom boards housing multiple variants of NXP Processors namely, MPC864x, QorIQ T/P series, Layerscape series. Can you recommend a common debugger which can work with all the processor architectures?
Checked the CW-TAP - https://www.nxp.com/design/design-center/development-boards-and-designs/CW_TAP - but its not having the MPC864x and QorIQ P-series as per the supported devices list shown.
标记 (1)
7 回复数
3,285 次查看
Oswalag
the CW TAP (CWH-CTP-BASE-HE) supports all the mentioned processors.
BR,
3,274 次查看
kumar_086
Thanks for your reply.
Based on the link - https://www.nxp.com/design/design-center/development-boards-and-designs/CW_TAP : the PPC - MPC864x series like MPC8640/MPC8641 is not shown on the page. Can you clarify on this processor set?
标记 (1)
3,257 次查看
Oswalag
It isn't mentioned but the USB TAP CWH-CTP-BASE-HE with CWH-CTP-COP-YE Probe Tip could be used with MPC864x processors.
3,247 次查看
kumar_086
When the Code warrior tool is installed, the MPC8640 is not found in CW versions v10.4.0, v10.5.1. Please let us know if we need to enable any additional patches/updates. Shared the snapshots of processors of both versions.
3,207 次查看
Oswalag
It is because MPC864X is not supported by Code Warrior for Power Architecture IDE, it is supported in CodeWarrior 8.8 (IDE 5.9).
3,167 次查看
kumar_086
How do we download this version? Can you help us with the link details?
3,084 次查看
Oswalag
