TSN switch configuration
1,047件の閲覧回数
kerol
Hello, I use LS1028ARM to make the development board. The Felix Switch Document mentioned in it is not found in the relevant materials. I hope to obtain this part of information in detail. What we are doing now is the configuration of TSN switch. For the connection topology between the virtual network card in the switch and the switch, could you also explain their connection mode in detail? Thank you very much!
0 返答(返信)
