TJA1145T/FD
TJA1145T/FD
3,615 次查看
basavarajaganes
Please let me know if the TJA1145T/FD supports the CAN-FD in active mode.
I couldn't find the reference for the same in the data sheet. All it says is that the TJA1145T/FD supports CAN-FD in passive mode.
Thanks.
1 回复
3,336 次查看
PetrS
No, TJA1145T/FD does not support the CAN-FD in active mode.
Only the CAN-FD passive mode is supported, means the transceiver is able to ignore CAN FD frames while waiting for a valid wake-up frame in Sleep/Standby mode.
BR, Petr
