TEA2095T application
Dohko
I would like to design a 500W power supply. Output 50V 10A.
May I know if I can use TEA2095T for the SR control? As I know, the supply voltage of TEA2095T is 38Vmax.  Then how can I provide suitable Vcc to TEA2095T. Because I have 50V output at the secondary side.
TomasVaverka
Hi Sam,
The TEA2095T can be used as the SR controller for a 50V/ 10A secondary, but you must supply its VCC from a separate supply (e.g. use an auxiliary transformer winding) that never exceeds its 38V limit. It cannot be powered directly from the 50V output.
BRs, Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-2168719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETEA2095T%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20would%20like%20to%20design%20a%20500W%20power%20supply.%20Output%2050V%2010A.%3C%2FP%3E%3CP%3EMay%20I%20know%20if%20I%20can%20use%20TEA2095T%20for%20the%20SR%20control%3F%20As%20I%20know%2C%20the%20supply%20voltage%20of%20TEA2095T%20is%2038Vmax.%26nbsp%3B%20Then%20how%20can%20I%20provide%20suitable%20Vcc%20to%20TEA2095T.%20Because%20I%20have%2050V%20output%20at%20the%20secondary%20side.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TEA2095T%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Sam%2C%3C%2FP%3E%0A%3CP%3EThe%20TEA2095T%20can%20be%20used%20as%20the%20SR%20controller%20for%20a%2050V%2F%2010A%20secondary%2C%20but%20you%20must%20supply%20its%20VCC%20from%20a%20separate%20supply%20(e.g.%20use%20an%20auxiliary%20transformer%20winding)%20that%20never%20exceeds%20its%2038V%20limit.%20It%20cannot%20be%20powered%20directly%20from%20the%2050V%20output.%3C%2FP%3E%0A%3CP%3EBRs%2C%20Tomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
