TDF8530
TDF8530
1,940 次查看
mirjanalawless
i found a TDF8530N1C but no datasheet to it, is it the same as TDF8530TH/N1?
and can i replace directly a DF8530TH/N1 with a TDF8530/N2 ?
i would like to know exactly what is the diffence between N1 and N2, which Voltage is each?
i appreciate the answer
Mirjana
标记 (1)
1 回复
1,719 次查看
guoweisun
TDF853x/N1 is limited to 18 V,TDF853x/N2 is limited to 25 V.
For the detail information you'd better contact with NXP local distributors sign a NDA then get the related documentations.
Thanks!
