TDA8026 active mode
TDA8026 active mode
pyt351
Hi @Community
I'm trying to interface the TDA8026 CAKE Daughter board with host controller. At first I am trying to detect the product version only for the device by connecting the I2C pins and VDd, VDDintf pins. but i am not able to read the register 0x48h(A0=GND) as the device is not acknowledging. When i checked the current consumption and referred the datasheet i found that the device is in standby mode(400ua) and switched to shutdown mode (40ua) by pulling the SDWNN pin to ground. But i am not able to get the chip into the active mode. I am not able to find any information on the application note or the datasheet. please assist me to test the I2c communication of the TDA8026 device.
Thanks and Regards
pyt
