TDA18250 Documentation
2,701 次查看
martin_gisbert
I have a customer inquiry for the TDA18250(B)HN/TDA18260HN. Unfortunately, the documentation for this part on nxp.com is very poor and I did not find anything but a "Short Datasheet" (8 pages, see attached) on https://www.nxp.com/products/media-and-audio/silicon-tuners/cable-and-terrestrial-silicon-tuners/cab...
--> Where can I find more detailed documentation and references, e.g. to dev.boards, for this "Cable Silicon Tuner"?
Martin, FAE at EBV
标记 (1)
2,646 次查看
reyes
Hi Martin,
It is very unfortunate for me to let you know that the NXP tuner devices alike the TDA18250 are made only for a small part of the industry, therefore information, documentation and support is limited and unfortunately I was not able to get the requested documentation for you through the applications engineers and marketing team, they mentioned that this request need to comes directly from a NXP Sales representative or a DBM, so, you should contact your NXP Sales or your DBM directly to get access to the requested information depending on the opportunity.
I apologize for the problems this may cause.
Jose
