Setting up braodcast MC1322x
1,570 次查看
Lifan
I am using a MC1322x Sensor Node as the coordinator and two MC1322X Low Power Nodes as the Endpoints. Could someone please tell me how to send up the network to allow the Sensor node to broadcast messages to the two Low Power Nodes at the same time? Any help will be greatly appreciated.
-Lifan
950 次查看
AmitPatil
Try setting broadcast address as network address in address info structure (addrInfo.dstAddr.aNwkAddr) whenever you want to transmit broadcast message, see if that works for you.
