SPL error in flash.bin for trying to compile iMX8QXP secureboot
1,638 次查看
pramodreddy
Compilation in iMX8QXP
:~/Downloads/imx-mkimage(lf-6.6.3_1.0.0)$ sudo make clean && make SOC=iMX8QX REV=C0 flash_spl
imx8qm clean done
imx8qx clean done
imx8dxl clean done
imx8ulp clean done
imx93 clean done
imx91 clean done
imx95 clean done
Compiling mkimage_imx8
include misc.mak
include m4.mak
include android.mak
include test.mak
include autobuild.mak
include alias.mak
./../mkimage_imx8 -commit > head.hash
if [ -f tee.bin ]; then \
if [  ]; then \
echo "Start compress tee.bin"; \
lz4 -9 -f --rm tee.bin tee.bin.lz4; \
cp tee.bin.lz4 tee.bin; \
fi; \
if [  ]; then \
./../mkimage_imx8 -soc QX -sw_version  -rev B0 -c -ap bl31.bin a35 0x80000000 -ap u-boot-hash.bin a35 0x80020000 -ap tee.bin a35 0xFE000000 -out u-boot-atf-container.img; \
else \
./../mkimage_imx8 -soc QX -rev B0 -c -ap bl31.bin a35 0x80000000 -ap u-boot-hash.bin a35 0x80020000 -ap tee.bin a35 0xFE000000 -out u-boot-atf-container.img; \
fi; \
else \
./../mkimage_imx8 -soc QX -rev B0 -c -ap bl31.bin a35 0x80000000 -ap u-boot-hash.bin a35 0x80020000 -out u-boot-atf-container.img; \
fi
SOC: QX
REVISION: B0
New Container: 0
AP: bl31.bin core: a35 addr: 0x80000000
AP: u-boot-hash.bin core: a35 addr: 0x80020000
AP: tee.bin core: a35 addr: 0xfe000000
Output: u-boot-atf-container.img
CONTAINER FUSE VERSION: 0x00
CONTAINER SW VERSION: 0x0000
ivt_offset: 1024
rev: 2
Platform: i.MX8QXP B0
ivt_offset: 1024
container image offset (aligned):2000
csf_off 0x2400
flags: 0x10
Hash of the images =
1+0 records in
1+0 records out
33792 bytes (34 kB, 33 KiB) copied, 0.000153251 s, 221 MB/s
64+1 records in
64+1 records out
32909 bytes (33 kB, 32 KiB) copied, 0.000214885 s, 153 MB/s
AP file_offset = 0x2000 size = 0x8400
1+0 records in
1+0 records out
520192 bytes (520 kB, 508 KiB) copied, 0.000895716 s, 581 MB/s
1014+1 records in
1014+1 records out
519649 bytes (520 kB, 507 KiB) copied, 0.0041585 s, 125 MB/s
AP file_offset = 0xa400 size = 0x7f000
1+0 records in
1+0 records out
591872 bytes (592 kB, 578 KiB) copied, 0.00138488 s, 427 MB/s
1155+1 records in
1155+1 records out
591528 bytes (592 kB, 578 KiB) copied, 0.00404481 s, 146 MB/s
AP file_offset = 0x89400 size = 0x90800
CST: CONTAINER 0 offset: 0x0
CST: CONTAINER 0: Signature Block: offset is at 0x190
Offsets = 0x0 0x190
DONE.
Note: Please copy image to offset: IVT_OFFSET + IMAGE_OFFSET
./../mkimage_imx8 -soc QX -rev B0 -dcd skip -append mx8qxc0-ahab-container.img -c -scfw scfw_tcm.bin -ap u-boot-spl.bin a35 0x00100000 -out flash.bin
SOC: QX
REVISION: B0
DCD: skip
New Container: 0
SCFW: scfw_tcm.bin
AP: u-boot-spl.bin core: a35 addr: 0x00100000
Output: flash.bin
ivt_offset: 1024
rev: 2
ivt_offset: 1024
header tag missmatched ca
container image offset (aligned):13400
csf_off 0x13800
flags: 0x10
1+0 records in
1+0 records out
174080 bytes (174 kB, 170 KiB) copied, 0.000434511 s, 401 MB/s
338+1 records in
338+1 records out
173120 bytes (173 kB, 169 KiB) copied, 0.000963655 s, 180 MB/s
SCFW file_offset = 0x13400 size = 0x2a800
1+0 records in
1+0 records out
132096 bytes (132 kB, 129 KiB) copied, 0.000203474 s, 649 MB/s
256+1 records in
256+1 records out
131230 bytes (131 kB, 128 KiB) copied, 0.000234614 s, 559 MB/s
AP file_offset = 0x3dc00 size = 0x20400
CST: CONTAINER 0 offset: 0x400
CST: CONTAINER 0: Signature Block: offset is at 0x510
Offsets = 0x400 0x510
DONE.
append u-boot-atf-container.img at 376 KB
1127+0 records in
1127+0 records out
1154048 bytes (1.2 MB, 1.1 MiB) copied, 0.00305697 s, 378 MB/s
But when i checked in flash.bin below is error i am getting, How to fix this
strings flash.bin | grep -i spl
spl: ERROR: unsupported device
SPL: Unsupported Boot Device!
SPL: failed to boot from all boot devices
U-Boot SPL 2024.04-lf_v2024.04+g6c4545203d1+p0 (Nov 15 2024 - 04:02:13 +0000)
SPL: Image overlaps SPL
SPL: Image too large
spl: unsupported mmc boot device.
spl: could not initialize mmc. error: %d
spl: could not find mmc device %d. error: %d
spl: mmc init failed with error: %d
spl: mmc partition switch failed
spl: mmc: wrong boot mode
display_init
Display the FIPS mode of the SoC by reading fuse 0xA, bit 3
Successfully finished the power up sequence of display.
SPL Phase
TI Keystone SPL Image
TI OMAP SPL With GP CH
sfspl
StarFive SPL Image
display MMC info
u-boot,dm-spl
splashimage=0x9e000000
display-timings
display-subsystem
fsl,imx-display-subsystem
//ldb@562210e0/lvds-channel@0/display-timings/timing0
display0
display1
split_vm_region
标记 (2)
3 回复数
1,532 次查看
Manuel_Salas
Hello @pramodreddy
I hope you are doing very well.
Actually, the command strings flash.bin that you are running is not a runtime error. That command is looking for static strings compiled into the binary.
Salas.
1,503 次查看
pramodreddy
HI @Manuel_Salas
  Deatils_flash.png.
Please check this. we are currently only using flash but not flash_spl. i am trying to generate and sue flash_spl.
I been following user guide og NXP PFA. Generate_flash and using and following the steps.
sudo make clean &&  make SOC=iMX8QX REV=C0 flash_spl using this command to generate flash.bin.
flash.bin is generated successfully. But once this flashed 100%  that's it struck no done or nothing amd terminla is not coming out of it and also furthur wic flashing is not allowed.
Help me where could i gone wrong.
Thanks In advance
Please ping  for any furthur details
1,496 次查看
pramodreddy
HI @Manuel_Salas
Below are the steps we are following
a. cp BUILD_DIR/tmp/deploy/images/imx8qxpc0mek/imx-boot-tools/bl31-imx8qx.bin iMX8QX/bl31.bin
b. cp BUILD_DIR/tmp/deploy/images/imx8qxpc0mek/imx-boot-tools/mx8qxc0-ahab-container.img iMX8QX/
c. cp BUILD_DIR/tmp/deploy/images/imx8qxpc0mek/imx-boot-tools/u-boot-imx8qxpc0mek.bin-sd iMX8QX/u-boot.bin
d. cp BUILD_DIR/tmp/deploy/images/imx8qxpc0mek/imx-boot-tools/u-boot-spl.bin-imx8qxpc0mek-sd iMX8QX/u-boot-spl.bin
a. Copy the scfw_tcm.bin to imx-mkimage/iMX8QX
b. sudo make clean &&  make SOC=iMX8QX REV=C0 flash_spl
Note : current Target which we are using iMX8QXPC0
标记 (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-2360484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B0%9D%E8%AF%95%E7%BC%96%E8%AF%91%20iMX8QXP%20secureboot%20%E6%97%B6%EF%BC%8Cflash.bin%20%E4%B8%AD%E5%87%BA%E7%8E%B0%20SPL%20%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2360484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EiMX8QXP%20%E4%B8%AD%E7%9A%84%E7%BC%96%E8%AF%91%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%3A~%2FDownloads%2Fimx-mkimage(lf-6.6.3_1.0.0)%24%20sudo%20make%20clean%26amp%3B%26amp%3B%20make%20SOC%3DiMX8QX%20REV%3DC0%20flash_spl%3C%2FDIV%3E%3CDIV%3Eimx8qm%20%E6%B8%85%E6%B4%81%E5%AE%8C%E6%88%90%3C%2FDIV%3E%3CDIV%3Eimx8qx%20clean%20done%3C%2FDIV%3E%3CDIV%3Eimx8dxl%20%E6%B8%85%E6%B4%81%E5%AE%8C%E6%AF%95%3C%2FDIV%3E%3CDIV%3Eimx8ulp%20%E6%B8%85%E6%B4%81%E5%AE%8C%E6%88%90%3C%2FDIV%3E%3CDIV%3Eimx93%20%E6%B8%85%E6%B4%81%E5%AE%8C%E6%88%90%3C%2FDIV%3E%3CDIV%3Eimx91%20%E6%B8%85%E6%B4%81%E5%AE%8C%E6%88%90%3C%2FDIV%3E%3CDIV%3Eimx95%20%E6%B8%85%E6%B4%81%E5%AE%8C%E6%88%90%3C%2FDIV%3E%3CDIV%3E%E7%BC%96%E8%AF%91%20mkimage_imx8%3C%2FDIV%3E%3CDIV%3Einclude%20misc.mak%3C%2FDIV%3E%3CDIV%3E%E5%8C%85%E6%8B%AC%20m4.mak%3C%2FDIV%3E%3CDIV%3Einclude%20android.mak%3C%2FDIV%3E%3CDIV%3Einclude%20test.mak%3C%2FDIV%3E%3CDIV%3Einclude%20autobuild.mak%3C%2FDIV%3E%3CDIV%3E%E5%8C%85%E5%90%AB%20alias.mak%3C%2FDIV%3E%3CDIV%3E.%2F..%2Fmkimage_imx8%20-commit%26gt%3B%20head.hash%3C%2FDIV%3E%3CDIV%3Eif%20%5B%20-f%20tee.bin%20%5D%3B%20then%5C%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif%20%5B%20%5D%3B%20then%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eecho%22Start%20compress%20tee.bin%22%3B%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elz4%20-9%20-f%20--rm%20tee.bin%20tee.bin.lz4%EF%BC%9B%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecp%20tee.bin.lz4%20tee.bin%3B%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Efi%3B%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif%20%5B%20%5D%3B%20then%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.%2F%E3%80%82%2Fmkimage_imx8-soc%20QX-sw_version-rev%20B0-c-ap%20bl31.bin%20a35%200x80000000-ap%20u-boot-hash.bin%20a35%200x80000000-ap%20a35%200x80020000-ap%20tee.bin%20a35%200xfe000000-out%20u-boot-atf-container.img%3B%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%90%A6%E5%88%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E.%2F%E3%80%82%2Fmkimage_imx8-soc%20QX-rev%20B0-c-ap%20bl31.bin%20a35%200x80000000-ap%20u-boot-hash.bin%20a35%200x80000000-ap%20a35%200x80020000-ap%20tee.bin%20a35%200xfe000000%20out%20u-boot-atf-container.img%3B%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Efi%3B%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E5%90%A6%E5%88%99%3C%2FDIV%3E%3CDIV%3E.%2F%E3%80%82%E3%80%82%2Fmkimage_imx8-soc%20QX-rev%20B0-c-ap%20bl31.bin%20a35%200x80000000-ap%20u-boot-hash.bin%20a35%200x80000000-ap%20a35%200x80020000-out%20u-boot-atf-container.img%EF%BC%9B%5C%3C%2FDIV%3E%3CDIV%3Efi%3C%2FDIV%3E%3CDIV%3ESOC%EF%BC%9AQX%20%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E8%AE%A2%EF%BC%9A%20B0%20%3C%2FDIV%3E%3CDIV%3E%E6%96%B0%E9%9B%86%E8%A3%85%E7%AE%B1%3A%200%3C%2FDIV%3E%3CDIV%3EAP%3A%20bl31.bin%20core%3A%20a35%20addr%3A%200x80000000%3C%2FDIV%3E%3CDIV%3E%E7%BE%8E%E8%81%94%E7%A4%BE%EF%BC%9Au-boot-hash.bin%20%E6%A0%B8%E5%BF%83%EF%BC%9Aa35%20%E5%9C%B0%E5%9D%80%EF%BC%9A0x80020000%3C%2FDIV%3E%3CDIV%3EAP%3A%20tee.bin%20core%3A%20a35%20addr%3A%200xfe000000%3C%2FDIV%3E%3CDIV%3E%E8%BE%93%E5%87%BA%EF%BC%9Au-boot-atf-container.img%3C%2FDIV%3E%3CDIV%3E%E5%AE%B9%E5%99%A8%E7%86%94%E4%B8%9D%E7%89%88%E6%9C%AC%EF%BC%9A0x00%3C%2FDIV%3E%3CDIV%3E%E5%AE%B9%E5%99%A8%20SW%20%E7%89%88%E6%9C%AC%EF%BC%9A%200x0000%3C%2FDIV%3E%3CDIV%3Eivt_offset%3A%201024%3C%2FDIV%3E%3CDIV%3Erev%3A%202%3C%2FDIV%3E%3CDIV%3E%E5%B9%B3%E5%8F%B0%EF%BC%9Ai.MX8QXP%20B0%3C%2FDIV%3E%3CDIV%3Eivt_offset%3A%201024%3C%2FDIV%3E%3CDIV%3E%E5%AE%B9%E5%99%A8%E5%9B%BE%E5%83%8F%E5%81%8F%E7%A7%BB%EF%BC%88%E5%AF%B9%E9%BD%90%EF%BC%89%EF%BC%9A2000%3C%2FDIV%3E%3CDIV%3Ecsf_off%200x2400%3C%2FDIV%3E%3CDIV%3E%E6%A0%87%E8%AE%B0%EF%BC%9A0x10%3C%2FDIV%3E%3CDIV%3E%E5%9B%BE%E5%83%8F%E7%9A%84%E5%93%88%E5%B8%8C%E5%80%BC%20%3D%20%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E4%B8%AD%E7%9A%84%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E8%AE%B0%E5%BD%95%E8%BE%93%E5%87%BA%3C%2FDIV%3E%3CDIV%3E%E5%A4%8D%E5%88%B6%E4%BA%86%2033792%20%E5%AD%97%E8%8A%82%20(34%20kB%EF%BC%8C33%20KiB)%EF%BC%8C0.000153251%20%E7%A7%92%EF%BC%8C221%20MB%2Fs%3C%2FDIV%3E%3CDIV%3E64%2B1%20%E4%B8%AA%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E64%2B1%20%E6%9D%A1%E8%AE%B0%E5%BD%95%E8%BE%93%E5%87%BA%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%2032909%20%E5%AD%97%E8%8A%82%20(33%20kB%2C%2032%20KiB)%EF%BC%8C0.000214885%20%E7%A7%92%EF%BC%8C153%20MB%2Fs%3C%2FDIV%3E%3CDIV%3EAP%20file_offset%20%3D%200x2000%20size%20%3D%200x8400%3C%2FDIV%3E%3CDIV%3E%E5%9B%BE%E5%83%8F%E7%9A%84%E5%93%88%E5%B8%8C%E5%80%BC%20%3D%20%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E4%B8%AD%E7%9A%84%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E8%AE%B0%E5%BD%95%E8%BE%93%E5%87%BA%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20520192%20%E5%AD%97%E8%8A%82%20(520%20kB%2C%20508%20KiB)%EF%BC%8C0.000895716%20%E7%A7%92%EF%BC%8C581%20MB%2Fs%3C%2FDIV%3E%3CDIV%3E1014%2B1%20%E4%B8%AA%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E1014%2B1%20%E6%9D%A1%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20519649%20%E5%AD%97%E8%8A%82%20(520%20kB%2C%20507%20KiB)%EF%BC%8C0.0041585%20%E7%A7%92%EF%BC%8C125%20MB%2Fs%3C%2FDIV%3E%3CDIV%3EAP%20file_offset%20%3D%200xa400%20size%20%3D%200x7f000%3C%2FDIV%3E%3CDIV%3E%E5%9B%BE%E5%83%8F%E7%9A%84%E5%93%88%E5%B8%8C%E5%80%BC%20%3D%20%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E4%B8%AD%E7%9A%84%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E8%AE%B0%E5%BD%95%E8%BE%93%E5%87%BA%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20591872%20%E5%AD%97%E8%8A%82%20(592%20kB%2C%20578%20KiB)%EF%BC%8C0.00138488%20%E7%A7%92%EF%BC%8C427%20MB%2Fs%3C%2FDIV%3E%3CDIV%3E1155%2B1%20%E4%B8%AA%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E1155%2B1%20%E6%9D%A1%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20591528%20%E5%AD%97%E8%8A%82%20(592%20kB%2C%20578%20KiB)%EF%BC%8C0.00404481%20%E7%A7%92%EF%BC%8C146%20MB%2Fs%3C%2FDIV%3E%3CDIV%3EAP%20file_offset%20%3D%200x89400%20size%20%3D%200x90800%3C%2FDIV%3E%3CDIV%3ECST%EF%BC%9A%E5%AE%B9%E5%99%A8%200%20%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9A0x0%3C%2FDIV%3E%3CDIV%3ECST%EF%BC%9A%E5%AE%B9%E5%99%A8%200%EF%BC%9A%E7%AD%BE%E5%90%8D%E5%9D%97%EF%BC%9A%E5%81%8F%E7%A7%BB%E9%87%8F%E4%B8%BA%200x190%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%81%8F%E7%A7%BB%20%3D%200x0%200x190%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E5%AE%8C%E6%88%90%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%AF%B7%E5%B0%86%E5%9B%BE%E5%83%8F%E5%A4%8D%E5%88%B6%E5%88%B0%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9Aivt_offset%20%2B%20image_offset%3C%2FDIV%3E%3CDIV%3E.%2F%E3%80%82%2Fmkimage_imx8-soc%20QX-rev%20B0-dcd%20%E8%B7%B3%E8%BF%87-append%20mx8qxc0-ahab-container.img-c-c-c-scfw%20scfw_tcm.bin-ap%20u-boot-spl.bin%20a35%200x00100000%20%E8%BE%93%E5%87%BA%20flash.bin%3C%2FDIV%3E%3CDIV%3ESOC%EF%BC%9AQX%20%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E8%AE%A2%EF%BC%9A%20B0%20%3C%2FDIV%3E%3CDIV%3EDCD%3A%20%E8%B7%B3%E8%BF%87%3C%2FDIV%3E%3CDIV%3E%E6%96%B0%E9%9B%86%E8%A3%85%E7%AE%B1%3A%200%3C%2FDIV%3E%3CDIV%3ESCFW%3A%20scfw_tcm.bin%3C%2FDIV%3E%3CDIV%3E%E7%BE%8E%E8%81%94%E7%A4%BE%EF%BC%9Au-boot-spl.bin%20%E6%A0%B8%E5%BF%83%EF%BC%9Aa35%20%E5%9C%B0%E5%9D%80%EF%BC%9A0x00100000%3C%2FDIV%3E%3CDIV%3E%E8%BE%93%E5%87%BA%EF%BC%9Aflash.bin%3C%2FDIV%3E%3CDIV%3E%E5%AE%B9%E5%99%A8%E7%86%94%E4%B8%9D%E7%89%88%E6%9C%AC%EF%BC%9A0x00%3C%2FDIV%3E%3CDIV%3E%E5%AE%B9%E5%99%A8%20SW%20%E7%89%88%E6%9C%AC%EF%BC%9A%200x0000%3C%2FDIV%3E%3CDIV%3Eivt_offset%3A%201024%3C%2FDIV%3E%3CDIV%3Erev%3A%202%3C%2FDIV%3E%3CDIV%3E%E5%B9%B3%E5%8F%B0%EF%BC%9Ai.MX8QXP%20B0%3C%2FDIV%3E%3CDIV%3Eivt_offset%3A%201024%3C%2FDIV%3E%3CDIV%3E%E6%A0%87%E9%A2%98%E6%A0%87%E7%AD%BE%E4%B8%8D%E5%8C%B9%E9%85%8D%3C%2FDIV%3E%3CDIV%3E%E5%AE%B9%E5%99%A8%E5%9B%BE%E5%83%8F%E5%81%8F%E7%A7%BB%EF%BC%88%E5%AF%B9%E9%BD%90%EF%BC%89%EF%BC%9A13400%3C%2FDIV%3E%3CDIV%3Ecsf_off%200x13800%3C%2FDIV%3E%3CDIV%3E%E6%A0%87%E8%AE%B0%EF%BC%9A0x10%3C%2FDIV%3E%3CDIV%3E%E5%9B%BE%E5%83%8F%E7%9A%84%E5%93%88%E5%B8%8C%E5%80%BC%20%3D%20%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E4%B8%AD%E7%9A%84%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E8%AE%B0%E5%BD%95%E8%BE%93%E5%87%BA%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20174080%20%E5%AD%97%E8%8A%82%20(174%20kB%EF%BC%8C170%20KiB)%EF%BC%8C0.000434511%20%E7%A7%92%EF%BC%8C401%20MB%2Fs%3C%2FDIV%3E%3CDIV%3E338%2B1%20%E4%B8%AA%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E338%2B1%20%E6%9D%A1%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20173120%20%E5%AD%97%E8%8A%82%20(173%20kB%2C%20169%20KiB)%EF%BC%8C0.000963655%20%E7%A7%92%EF%BC%8C180%20MB%2Fs%3C%2FDIV%3E%3CDIV%3ESCFW%20file_offset%20%3D%200x13400%20size%20%3D%200x2a800%3C%2FDIV%3E%3CDIV%3E%E5%9B%BE%E5%83%8F%E7%9A%84%E5%93%88%E5%B8%8C%E5%80%BC%20%3D%20%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E4%B8%AD%E7%9A%84%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E1%2B0%20%E8%AE%B0%E5%BD%95%E8%BE%93%E5%87%BA%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20132096%20%E5%AD%97%E8%8A%82%20(132%20kB%2C%20129%20KiB)%EF%BC%8C0.000203474%20%E7%A7%92%EF%BC%8C649%20MB%2Fs%3C%2FDIV%3E%3CDIV%3E256%2B1%20%E4%B8%AA%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E256%2B1%20%E6%9D%A1%E8%AE%B0%E5%BD%95%E8%BE%93%E5%87%BA%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%20131230%20%E5%AD%97%E8%8A%82%20(131%20kB%2C%20128%20KiB)%EF%BC%8C0.000234614%20%E7%A7%92%EF%BC%8C559%20MB%2Fs%3C%2FDIV%3E%3CDIV%3EAP%20file_offset%20%3D%200x3dc00%20size%20%3D%200x20400%3C%2FDIV%3E%3CDIV%3ECST%EF%BC%9A%E5%AE%B9%E5%99%A8%200%20%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9A0x400%3C%2FDIV%3E%3CDIV%3ECST%EF%BC%9A%E5%AE%B9%E5%99%A8%200%EF%BC%9A%E7%AD%BE%E5%90%8D%E5%9D%97%EF%BC%9A%E5%81%8F%E7%A7%BB%E9%87%8F%E4%B8%BA%200x510%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%81%8F%E7%A7%BB%20%3D%200x400%200x510%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E5%AE%8C%E6%88%90%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%AF%B7%E5%B0%86%E5%9B%BE%E5%83%8F%E5%A4%8D%E5%88%B6%E5%88%B0%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9Aivt_offset%20%2B%20image_offset%3C%2FDIV%3E%3CDIV%3E%E5%9C%A8%20376%20KB%20%E5%A4%84%E6%B7%BB%E5%8A%A0%20u-boot-atf-container.img%3C%2FDIV%3E%3CDIV%3E1127%2B0%20%E6%9D%A1%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E1127%2B0%20%E6%9D%A1%E8%AE%B0%E5%BD%95%3C%2FDIV%3E%3CDIV%3E%E5%B7%B2%E5%A4%8D%E5%88%B6%201154048%20%E5%AD%97%E8%8A%82%20(1.2%20MB%EF%BC%8C1.1%20MiB)%EF%BC%8C0.00305697%20%E7%A7%92%EF%BC%8C378%20MB%2Fs%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E5%BD%93%E6%88%91%E6%A3%80%E6%9F%A5%20flash.bin%20%E6%97%B6%EF%BC%8C%E5%8F%91%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%8C%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%EF%BC%9F%3C%2FP%3E%3CP%3Estrings%20flash.bin%20%7C%20grep-i%20spl%20s%20%3CBR%20%2F%3E%20pl%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%E7%9A%84%E8%AE%BE%E5%A4%87%20SPL%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%E7%9A%84%E5%BC%95%E5%AF%BC%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%EF%BC%81%3CBR%20%2F%3ESPL%EF%BC%9A%E6%97%A0%E6%B3%95%E4%BB%8E%E6%89%80%E6%9C%89%E5%BC%95%E5%AF%BC%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%20U-Boot%20SPL%202024.04-lf_v2024.04%2Bg6c4545203d1%2Bp0%EF%BC%882024%20%E5%B9%B4%2011%20%E6%9C%88%2015%20%E6%97%A5-04%3A02%3A13%20%2B0000%EF%BC%89%3CBR%20%2F%3ESPL%EF%BC%9A%E5%9B%BE%E5%83%8F%E4%B8%8E%20SPL%20%E9%87%8D%E5%8F%A0%3CBR%20%2F%3ESPL%EF%BC%9A%E5%9B%BE%E5%83%8F%E5%A4%AA%E5%A4%A7%3CBR%20%2F%3Espl%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%E7%9A%84%20mmc%20%E5%BC%95%E5%AF%BC%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3Espl%EF%BC%9A%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%20mmc%E3%80%82%E9%94%99%E8%AF%AF%3A%25d%20%3CBR%20%2F%3E%20spl%3A%20%E6%89%BE%E4%B8%8D%E5%88%B0%20mmc%20%E8%AE%BE%E5%A4%87%20%25d%E3%80%82%E9%94%99%E8%AF%AF%EF%BC%9A%25d%20%3CBR%20%2F%3E%20spl%EF%BC%9Ammc%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%EF%BC%9A%25d%20%3CBR%20%2F%3E%20spl%EF%BC%9Ammc%20%E5%88%86%E5%8C%BA%E5%88%87%E6%8D%A2%E5%A4%B1%E8%B4%A5%20%3CBR%20%2F%3E%20spl%EF%BC%9Ammc%EF%BC%9A%E9%94%99%E8%AF%AF%E7%9A%84%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%20%3CBR%20%2F%3E%20display_init%20%E9%80%9A%E8%BF%87%E8%AF%BB%E5%8F%96%E7%86%94%E4%B8%9D%200xA%EF%BC%8C%E4%BD%8D%203%20%3CBR%20%2F%3E%20%E6%98%BE%E7%A4%BA%20SoC%20%E7%9A%84%20FIPS%20%E6%A8%A1%E5%BC%8F%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%E6%98%BE%E7%A4%BA%E5%99%A8%E7%9A%84%E5%BC%80%E6%9C%BA%E9%A1%BA%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ESPL%20Phase%20%3CBR%20%2F%3E%20TI%20Keystone%20SPL%20Image%20TI%20OMAP%20SPL%20With%20GP%20CH%20sfspl%20%3CBR%20%2F%3E%20StarFive%20SPL%20%E5%9B%BE%E5%83%8F%E6%98%BE%E7%A4%BA%20MMC%20%E4%BF%A1%E6%81%AF%20%3CBR%20%2F%3E%20u-boot%EF%BC%8Cdm-spl%20splashimage%3D0x9e000000%20%E6%98%BE%E7%A4%BA%E5%99%A8%E8%AE%A1%E6%97%B6%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%E5%AD%90%E7%B3%BB%E7%BB%9F%20%3CBR%20%2F%3E%20fsl%EF%BC%8Cimx-display-display-supsystem%20%2F%2Fldb%20%40562210e0%20%2Flvds-channel%20%400%20%2Fdisplay-%3CBR%20%2F%3E%20timings%2Ftiming0%20display0%20splity1%20spl%20%3CBR%20%2F%3E%20it_vm_region%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2361340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPL%20error%20in%20flash.bin%20for%20trying%20to%20compile%20iMX8QXP%20secureboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2361340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231368%22%20target%3D%22_blank%22%3E%40pramodreddy%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%83%BD%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E5%91%BD%E4%BB%A4%20%3CEM%3E%3CSTRONG%3E%E5%AD%97%E7%AC%A6%E4%B8%B2%20flash.bin%3C%2FSTRONG%3E%3C%2FEM%3E%E5%B9%B6%E4%B8%8D%E6%98%AF%E8%BF%90%E8%A1%8C%E6%97%B6%E9%94%99%E8%AF%AF%E3%80%82%E8%AF%A5%E5%91%BD%E4%BB%A4%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%E7%BC%96%E8%AF%91%E5%88%B0%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E9%9D%99%E6%80%81%E5%AD%97%E7%AC%A6%E4%B8%B2%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%90%A8%E6%8B%89%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPL%20error%20in%20flash.bin%20for%20trying%20to%20compile%20iMX8QXP%20secureboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E9%87%87%E5%8F%96%E7%9A%84%E6%AD%A5%E9%AA%A4%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Ea.%20cp%20BUILD_DIR%2Ftmp%2Fdeploy%2Fimages%2Fimx8qxpc0mek%2Fimx-boot-tools%2Fbl31-imx8qx.bin%20iMX8QX%2Fbl31.bin%20%3CBR%20%2F%3Eb.%20cp%20build_dir%2Ftmp%2Fdeploy%2Fimages%2Fimx8qxpc0mek%2Fimx-boot-tools%2Fmx8qxc0-AHAB-Container.img%20imx8qxc0-AHAB-container.img%20imx8qxpc0%2Fc.cp%20build_dir%2Ftmp%2Fdeploy%2Fimx8qxpc0mek%2Fdeploy%2Fimx8qxpc0mek.bin-SD%20iMX8QX%2Fu-boot.bin%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Ed.%20cp%20build_dir%2Ftmp%2Fdeploy%2Fimages%2Fimx8qxpc0mek%2Fimx-boot-tools%2Fu-boot-spl.bin-imx8qxpc0mek-SD%20iMX8QX%2Fu-boot-spl.bin%3C%2FP%3E%3CP%3Ea.%E5%B0%86%20scfw_tcm.bin%20%E5%A4%8D%E5%88%B6%E5%88%B0%20imx-mkimage%2FiMX8QX%3CBR%20%2F%3Eb.%20sudo%20make%20clean%26amp%3B%26amp%3B%20make%20SOC%3DiMX8QX%20REV%3DC0%20flash_spl%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E5%BD%93%E5%89%8D%E7%9B%AE%E6%A0%87%E4%B8%BA%20iMX8QXPC0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SPL%20error%20in%20flash.bin%20for%20trying%20to%20compile%20iMX8QXP%20secureboot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%3C%2FP%3E%3CP%3E%20%20Deatils_flash.png%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E5%8F%AA%E4%BD%BF%E7%94%A8%E4%BA%86%20flash%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20flash_spl%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%94%9F%E6%88%90%E5%92%8C%E8%B5%B7%E8%AF%89%20flash_spl%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E5%85%B3%E6%B3%A8%20NXP%20PFA%20%E7%9A%84%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E3%80%82%E7%94%9F%E6%88%90%E9%97%AA%E5%AD%98%EF%BC%8C%E5%B9%B6%E6%8C%89%E7%85%A7%E6%AD%A5%E9%AA%A4%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Esudo%20make%20clean%26amp%3B%26amp%3B%20make%20SOC%3DiMX8QX%20REV%3DC0%20flash_spl%20%E4%BD%BF%E7%94%A8%E6%AD%A4%E5%91%BD%E4%BB%A4%E7%94%9F%E6%88%90%20flash.bin%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Eflash.bin%20%E5%B7%B2%E6%88%90%E5%8A%9F%E7%94%9F%E6%88%90%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E4%B8%80%E6%97%A6%E9%97%AA%E7%83%81%E4%BA%86%20100%25%20%EF%BC%8C%E5%B0%B1%E4%BC%9A%E8%A2%AB%E5%87%BB%E4%B8%AD%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%8D%E5%BA%94%EF%BC%8C%E4%B9%9F%E4%B8%8D%E4%BC%9A%E6%9C%89%E4%BB%BB%E4%BD%95%E7%BB%93%E6%9E%9C%EF%BC%8C%E8%80%8C%E4%B8%94%E4%B9%9F%E4%B8%8D%E5%85%81%E8%AE%B8%E5%86%8D%E9%97%AA%E7%83%81%20WIC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%B8%AE%E5%B8%AE%E6%88%91%EF%BC%8C%E6%88%91%E5%93%AA%E9%87%8C%E5%81%9A%E9%94%99%E4%BA%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%A2%84%E5%85%88%E6%84%9F%E8%B0%A2%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E5%A6%82%E9%9C%80%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E6%83%85%EF%BC%8C%E8%AF%B7%E8%81%94%E7%B3%BB%E6%88%91%E4%BB%AC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
