SPC5744PFK1AMLQ9
SPC5744PFK1AMLQ9
JACK123
Dear technology, hello, SPC5744PFK1AMLQ9 The microcontroller does not reset, and every time you switch to an extended session, it shows a failure
davidtosenovjan
Could you please provide details in english? Thanks
JACK123
Dear tech, hello, SPC5744PFK1AMLQ9 microcontroller does not reset, every time you switch to an extended session, it shows a fault
1. Question replication test situation
The customer conducted a cross-validation test on a suspected problematic microcontroller (MCU) using the following methods:
Test 1: Replace with a "problem batch" MCU
Select the product that passed the test from the inventory and replace the MCU with the MCU that was questioned in question this time.
Test Results:
Some products fail the first test;
Some products failed on the 5th repeat test.
Test 2: Replace with a "good batch" MCU
Remove the MCU from the product that is in stock and install it on the product with the original "problem MCU".
Repeat the test 15-20 times, and all products have passed the test throughout the process without any abnormalities.
davidtosenovjan
Which tool is your question related to?
JACK123
The flashing of the program failed
JACK123
If the burning process is not smooth, there will be a probability of "Failure to switch to programming session" and "Failure to switch to extended session".
