SJA1110 Host access point
1,256件の閲覧回数
yangjinzhuang
       I am not sure SPI_AP and SPI_HOST can work at the same time on SJA1110, does it means that it selects SPI_AP by SPI_HAP_SS0 and selects SPI_HOST by SPI_HAP_SS1, then can't select SPI_AP and SPI_HOST at the same time?
3 返答(返信)
1,238件の閲覧回数
PetrS
the SPI Access Point (SPI_AP) and the SPI Host Access (SPI_HOST) share SDI, SDO and SCK signals, so you should not communicate to both slaves at the same time.
BR, Petr
1,218件の閲覧回数
yangjinzhuang
       Thank you very much! How can I get the current mode of SJA1110 SPI now? What is the default mode of factory configuration? How to view?
      I got the hardware GLDBOX(S32G-VNP-GLDBOX) recently,  the Linux BSP version is 35.0, there is only sja1110.ko in Linux OS, the SJA1110 firmware not in, maybe it saved in the flash for SJA1110 itself.
1,199件の閲覧回数
PetrS
read UM11107 for SPI mode info.
For a SJA1110 firmware I think you already discussed it on https://community.nxp.com/t5/S32G/How-to-set-SJA1110-on-GLDBOX/td-p/1911879
BR, Petr
