SJA1105 without Host Processor
ttel
If I understand the datasheet correctly, the SJA1105 Ethernet Switch requires a host processor to load the configuration. This means that I cannot operate the device in a default mode without a processor connected to the SPI port. Did I understand that correctly?
Thanks in advance.
PetrS
yes, SJA1105 will not be functional, until the static configuration is successfully loaded via SPI.
BR, Petr
