SC430410MFC
SC430410MFC
1,632 次查看
nadirkarandyshe
Hallo.
May I ask You What core & instruction set use in controller SC4304 series?
How to get documents & PDF's file of this chip?
Sorry, my english is not good.
Best reggards.
Nadir
1 回复
1,492 次查看
TomE
Specialist II
You're in the wrong forum. This is the forum for asking for help about using the forum. I suspect that might be an 8-bitter, so you should be asking in that forum. Or maybe it isn't - it has an external bus and is in a 132-pin package. What are you trying to reverse-engineer (board # 279731-0181)?
That doesn't seem to be a Freescale product part number. The part in the photo doesn't even have the "Freescale" name or logo on it. A search of their site does find one document that lists that number as given, but I suspect it is a "private label mask part" made for a customer.
Tom
