SC18IM704 sleep mode
1,514件の閲覧回数
Tix00
Hi everyone! Beyond all the issues reported about latest firmware 1.0.2, I found that -in my case, with all the registers in their default values-, entering Sleep Mode (x5A,x5A,xA5,x50), causes the bridge transmit endless null characters (0x00) until it receives any character through UART.
This behaviour is not described in the datasheet. Is it OK????
Many thanks in advance.
1,459件の閲覧回数
Tix00
Hi Tomas, thanks a lot for your fast reply. You're right, datasheet is very clear about this.
BW, Tix00
2 返答(返信)
1,463件の閲覧回数
TomasVaverka
Hi Vicent,
Power-down should work without the device sending endless null char. See the capture below on my setup. Make sure RXD pin remains high during power down.
Are you using the latest device version? What is the date code on these devices?
BR, Tomas
1,460件の閲覧回数
Tix00
BW, Tix00
