Request for FFF Replacement for RF Amplifier Gain Block Part Number SBB1089Z
1,258 次查看
jleu64
Hey NXP community, I am trying to look for a FFF replacement for a gain block amplifier. The part we are currently using is part number SBB1089Z that is currently obsolete. Does NXP offer a FFF alternative?
See datasheet in the mouser link below as well as the attachment:
https://www.mouser.com/ProductDetail/Qorvo/SBB1089Z?qs=p6lVfQR1GSqn6Xv87QE3bg%3D%3D&srsltid=AfmBOorM...
1,247 次查看
ErikaC
Please check our General Purpose Amplifier MMG3014NT1 that It is suitable for applications with frequencies from 40 to 4000 MHz.
  • Single 5 Volt Supply
  • P1dB: 25 dBm @ 900 MHz
  • Small-Signal Gain: 19.5 dB @ 900 MHz
  • Third Order Output Intercept Point: 40.5 dBm @ 900 MHz
  • SOT-89 Surface Mount Package
  • RoHS Compliant
Hope this helps.
