Real Time Clock for MIMXRT1060
1,130件の閲覧回数
RLeclair
I am looking into the correct way to set and get date and time from the RTC in the MIMXRT1060-EVK board. In using the SDK I saw that there is no sample for the driver for RTC shown here nor can it be added: MCUXpresso SDK API Reference Manual: RTC: Real Time Clock (nxp.com)
However, I found that the driver SNVS_HP (MCUXpresso SDK API Reference Manual: SNVS_HP: Secure Non-Volatile Storage (nxp.com)) is usable on the board and has a RTC implementation (has an example on the SDK). I've implemented a solution using it, are there any problems in using this driver for RTC operations?
タグ(1)
1,110件の閲覧回数
Pavel_Hernandez
If you find that library and it works for you, that is ok, but I review the SDK and there are 2 examples with RTC.
Pavel
