Read PWM input signal using fmuk66
767 次查看
WissamSays
I've been looking on google, is there is a way to read GPIO signal using the fmuk66 board. Is it doable? Due to the fact, that when I read the datasheet of the fmuk66, they wrote PWM out, and there is no other information if they're bidirectional or not.
Board : fmuk66
Encoder : ROB-12629 wheel encoders
Thank you in advance.
0 回复数
