RADAR
RADAR
nitikasharma
What will be the maximum IF frequency we can send to ADC if the ADC's maximum sampling rate is 40Msps?
nitikasharma
No, I dont have access. can you please share full datasheet?
ErikaC
Please find the document under secure files, you need an active NDA, if you do not have an active NDA please start the process here: Request an NDA
ErikaC
Can you confirm the part number to provide this information?
Regards.
nitikasharma
Its TEF810x, what is the maximum IF we can apply to ADC?
What should be the chirp time used for the same?
ErikaC
Thank you.
That information can be found in the full datasheet, pages 21/22. Do you have access to full datasheet?
