QN9080 RTC CNT2
QN9080 RTC CNT2
1,856件の閲覧回数
Kynnans
In QN9080 sdk documents ,a RTC register named CNT2 will add one at every clock rising edge, but it‘s a 32 bit number. If i use a 32.768kHz crystal, It can only count to 36 hours. What happens when this register overflows after 36h
6 返答(返信)
1,848件の閲覧回数
KaiLi
Hello @Kynnans
An interrupt will occur after the overflow, and how the interrupt event is handled is determined by the application layer.
1,839件の閲覧回数
Kynnans
Can I  modify this value?
1,822件の閲覧回数
KaiLi
Hello @Kynnans
Which value are you referring to? An interruption event?
1,814件の閲覧回数
Kynnans
can i modify CNT2?
1,807件の閲覧回数
KaiLi
Hello @Kynnans
CTN2 is free running count value, which cannot be modified.
1,849件の閲覧回数
KaiLi
Hello @Kynnans
Which SDK documents do you use and let me check it.
