QN9080 RTC CNT2
QN9080 RTC CNT2
Kynnans
In QN9080 sdk documents ,a RTC register named CNT2 will add one at every clock rising edge, but it‘s a 32 bit number. If i use a 32.768kHz crystal, It can only count to 36 hours. What happens when this register overflows after 36h
KaiLi
Hello @Kynnans
An interrupt will occur after the overflow, and how the interrupt event is handled is determined by the application layer.
Kynnans
Can I  modify this value?
KaiLi
Hello @Kynnans
Which value are you referring to? An interruption event?
Kynnans
can i modify CNT2?
KaiLi
Hello @Kynnans
CTN2 is free running count value, which cannot be modified.
KaiLi
Hello @Kynnans
Which SDK documents do you use and let me check it.
