Problems in getting TapLinx License Key
Kristy
Dear Sir or Madam,
Hello, this is Kristy, an app developer using tools from NXO. I am trying to use the TapLinx SDK, and an Offline TapLinx License Key is needed. (Project Pattern: 11823812)
In the My Project page, I have just created a project and forgot to add the project name to be the same as the application ID. I changed the name back, but I still cannot see the license key. Then I try to delete the file and make a new one. Even if I am the solo developer, it said, "You do not have access to delete the owner's detail record". How to solve these problems?
What I need:
1. Verify my account as the project owner
2. Give me the Offline TapLinx License Key based on Project Pattern: 11823812; or help me to delete Project Pattern: 11823812, let me make a new project
My project is due on 4.10, which is quite urgent. I am looking forward to hearing from you. Thank you.
Kristy Hung
Tags (2)
EduardoZamora
Hello @Kristy
Hope you are doing well.
Please accept my apologies, I believe I am not following this issue. Is your issue related to a TapLinx Application registered in the TapLinx Developer Center? Are you using TapLinx SDK for Android? Or is it for Java?
Please follow the instructions for App registration and online/offline key generation as described in Starting development with TapLinx Android SDK and Starting development with TapLinx Java SDK. Offline License Key for a Java application must be requested and approved by the admin, as mentioned in UG10046, Section 2.1.
Eduardo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2345644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EProblems%20in%20getting%20TapLinx%20License%20Key%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Sir%20or%20Madam%2C%3C%2FP%3E%3CP%3E%3CSPAN%3EHello%2C%20this%20is%20Kristy%2C%20an%20app%20developer%20using%20tools%20from%20NXO.%20I%20am%20trying%20to%20use%20the%20TapLinx%20SDK%2C%20and%20an%20Offline%20TapLinx%20License%20Key%20is%20needed.%20(%3C%2FSPAN%3E%3CSPAN%3EProject%20Pattern%3A%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E11823812)%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIn%20the%20My%20Project%20page%2C%20I%20have%20just%20created%20a%20project%20and%20forgot%20to%20add%20the%20project%20name%20to%20be%20the%20same%20as%20the%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Eapplication%20ID.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EI%20changed%20the%20name%20back%2C%20but%20I%20still%20cannot%20see%20the%20license%20key.%20Then%20I%20try%20to%20delete%20the%20file%20and%20make%20a%20new%20one.%20Even%20if%20I%20am%20the%20solo%20developer%2C%20it%20said%2C%20%22You%20do%20not%20have%20access%20to%20delete%20the%20owner's%20detail%20record%22.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EHow%20to%20solve%20these%20problems%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWhat%20I%20need%3A%3C%2FP%3E%3CP%3E1.%20Verify%20my%20account%20as%20the%20project%20owner%3C%2FP%3E%3CP%3E2.%20Give%20me%20the%26nbsp%3B%3CSPAN%3EOffline%20TapLinx%20License%20Key%20based%20on%26nbsp%3BProject%20Pattern%3A%26nbsp%3B11823812%3B%20or%20help%20me%20to%20delete%26nbsp%3BProject%20Pattern%3A%26nbsp%3B11823812%2C%20let%20me%20make%20a%20new%20project%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMy%20project%20is%20due%20on%204.10%2C%20which%20is%20quite%20urgent.%20I%20am%20looking%20forward%20to%20hearing%20from%20you.%20Thank%20you.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20regards%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EKristy%20Hung%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20in%20getting%20TapLinx%20License%20Key%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260950%22%20target%3D%22_blank%22%3E%40Kristy%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHope%20you%20are%20doing%20well.%3C%2FP%3E%0A%3CP%3EPlease%20accept%20my%20apologies%2C%20I%20believe%20I%20am%20not%20following%20this%20issue.%20Is%20your%20issue%20related%20to%20a%20TapLinx%20Application%20registered%20in%20the%20%3CA%20href%3D%22https%3A%2F%2Finspire.nxp.com%2Fmifare%2Findex.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETapLinx%20Developer%20Center%3C%2FA%3E%3F%20Are%20you%20using%20TapLinx%20SDK%20for%20Android%3F%20Or%20is%20it%20for%20Java%3F%3C%2FP%3E%0A%3CP%3EPlease%20follow%20the%20instructions%20for%20App%20registration%20and%20online%2Foffline%20key%20generation%20as%20described%20in%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10044%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EStarting%20development%20with%20TapLinx%20Android%20SDK%3C%2FA%3E%20and%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10046%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EStarting%20development%20with%20TapLinx%20Java%20SDK%3C%2FA%3E.%20Offline%20License%20Key%20for%20a%20Java%20application%20must%20be%20requested%20and%20approved%20by%20the%20admin%2C%20as%20mentioned%20in%20UG10046%2C%20Section%202.1.%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3EEduardo.%3C%2FP%3E%3C%2FLINGO-BODY%3E
