Pin compatible replacement for BGU7003W,115
A4speaker1
  I have BGU7003W,115 used in my designs but it is getting obsolete now. Can you suggest any pin compatible replacement part which I just solder in my old PCB?
A4speaker1
Can you sugegst any in-production amplifier (almost same or better specs) which can be used instead of this one?
ErikaC
I am afraid that all the family are in the same situation Obsolete or End or life.
However, you can contact Rochester electronics that is our Distributor for obsolete parts.
https://www.rocelec.com/part/01t4w00000POnPIAA1-BGU7003W115
It seems that they have stock.
A4speaker1
Can you recommend any end of life part which is available at least in 3000 quantity?
A4speaker1
Just 3 pcs in stock. Need 3000 pcs.
ErikaC
I am afraid we do not have a  pin compatible replacement for BGU7003W. We apologize for any inconvenience this may cause you.
