PTN5110 not using VCONN
thomaskofoedhan
We use the PTN5110 in an application with only High Speed USB (2.0) and do not want to support active cables or cable ID, which means we won't be supplying VCONN on CC pins. What should I do with the VCONN input?
1) Leave it open.
2) Tie it to GND with or without a pull-down resistor.
Tags (2)
TomasVaverka
Hi Thomas,
Please ground the VCONN_IN pin. You can directly ground it.
Tomas
