PN7462 Debugging Error in MCUXpresso IDE – Need Root Cause and Resolution
1,510 次查看
Vignesh_Venkatesan123
Hello All,
I am using the PN7462 Development Kit with MCUXpresso IDE version 12.24.148. While attempting to debug code on the PN7462, I am encountering the error shown below.
I have included the debug log and attached a screenshot of the error for your reference.
Could you please help identify the root cause of this issue and suggest a possible solution?
Thank you in advance for your support.
Error Log:
LinkServer RedlinkMulti Driver v24.12 (Dec 18 2024 18:34:07 - crt_emu_cm_redlink build 869)
Found part description in XML file PN74xxAU.xml
Reconnected to existing LinkServer process.
============= SCRIPT: PN7xxxxx_Connect.scp =============
DpID = 0BB11477
APID = 0x04770021
============= END SCRIPT ===============================
Probe Firmware: LPC-LINK2 CMSIS-DAP V5.224 (NXP Semiconductors)
Serial Number:  PUDQPZIU
VID:PID:  1FC9:0090
USB Path: \\?\hid#vid_1fc9&pid_0090&mi_00#7&31d1711e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
Using memory from core 0 after searching for a good core
debug interface type      = CoreSight DP (DAP DP ID 0BB11477) over SWD TAP 0
processor type            = Cortex-M0 (CPU ID 00000C20) on DAP AP 0
number of h/w breakpoints = 4
number of flash patches   = 0
number of h/w watchpoints = 2
Probe(0): Connected&Reset. DpID: 0BB11477. CpuID: 00000C20. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FF000: CID B105100D PID 04000BB471 ROM (type 0x1)
ROM 1 E000E000: CID B105E00D PID 04000BB008 Gen SCS (type 0x0)
ROM 1 E0001000: CID B105E00D PID 04000BB00A Gen DWT (type 0x0)
ROM 1 E0002000: CID B105E00D PID 04000BB00B Gen FPB (type 0x0)
NXP: PN7462AU-C3-00
DAP stride is 1024 bytes (256 words)
Inspected v.2 On-chip Flash Memory PN7xxxxx_158k.cfx
Image 'PN7xxxxx_158k Mar  8 2016 16:35:06'
( 65) Chip Setup Complete
Connected: was_reset=true. was_stopped=false
Awaiting telnet connection to port 3330 ...
GDB nonstop mode enabled
FreeRTOS stack backtrace is disabled
Opening flash driver PN7xxxxx_158k.cfx
VECTRESET requested, but not supported on ARMv6-M CPUs. Using SOFTRESET instead.
Using SOFT reset to run the flash driver
Flash device supported (158KB = 79*2K at 0x203000)
Writing 120260 bytes to address 0x00203000 in Flash
driver "ProgramPage" timeout (500 ms)  PC: FFFFFFFE
Closing flash driver PN7xxxxx_158k.cfx
Target error from Commit Flash write: Ec: Flash driver "ProgramPage" timeout (500 ms)  PC: FFFFFFFE
GDB stub (C:\NXP\LinkServer_24.12.21\binaries\crt_emu_cm_redlink) terminating - GDB protocol problem: Pipe has been closed by GDB.
5 回复数
1,494 次查看
KaiLi
Hello @Vignesh_Venkatesan123
Try turning the power off and then on again. In principle, EVK+example project should not have any problems. It works on my side.
1,490 次查看
Hello KaiLi,
I am working on below example code "NfcrdlibEx10_MIFAREDESFire_EVx". I could able to progress for certificate read/write and flash. Now i am facing this issue in board side. there are no changes made to SW which worked earlier.
Probe used : LPC-LINK2 CMSIS-DAP V5.224
Vignesh Venkatesan
1,371 次查看
KaiLi
Please try updating the LPC-Link2 firmware. Normally, the EVK board and software code haven't been modified, so there shouldn't be any problems.
Please update firmware by going LPC-Link2 | NXP Semiconductors
968 次查看
There is no problem with LPC-Link2. As i connected another EVK board with the same LPC-Link2 and same probe, debug flashing is happening properly. Problem is with EVK board.
869 次查看
Hi @KaiLi
Can you please explain the process of how to do full erase ?
%3CLINGO-SUB%20id%3D%22lingo-sub-2367352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7462%20MCUXpresso%20IDE%20%E8%B0%83%E8%AF%95%E9%94%99%E8%AF%AF%20-%20%E9%9C%80%E8%A6%81%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E5%92%8C%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%B8%A6%E6%9C%89%20MCUXpresso%20IDE%2012.24.148%20%E7%89%88%E6%9C%AC%E7%9A%84%20PN7462%20%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E3%80%82%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%B0%83%E8%AF%95%20PN7462%20%E4%B8%8A%E7%9A%84%E4%BB%A3%E7%A0%81%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E4%BA%86%E9%94%99%E8%AF%AF%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E4%BE%9B%E4%BD%A0%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%B8%AE%E5%8A%A9%E6%89%BE%E5%87%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%EF%BC%8C%E5%B9%B6%E6%8F%90%E5%87%BA%E5%8F%AF%E8%83%BD%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CP%3ELinkServer%20RedlinkMulti%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20v24.12%EF%BC%882024%20%E5%B9%B4%2012%20%E6%9C%88%2018%20%E6%97%A5%2018%3A34%3A07-crt_emu_cm_redlink%20%E7%89%88%E6%9C%AC%20869%EF%BC%89%3C%2FP%3E%3CP%3E%E5%9C%A8%20XML%20%E6%96%87%E4%BB%B6%20PN74xxAU.xml%20%E4%B8%AD%E6%89%BE%E5%88%B0%E9%83%A8%E4%BB%B6%E6%8F%8F%E8%BF%B0%3C%2FP%3E%3CP%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E8%84%9A%E6%9C%AC%EF%BC%9APN7xxxxx_Connect.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EDpID%20%3D%200BB11477%3C%2FP%3E%3CP%3EAPID%20%3D%200x04770021%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%9B%BA%E4%BB%B6%EF%BC%9ALPC-LINK2%20CMSIS-DAP%20V5.224%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3C%2FP%3E%3CP%3E%E5%BA%8F%E5%88%97%E5%8F%B7%20%20PUDQPZIU%3C%2FP%3E%3CP%3Evid%3Apid%3A%201fc9%3A0090%3C%2FP%3E%3CP%3EUSB%20%E8%B7%AF%E5%BE%84%EF%BC%9A%5C%3F%5Chid%23vid_1fc9%26amp%3Bpid_0090%26amp%3Bmi_00%237%26amp%3B31d1711e%26amp%3B0%26amp%3B0000%23%7B4d1e55b2-f16f-11cf-88cb-001111000030%7D%3C%2FP%3E%3CP%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E5%A5%BD%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%EF%BC%8C%E4%BD%BF%E7%94%A8%E6%A0%B8%E5%BF%83%200%20%E7%9A%84%E5%86%85%E5%AD%98%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%20SWD%20TAP%200%20%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSIGHT%20DP%EF%BC%88DAP%20DP%20ID%200BB11477%EF%BC%89%3C%2FP%3E%3CP%3EDAP%20AP%200%20%E4%B8%8A%E7%9A%84%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M0%20(CPU%20ID%2000000C20)%3C%2FP%3E%3CP%3E%E4%B8%AD%E6%96%AD%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%204%3C%2FP%3E%3CP%3E%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%E9%87%8F%20%3D%200%3C%2FP%3E%3CP%3Eh%2Fw%20%E7%9B%91%E8%A7%86%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%202%3C%2FP%3E%3CP%3EProbe(0)%EF%BC%9A%E5%B7%B2%E8%BF%9E%E6%8E%A5%26amp%3B%E9%87%8D%E7%BD%AE%E3%80%82DpID%3A%200BB11477.CpuID%3A%2000000C20%E3%80%82%E4%BF%A1%E6%81%AF%3CNONE%3E%3C%2FNONE%3E%3C%2FP%3E%3CP%3E%E8%B0%83%E8%AF%95%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E6%8D%89%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3ECoreSight%20%E8%B0%83%E8%AF%95%20ROM%20%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3ERBASE%20E00FF000%EF%BC%9ACID%20B105100D%20PID%2004000BB471%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3C%2FP%3E%3CP%3EROM%201%20E000E000%EF%BC%9ACID%20B105E00D%20PID%2004000BB008%20Gen%20SCS%EF%BC%88%E7%B1%BB%E5%9E%8B%200x0%EF%BC%89%3C%2FP%3E%3CP%3EROM%201%20E0001000%EF%BC%9ACID%20B105E00D%20PID%2004000BB00A%20Gen%20DWT%EF%BC%88%E7%B1%BB%E5%9E%8B%200x0%EF%BC%89%3C%2FP%3E%3CP%3EROM%201%20E0002000%EF%BC%9ACID%20B105E00D%20PID%2004000BB00B%20Gen%20FPB%EF%BC%88%E7%B1%BB%E5%9E%8B%200x0%EF%BC%89%3C%2FP%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6PN7462AU-C3-00%3C%2FP%3E%3CP%3EDAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%201024%20%E5%AD%97%E8%8A%82%EF%BC%88256%20%E4%B8%AA%E5%AD%97%EF%BC%89%3C%2FP%3E%3CP%3E%E6%A3%80%E6%9F%A5%20v.2%20%E7%89%87%E4%B8%8A%E9%97%AA%E5%AD%98%20PN7xxxxx_158k.cfx%3C%2FP%3E%3CP%3E%E5%9B%BE%E5%83%8F%20%22PN7xxxxx_158k%202016%20%E5%B9%B4%203%20%E6%9C%88%208%20%E6%97%A5%2016%3A35%3A06%3C%2FP%3E%3CP%3E(%2065)%20%E8%8A%AF%E7%89%87%E8%AE%BE%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FP%3E%3CP%3E%E5%B7%B2%E8%BF%9E%E6%8E%A5%EF%BC%9Awas_reset%3Dtrue%E3%80%82was_stopped%3Dfalse%3C%2FP%3E%3CP%3E%E7%AD%89%E5%BE%85%20telnet%20%E8%BF%9E%E6%8E%A5%E5%88%B0%203330%20%E7%AB%AF%E5%8F%A3%20...%3C%2FP%3E%3CP%3E%E5%90%AF%E7%94%A8%20GDB%20%E4%B8%8D%E9%97%B4%E6%96%AD%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3EFreeRTOS%20%E5%A0%86%E6%A0%88%E5%9B%9E%E6%BA%AF%E5%B7%B2%E7%A6%81%E7%94%A8%3C%2FP%3E%3CP%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20PN7xxxxx_158k.cfx%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv6-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E4%BD%BF%E7%94%A8%20SOFTRESET%20%E4%BB%A3%E6%9B%BF%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E6%9D%A5%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%3E%E6%94%AF%E6%8C%81%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%EF%BC%880x203000%20%E6%97%B6%E4%B8%BA%20158KB%20%3D%2079*2K%EF%BC%89%3C%2FP%3E%3CP%3E%E5%9C%A8%E9%97%AA%E5%AD%98%E4%B8%AD%E5%86%99%E5%85%A5%20120260%20%E5%AD%97%E8%8A%82%E4%BB%A5%E5%AF%BB%E5%9D%80%200x00203000%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%22ProgramPage%22%20%E8%B6%85%E6%97%B6%EF%BC%88500%20%E6%AF%AB%E7%A7%92%EF%BC%89%20PC%EF%BC%9AFFFFFFFE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20PN7xxxxx_158k.cfx%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%8F%90%E4%BA%A4%E9%97%AA%E5%AD%98%E5%86%99%E5%85%A5%E6%97%B6%E5%87%BA%E7%8E%B0%E7%9B%AE%E6%A0%87%E9%94%99%E8%AF%AF%EF%BC%9AEc%EF%BC%9A%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%22ProgramPage%22%20%E8%B6%85%E6%97%B6%EF%BC%88500%20%E6%AF%AB%E7%A7%92%EF%BC%89%20PC%EF%BC%9AFFFFFFFE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGDB%20%E7%9F%AD%E6%88%AA%E7%BA%BF%EF%BC%88C%3A%5CNXP%5CLinkServer_24.12.21%5C%20binaries%5C%20crt_emu_cm_redlink%EF%BC%89%E6%AD%A3%E5%9C%A8%E7%BB%88%E6%AD%A2%E2%80%94%E2%80%94GDB%20%E5%8D%8F%E8%AE%AE%E9%97%AE%E9%A2%98%EF%BC%9AGDB%20%E5%B7%B2%E5%85%B3%E9%97%AD%E7%AE%A1%E9%81%93%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2367659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CKaiLi%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%A4%84%E7%90%86%E4%BB%A5%E4%B8%8B%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%22NfcrdlibEx10_MIFAREDESFire_EVx%22%20%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%AF%81%E4%B9%A6%E8%AF%BB%2F%E5%86%99%E5%92%8C%E9%97%AA%E5%AD%98%E6%96%B9%E9%9D%A2%E5%8F%96%E5%BE%97%E8%BF%9B%E5%B1%95%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E5%9C%A8%E6%9D%BF%E6%96%B9%E9%9D%A2%E9%9D%A2%E4%B8%B4%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%B2%A1%E6%9C%89%E5%AF%B9%E4%BB%A5%E5%89%8D%E8%BF%90%E8%A1%8C%E7%9A%84%20SW%20%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E7%9A%84%E6%8E%A2%E5%A4%B4%EF%BC%9ALPC-LINK2%20CMSIS-DAP%20V5.224%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E7%BB%B4%E6%A0%BC%E5%86%85%E4%BB%80-%E6%96%87%E5%8D%A1%E7%89%B9%E6%A1%91%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2367537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253318%22%20target%3D%22_blank%22%3E%40Vignesh_Venkatesan123%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B0%9D%E8%AF%95%E5%85%B3%E9%97%AD%E7%94%B5%E6%BA%90%EF%BC%8C%E7%84%B6%E5%90%8E%E5%86%8D%E6%89%93%E5%BC%80%E3%80%82%E5%8E%9F%E5%88%99%E4%B8%8A%EF%BC%8CEVK%2B%20%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E4%B8%8D%E5%BA%94%E8%AF%A5%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%E5%AE%83%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253318%22%20target%3D%22_blank%22%3E%40Vignesh_Venkatesan123%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E6%9B%B4%E6%96%B0%20LPC-Link2%20%E5%9B%BA%E4%BB%B6%E3%80%82%E9%80%9A%E5%B8%B8%EF%BC%8CEVK%20%E4%B8%BB%E6%9D%BF%E5%92%8C%E8%BD%AF%E4%BB%B6%E4%BB%A3%E7%A0%81%E5%B0%9A%E6%9C%AA%E4%BF%AE%E6%94%B9%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%BA%94%E8%AF%A5%E4%B8%8D%E4%BC%9A%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E9%80%9A%E8%BF%87%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOM13054%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELPC-Link%3C%2FA%3E%202%20%E6%9B%B4%E6%96%B0%E5%9B%BA%E4%BB%B6%20%7C%20NXP%20%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2376634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2376634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELPC-Link2%20%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%20LPC-Link2%20%E5%92%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E6%8E%A2%E5%A4%B4%E8%BF%9E%E6%8E%A5%E5%8F%A6%E4%B8%80%E4%B8%AA%20EVK%20%E6%9D%BF%E6%97%B6%EF%BC%8C%E8%B0%83%E8%AF%95%E5%88%B7%E6%96%B0%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%20EVK%20%E4%B8%BB%E6%9D%BF%E4%B8%8A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205266%22%20target%3D%22_blank%22%3E%40KaiLi%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E5%A6%82%E4%BD%95%E8%BF%9B%E8%A1%8C%E5%AE%8C%E5%85%A8%E6%B8%85%E9%99%A4%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
