PN7462 Debugging Error in MCUXpresso IDE – Need Root Cause and Resolution
1,521件の閲覧回数
Vignesh_Venkatesan123
Hello All,
I am using the PN7462 Development Kit with MCUXpresso IDE version 12.24.148. While attempting to debug code on the PN7462, I am encountering the error shown below.
I have included the debug log and attached a screenshot of the error for your reference.
Could you please help identify the root cause of this issue and suggest a possible solution?
Thank you in advance for your support.
Error Log:
LinkServer RedlinkMulti Driver v24.12 (Dec 18 2024 18:34:07 - crt_emu_cm_redlink build 869)
Found part description in XML file PN74xxAU.xml
Reconnected to existing LinkServer process.
============= SCRIPT: PN7xxxxx_Connect.scp =============
DpID = 0BB11477
APID = 0x04770021
============= END SCRIPT ===============================
Probe Firmware: LPC-LINK2 CMSIS-DAP V5.224 (NXP Semiconductors)
Serial Number:  PUDQPZIU
VID:PID:  1FC9:0090
USB Path: \\?\hid#vid_1fc9&pid_0090&mi_00#7&31d1711e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
Using memory from core 0 after searching for a good core
debug interface type      = CoreSight DP (DAP DP ID 0BB11477) over SWD TAP 0
processor type            = Cortex-M0 (CPU ID 00000C20) on DAP AP 0
number of h/w breakpoints = 4
number of flash patches   = 0
number of h/w watchpoints = 2
Probe(0): Connected&Reset. DpID: 0BB11477. CpuID: 00000C20. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FF000: CID B105100D PID 04000BB471 ROM (type 0x1)
ROM 1 E000E000: CID B105E00D PID 04000BB008 Gen SCS (type 0x0)
ROM 1 E0001000: CID B105E00D PID 04000BB00A Gen DWT (type 0x0)
ROM 1 E0002000: CID B105E00D PID 04000BB00B Gen FPB (type 0x0)
NXP: PN7462AU-C3-00
DAP stride is 1024 bytes (256 words)
Inspected v.2 On-chip Flash Memory PN7xxxxx_158k.cfx
Image 'PN7xxxxx_158k Mar  8 2016 16:35:06'
( 65) Chip Setup Complete
Connected: was_reset=true. was_stopped=false
Awaiting telnet connection to port 3330 ...
GDB nonstop mode enabled
FreeRTOS stack backtrace is disabled
Opening flash driver PN7xxxxx_158k.cfx
VECTRESET requested, but not supported on ARMv6-M CPUs. Using SOFTRESET instead.
Using SOFT reset to run the flash driver
Flash device supported (158KB = 79*2K at 0x203000)
Writing 120260 bytes to address 0x00203000 in Flash
driver "ProgramPage" timeout (500 ms)  PC: FFFFFFFE
Closing flash driver PN7xxxxx_158k.cfx
Target error from Commit Flash write: Ec: Flash driver "ProgramPage" timeout (500 ms)  PC: FFFFFFFE
GDB stub (C:\NXP\LinkServer_24.12.21\binaries\crt_emu_cm_redlink) terminating - GDB protocol problem: Pipe has been closed by GDB.
5 返答(返信)
1,505件の閲覧回数
KaiLi
Hello @Vignesh_Venkatesan123
Try turning the power off and then on again. In principle, EVK+example project should not have any problems. It works on my side.
1,501件の閲覧回数
Hello KaiLi,
I am working on below example code "NfcrdlibEx10_MIFAREDESFire_EVx". I could able to progress for certificate read/write and flash. Now i am facing this issue in board side. there are no changes made to SW which worked earlier.
Probe used : LPC-LINK2 CMSIS-DAP V5.224
Vignesh Venkatesan
1,382件の閲覧回数
KaiLi
Please try updating the LPC-Link2 firmware. Normally, the EVK board and software code haven't been modified, so there shouldn't be any problems.
Please update firmware by going LPC-Link2 | NXP Semiconductors
979件の閲覧回数
There is no problem with LPC-Link2. As i connected another EVK board with the same LPC-Link2 and same probe, debug flashing is happening properly. Problem is with EVK board.
880件の閲覧回数
Hi @KaiLi
Can you please explain the process of how to do full erase ?
%3CLINGO-SUB%20id%3D%22lingo-sub-2367352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXpresso%20IDE%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BPN7462%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A8%E3%83%A9%E3%83%BC%20%E2%80%93%20%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%81%A8%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFMCUXpresso%20IDE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B312.24.148%E3%81%A7PN7462%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82PN7462%E4%B8%8A%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%AD%E3%82%B0%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E7%94%BB%E9%9D%A2%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%82%E4%BD%B5%E3%81%9B%E3%81%A6%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%3A%3C%2FP%3E%3CP%3ELinkServer%20RedlinkMulti%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20v24.12%20(2024%E5%B9%B412%E6%9C%8818%E6%97%A5%2018%3A34%3A07%20-%20crt_emu_cm_redlink%20%E3%83%93%E3%83%AB%E3%83%89%20869)%3C%2FP%3E%3CP%3EXML%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABPN74xxAU.xml%E3%81%AB%E9%83%A8%E5%93%81%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%97%A2%E5%AD%98%E3%81%AELinkServer%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3A%20PN7xxxxx_Connect.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EDpID%20%3D%200BB11477%3C%2FP%3E%3CP%3EAPID%20%3D%200x04770021%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E7%B5%82%E4%BA%86%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%EF%BC%9ALPC-LINK2%20CMSIS-DAP%20V5.224%EF%BC%88NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA%E8%A3%BD%EF%BC%89%3C%2FP%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A%20PUDQPZIU%3C%2FP%3E%3CP%3EVID%3APID%3A%201FC9%3A0090%3C%2FP%3E%3CP%3EUSB%E3%83%91%E3%82%B9%3A%20%5C%5C%3F%5Chid%23vid_1fc9%26amp%3Bpid_0090%26amp%3Bmi_00%237%26amp%3B31d1711e%26amp%3B0%26amp%3B0000%23%7B4d1e55b2-f16f-11cf-88cb-001111000030%7D%3C%2FP%3E%3CP%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%82%B3%E3%82%A2%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%B3%E3%82%A20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%200BB11477)%20over%20SWD%20TAP%200%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20Cortex-M0%20(CPU%20ID%2000000C20)%20(DAP%20AP%200)%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%204%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%200%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%202%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(0)%3A%20%E6%8E%A5%E7%B6%9A%E6%B8%88%E3%81%BF%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%B8%88%E3%81%BF%E3%80%82DPID%3A%200BB11477%E3%80%82CPUID%3A%2000000C20%E3%80%82%E6%83%85%E5%A0%B1%EF%BC%9A%3CNONE%3E%3C%2FNONE%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%9ASWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%EF%BC%9A%E7%84%A1%E5%8A%B9%E3%80%82%3C%2FP%3E%3CP%3ECoreSight%E3%83%87%E3%83%90%E3%83%83%E3%82%B0ROM%E3%81%AE%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3ERBASE%20E00FF000%3A%20CID%20B105100D%20PID%2004000BB471%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3C%2FP%3E%3CP%3EROM%201%20E000E000%3A%20CID%20B105E00D%20PID%2004000BB008%20Gen%20SCS%20(%E3%82%BF%E3%82%A4%E3%83%97%200x0)%3C%2FP%3E%3CP%3EROM%201%20E0001000%3A%20CID%20B105E00D%20PID%2004000BB00A%20Gen%20DWT%20(%E3%82%BF%E3%82%A4%E3%83%97%200x0)%3C%2FP%3E%3CP%3EROM%201%20E0002000%3A%20CID%20B105E00D%20PID%2004000BB00B%20Gen%20FPB%20(%E3%82%BF%E3%82%A4%E3%83%97%200x0)%3C%2FP%3E%3CP%3ENXP%3A%20PN7462AU-C3-00%3C%2FP%3E%3CP%3EDAP%E3%81%AE%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF1024%E3%83%90%E3%82%A4%E3%83%88%EF%BC%88256%E3%83%AF%E3%83%BC%E3%83%89%EF%BC%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%A4%9C%E6%9F%BB%E6%B8%88%E3%81%BF%20v.2%20%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%20PN7xxxxx_158k.cfx%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%E3%80%8CPN7xxxxx_158k%202016%E5%B9%B43%E6%9C%888%E6%97%A5%2016%3A35%3A06%E3%80%8D%3C%2FP%3E%3CP%3E%EF%BC%8865%EF%BC%89%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%3A%20was_reset%3Dtrue%E3%80%82was_stopped%3Dfalse%3C%2FP%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%883330%E3%81%B8%E3%81%AETelnet%E6%8E%A5%E7%B6%9A%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD...%3C%2FP%3E%3CP%3EGDB%E3%83%8E%E3%83%B3%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E6%9C%89%E5%8A%B9%3C%2FP%3E%3CP%3EFreeRTOS%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%83%90%E3%83%83%E3%82%AF%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90PN7xxxxx_158k.cfx%E3%82%92%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EVECTRESET%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv6-M%20CPU%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%82%BD%E3%83%95%E3%83%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%95%E3%83%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%AF%BE%E5%BF%9C%EF%BC%88158KB%20%3D%2079*2K%E3%80%81%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x203000%EF%BC%89%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x00203000%E3%81%AB120260%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%8CProgramPage%E3%80%8D%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%EF%BC%88500%20ms%EF%BC%89PC%3A%20FFFFFFFE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90PN7xxxxx_158k.cfx%E3%82%92%E9%96%89%E3%81%98%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%88%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%EF%BC%89%EF%BC%9AEc%EF%BC%9A%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%80%8CProgramPage%E3%80%8D%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%EF%BC%88500ms%EF%BC%89PC%EF%BC%9AFFFFFFFE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGDB%20%E3%82%B9%E3%82%BF%E3%83%96%20(C%3A%5CNXP%5CLinkServer_24.12.21%5Cbinaries%5Ccrt_emu_cm_redlink)%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%20-%20GDB%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%3A%20%E3%83%91%E3%82%A4%E3%83%97%E3%81%8C%20GDB%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2367659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81KaiLi%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8CNfcrdlibEx10_MIFAREDESFire_EVx%E3%80%8D%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E5%85%88%E3%81%AB%E9%80%B2%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E5%81%B4%E3%81%A7%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E5%89%8D%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%AF%E5%8A%A0%E3%81%88%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%EF%BC%9ALPC-LINK2%20CMSIS-DAP%20V5.224%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%B4%E3%82%A3%E3%82%B0%E3%83%8D%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%B4%E3%82%A7%E3%83%B3%E3%82%AB%E3%83%86%E3%82%B5%E3%83%B3%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2367537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2367537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253318%22%20target%3D%22_blank%22%3E%40Vignesh_Venkatesan123%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%92%E4%B8%80%E5%BA%A6%E5%88%87%E3%81%A3%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E5%85%A5%E3%82%8C%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%8E%9F%E5%89%87%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81EVK%2Bexample%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253318%22%20target%3D%22_blank%22%3E%40Vignesh_Venkatesan123%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ELPC-Link2%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E9%80%9A%E5%B8%B8%E3%80%81EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOM13054%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELPC-Link2%20%7C%20NXP%20Semiconductors%3C%2FA%3E%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2376634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2376634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELPC-Link2%E3%81%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%90%8C%E3%81%98LPC-Link2%E3%81%A8%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E5%88%A5%E3%81%AEEVK%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AFEVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7462%20Debugging%20Error%20in%20MCUXpresso%20IDE%20%E2%80%93%20Need%20Root%20Cause%20and%20Resolution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205266%22%20target%3D%22_blank%22%3E%40KaiLi%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%AE%8C%E5%85%A8%E6%B6%88%E5%8E%BB%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
