PCMFxUSB3S Product
PCMFxUSB3S Product
1,064 次查看
AD_iniv
I'm currently thinking about use your product 'PCMFxUSB3S' (filter+ESD diode). I saw in the datasheet that a A1,3,5 pins (on the 3 lines version) is suppose to be the positive input, and A2,4,6 the negative one.
There are possible issue to connecting, for example, the negative side of a differential line to A1 and the positive one to A2 (of course changing also the polarity on the C side)?
1,050 次查看
TomasVaverka
Hello Alice,
Please be informed that the PCMFxUSB3S is no longer in our portfolio.
NXP has divested its Standard Products business on Feb 6th 2017. There is a standalone company called “Nexperia”, headquartered in the Netherlands, and is one of world-class leaders in Discretes, Logic and MOSFETs.
You may try to re-enter your inquiry at the Nexperia support web page: www.nexperia.com/support.
PCMFxUSB3S:
https://www.nexperia.com/products/esd-protection-tvs-filtering-and-signal-conditioning/emi-solutions...
Tomas
