PCF85263 RTC I2C Communication Issue - All Registers Returning 0x00
已解决
跳至解决方案
2,648 次查看
ohck
I'm configuring the PCF85263 RTC and encountering an issue where all registers return 0x00 when I attempt to read them via I2C. Here’s my setup and the steps I’ve followed:
HW setup:
- PCF85263 rtc connected to a Quectel BG95-m3 module.
- pull-up resistors are present
Issue:
- I have tried to write different commands to different registers but when verifying the registers state they all return as 0x00
Steps I have taken:
- I have confirmed that the rtc gets 1.8v on VDD, SDA and SCL using a multimeter.
- Tested on two separate devices.
My code is in the attached file(set_alarm function gets called).
Is there some step I'm missing in the configuration?
Thanks in advance.
1 解答
2,627 次查看
TomasVaverka
Hi Oscar,
If you have a logic analyzer or an oscilloscope, could you please share some screenshots to check what is going on the bus?
It should also help us to verify each I2C operation's acknowledgment. If a command is not acknowledged, subsequent operations could fail.
Looking at your code, the I2C device address being used is correct. Just verify if the I2C library expects this 7-bit address (0x51) and automatically handles the read/write bit.
BRs, Tomas
在原帖中查看解决方案
2 回复数
2,628 次查看
TomasVaverka
Hi Oscar,
BRs, Tomas
2,565 次查看
ohck
Thank you, forgot to answer... Got a logic analyzer and looking at the addresses I found out that I had to use the 0x51 address as is. Our other sensors required the R/W bit included in the address so I thought this one also needed.
%3CLINGO-SUB%20id%3D%22lingo-sub-1978175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPCF85263%20RTC%20I2C%20%E9%80%9A%E4%BF%A1%E9%97%AE%E9%A2%98%20-%20%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E8%BF%94%E5%9B%9E%200x00%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E9%85%8D%E7%BD%AE%20PCF85263%20RTC%EF%BC%8C%E5%B9%B6%E9%81%87%E5%88%B0%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%20I2C%20%E8%AF%BB%E5%8F%96%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BB%AC%E9%83%BD%E8%BF%94%E5%9B%9E%200x00%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%92%8C%E6%88%91%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%E7%A1%AC%E4%BB%B6%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E-%20PCF85263%20rtc%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20Quectel%20BG95-m3%20%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E-%20%E5%AD%98%E5%9C%A8%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E-%20%E6%88%91%E5%B0%9D%E8%AF%95%E5%B0%86%E4%B8%8D%E5%90%8C%E7%9A%84%E5%91%BD%E4%BB%A4%E5%86%99%E5%85%A5%E4%B8%8D%E5%90%8C%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E4%BD%86%E5%BD%93%E9%AA%8C%E8%AF%81%E5%AF%84%E5%AD%98%E5%99%A8%E7%8A%B6%E6%80%81%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BB%AC%E9%83%BD%E8%BF%94%E5%9B%9E%200x00%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E9%87%87%E5%8F%96%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FP%3E%3CP%3E-%20%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E4%B8%87%E7%94%A8%E8%A1%A8%E7%A1%AE%E8%AE%A4%20rtc%20%E5%9C%A8%20VDD%E3%80%81SDA%20%E5%92%8C%20SCL%20%E4%B8%8A%E8%8E%B7%E5%BE%97%201.8v%E3%80%82%3C%2FP%3E%3CP%3E-%20%E5%9C%A8%E4%B8%A4%E4%B8%AA%E7%8B%AC%E7%AB%8B%E7%9A%84%E8%AE%BE%E5%A4%87%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E5%9C%A8%E9%99%84%E4%BB%B6%E4%B8%AD%EF%BC%88set_alarm%20%E5%87%BD%E6%95%B0%E8%A2%AB%E8%B0%83%E7%94%A8%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%98%AF%E5%90%A6%E7%BC%BA%E5%B0%91%E4%BA%86%E6%9F%90%E4%BA%9B%E6%AD%A5%E9%AA%A4%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1983666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APCF85263%20RTC%20I2C%20%E9%80%9A%E4%BF%A1%E9%97%AE%E9%A2%98%20-%20%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E8%BF%94%E5%9B%9E%200x00%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1983666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E5%BF%98%E4%BA%86%E5%9B%9E%E7%AD%94...%E5%BE%97%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E5%B9%B6%E6%9F%A5%E7%9C%8B%E5%9C%B0%E5%9D%80%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E6%88%91%E5%BF%85%E9%A1%BB%E6%8C%89%E5%8E%9F%E6%A0%B7%E4%BD%BF%E7%94%A8%200x51%20%E5%9C%B0%E5%9D%80%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%E5%85%B6%E4%BB%96%E4%BC%A0%E6%84%9F%E5%99%A8%E9%9C%80%E8%A6%81%E5%9C%B0%E5%9D%80%E4%B8%AD%E5%8C%85%E5%90%AB%20R%2FW%20%E4%BD%8D%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%AA%E4%B9%9F%E9%9C%80%E8%A6%81%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1978313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APCF85263%20RTC%20I2C%20%E9%80%9A%E4%BF%A1%E9%97%AE%E9%A2%98%20-%20%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E8%BF%94%E5%9B%9E%200x00%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Oscar%2C%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E9%80%BB%E8%BE%91%E5%88%86%E6%9E%90%E4%BB%AA%E6%88%96%E7%A4%BA%E6%B3%A2%E5%99%A8%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%BA%9B%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E6%9D%A5%E6%A3%80%E6%9F%A5%E6%80%BB%E7%BA%BF%E4%B8%8A%E5%8F%91%E7%94%9F%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%AE%83%E8%BF%98%E5%BA%94%E8%AF%A5%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E9%AA%8C%E8%AF%81%E6%AF%8F%E4%B8%AA%20I2C%20%E6%93%8D%E4%BD%9C%E7%9A%84%E7%A1%AE%E8%AE%A4%E3%80%82%E5%A6%82%E6%9E%9C%E5%91%BD%E4%BB%A4%E6%9C%AA%E8%A2%AB%E7%A1%AE%E8%AE%A4%EF%BC%8C%E5%90%8E%E7%BB%AD%E6%93%8D%E4%BD%9C%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9F%A5%E7%9C%8B%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%20I2C%20%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%E5%8F%AA%E9%9C%80%E9%AA%8C%E8%AF%81%20I2C%20%E5%BA%93%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E8%BF%99%E4%B8%AA%207%20%E4%BD%8D%E5%9C%B0%E5%9D%80%EF%BC%880x51%EF%BC%89%E5%B9%B6%E8%87%AA%E5%8A%A8%E5%A4%84%E7%90%86%E8%AF%BB%2F%E5%86%99%E4%BD%8D%E3%80%82%3C%2FP%3E%0A%3CP%3EBRs%2C%20Tomas%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
