PCF8523TK reference circuit connection
1,234 次查看
zesun
I am testing RTC PCF8523TK. This is the first time for me to deal with RTC. Could anyone provide a reference circuit for this module? Basically, I am not sure how to deal with the INT1/CLKOUT pin.
Thanks in advance.
1 回复
1,171 次查看
guoweisun
For your question, you could download file UM10760 for the reference design and you also could get the INT1/CLOCL pin application solution.
You could get this file from this link.
http://www.nxp.com/products/signal-chain/real-time-clocks/ic-real-time-clocks-rtc/ic-bus-rtc-pcf8523...
