PCF2129, Vth(sw)bat range
1,699 次查看
wtedjo
What's the Vth(sw)bat range for PCF2129?
The datasheet (table 79) mentions the typical of 2.5V, and ranges only for Vth(sw)bat. Is it save to assume they use the same voltage reference, therefore, the same min and max?
Thank you.
1,683 次查看
wtedjo
Yes, I understand, and I can read the datasheet with no issue.
However, I was asking if there's more information that's not listed in the datasheet. It would be great if I can get in contact with one of the engineer/team who characterized the IC. Thank you.
1,682 次查看
guoweisun
Unfortunately NO additional information for this parameter.
1,687 次查看
guoweisun
It has only typical value for reference here:
