PCA9615
PCA9615
1,341件の閲覧回数
abinmajeed
We are planning to use PCA9615 IC in the design and need to know what is maximum cable length possible at 100Khz speed as no graph is embedded in the datasheet for the same
Abin
タグ(1)
1,261件の閲覧回数
guoweisun
Unfortunately,  we do not have any characterization about the length supported on different frequency.
So if you increase the length with lower frequency based on your actual application,you must validate the performance about that.
