PCA9540BDP/Q900J Temperature range
835件の閲覧回数
DP2003
What is the operating temperature range for this part.?  Datasheet suggest +105C for PCA9540BDP/Q900 but does not give any specific parameters for 105C operation.
821件の閲覧回数
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
In this case the operating temperature of the device goes from -40 to +85 degrees.
If such temperature range is exceeded, its behavior is not guaranteed. The device may be permanently damaged if exposed to temperatures over 105 degrees.
I hope this information helps.
David
