PCA9507
PCA9507
936件の閲覧回数
efrati10
The range I aim for is up to 2 meters with one PCA9507. I have a few questions regarding the setup and would appreciate any guidance:
  1. Where should I place the PCA9507 in this setup? Should it be closer to the slave (ADT7422) or the master device?
  2. Where should the pull-up resistors be placed in this configuration?
  3. What should be the value of these pull-up resistors?
923件の閲覧回数
TomasVaverka
Hello Asher,
The PCA9507 is a pretty old (~15 years) 2-wire serial bus extender with limited support from our application team. I would recommend you to take a closer look at chapter 7 of the datasheet, which provides useful design-in information.
BR, Tomas
