PCA6416A
5,278件の閲覧回数
VidhyaJ
HI Team,
Can PCA6416A  IO pins be driven before VCC is applied?
Kindly confirm.
Vidhya
5,029件の閲覧回数
TomasVaverka
Hi Vidhya,
The support ticket (case) can be created here:
https://support.nxp.com/s/?language=en_US
BRs, Tomas
15 返答(返信)
5,255件の閲覧回数
michs23
No, the IO pins of the PCA6416A should not be driven before applying VCC. Driving them without power can damage the device and lead to unpredictable AZ DMV behavior. Always apply VCC first, allow for stabilization, and then drive the I/O pins. Refer to the datasheet for specific guidelines and operating ranges.
5,259件の閲覧回数
TomasVaverka
Hi Vidhya,
The I/O pins should not be driven before VDD(P) is applied as this could lead to unintended behavior or damage. All I/Os are initialized as inputs at power-on and are only functional after VDD(P) reaches its operating level​.
BRs, Tomas
5,230件の閲覧回数
VidhyaJ
HI Team,
Refer to the link below,
https://www.nxp.com/docs/en/application-note/AN469.pdf
page no: 37, question No:5 specifies it is ok to drive IO pins before VCC is applied.
Kindly clarify.
Vidhya
5,218件の閲覧回数
TomasVaverka
Hi Vidhya,
The statement in the AN469 regarding PCA9501 IO pins being driven before VCC is specific to that device. The PCA6416A's internal structure differ from the PCA9501 and we do not really recommend applying voltage to I/O pins before VDD(P).
BRs, Tomas
5,205件の閲覧回数
VidhyaJ
HI Tomas,
can you suggest an I2C based 16bit NXP IO expander part which supports IO pins available before VDD?
Vidhya
5,193件の閲覧回数
VidhyaJ
Hi Tomas,
Does PCA9539 allows IO pins driven before VCC is applied?
Kindly confirm.
Vidhya
5,161件の閲覧回数
TomasVaverka
Hi Vidhya,
Yes, it does.
BRs, Tomas
5,122件の閲覧回数
VidhyaJ
Hi Tomas,
ok. PCA9539RBS,118 meets my requirement of IO pins driven before VCC is applied.
1. But there is a response from NXP that this part will be WIT??
Kindly confirm if this part can be used? or is there any other series for my requirement?
2. I need the following details of the selected part
  1. Confirmation on whether this part is currently ACTIVE
  2. REACH
  3. ROHS
  4. FIT (Failure In Time)
  5. MSL
  6. ECCN
  7. FINISH
  8. EOL
  9. Part Availability for 10 years
Kindly revert.
Thanks and Regards,
Vidhya
5,118件の閲覧回数
TomasVaverka
Hi Vidhya,
Regarding the longevity and details in the second question, please create a standard support ticket for my colleagues dealing with such non-technical questions.
BRs, Tomas
5,054件の閲覧回数
VidhyaJ
Hi Tomas,
what is your feedback on 1st point?
Can you share link to raise support ticket?
Thanks and Regards,
Vidhya
5,030件の閲覧回数
TomasVaverka
Hi Vidhya,
BRs, Tomas
5,021件の閲覧回数
VidhyaJ
Thanks Tomas.
I hope I can use PCA9539RPW,118 which meets IO pins driven before VCC is applied.
Vidhya
5,055件の閲覧回数
VidhyaJ
Hi Thomas,
Any feedback on the 1st point?
Vidhya
5,166件の閲覧回数
michs23
No, the IO pins of the PCA6416A should not be driven before applying VCC. Driving them without power can damage the device and lead to unpredictable behavior. Always apply VCC first, allow for stabilization, and then drive the I/O pins. Refer to the datasheet for specific guidelines and operating ranges.
5,052件の閲覧回数
VidhyaJ
Hi Michs,
Can you confirm the same?
Thanks and Regards,
Vidhya
%3CLINGO-SUB%20id%3D%22lingo-sub-2025713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPCA6416A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2025713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%E3%83%81%E3%83%BC%E3%83%A0%3C%2FP%3E%3CP%3EVCC%E5%8D%B0%E5%8A%A0%E5%89%8D%E3%81%ABP%E3%83%94%E3%83%B3%3CSPAN%3ECA6416A%3C%2FSPAN%3E%20IO%E3%83%94%E3%83%B3%E3%82%92%E9%A7%86%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%B4%E3%82%A3%E3%83%87%E3%82%A3%E3%83%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E
