MRFE6VS25NR1 Discoloration/Incomplete Plating
rlim
Hi, just want to confirm if the discoloration/incomplete plating on the leads of MRFE6VS25NR1 is normal and acceptable in manufacturing process (please see attached photo). Will it not cause any issue once mounted on board? Thank you in advance!
RafaR
Hello rlim
Good day!
That product still has the Freescale logo, so I can see that it's a bit old. Although there shouldn't be a noticeable electrical effect on the device, if it's important for its lifespan, I recommend you talk to your distributor to request a replacement part.
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
rlim
Hi RafaR,
Good day! Thank you for your reply.
You're correct, the parts received are very old (DC1349). I asked for replacement with newer DC (2448), however, some parts still exhibit discoloration/incomplete plating. See attached photo for reference.
Having the same scenario with a newer DC, and the affected area is localized, could this be considered as normal or part of the assembly process?
RafaR
Hello rlim
Good day!
No, it is not normal, you have to talk to your official distributor to request the warranty until the parts do not present those imperfections.
%3CLINGO-SUB%20id%3D%22lingo-sub-2187052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMRFE6VS25NR1%20Discoloration%2FIncomplete%20Plating%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20just%20want%20to%20confirm%20if%20the%20discoloration%2Fincomplete%20plating%20on%20the%20leads%20of%26nbsp%3BMRFE6VS25NR1%20is%20normal%20and%20acceptable%20in%20manufacturing%20process%20(please%20see%20attached%20photo).%20Will%20it%20not%20cause%20any%20issue%20once%20mounted%20on%20board%3F%20Thank%20you%20in%20advance!%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2191672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MRFE6VS25NR1%20Discoloration%2FIncomplete%20Plating%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2191672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20rlim%3C%2FP%3E%0A%3CP%3EGood%20day!%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%3ENo%2C%20it%20is%20not%20normal%2C%20you%20have%20to%20talk%20to%20your%20official%20distributor%20to%20request%20the%20warranty%20until%20the%20parts%20do%20not%20present%20those%20imperfections.%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20information%20has%20helped%20you%2C%20please%20let%20me%20know%20if%20you%20need%20help%20with%20anything%20else.%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MRFE6VS25NR1%20Discoloration%2FIncomplete%20Plating%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20RafaR%2C%3C%2FP%3E%3CP%3EGood%20day!%20Thank%20you%20for%20your%20reply.%26nbsp%3B%3C%2FP%3E%3CP%3EYou're%20correct%2C%20the%20parts%20received%20are%20very%20old%20(DC1349).%20I%20asked%20for%20replacement%20with%20newer%20DC%20(2448)%2C%20however%2C%20some%20parts%20still%20exhibit%20discoloration%2Fincomplete%20plating.%20See%20attached%20photo%20for%20reference.%3C%2FP%3E%3CP%3EHaving%20the%20same%20scenario%20with%20a%20newer%20DC%2C%20and%20the%20affected%20area%20is%20localized%2C%20could%20this%20be%20considered%20as%20normal%20or%20part%20of%20the%20assembly%20process%3F%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2187776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MRFE6VS25NR1%20Discoloration%2FIncomplete%20Plating%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2187776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20rlim%3C%2FP%3E%0A%3CP%3EGood%20day!%3C%2FP%3E%0A%3CP%3EThat%20product%20still%20has%20the%20Freescale%20logo%2C%20so%20I%20can%20see%20that%20it's%20a%20bit%20old.%20Although%20there%20shouldn't%20be%20a%20noticeable%20electrical%20effect%20on%20the%20device%2C%20if%20it's%20important%20for%20its%20lifespan%2C%20I%20recommend%20you%20talk%20to%20your%20distributor%20to%20request%20a%20replacement%20part.%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20information%20has%20helped%20you%2C%20please%20let%20me%20know%20if%20you%20need%20help%20with%20anything%20else.%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E
