MRF13750H Input Matching Design Simulation
Luis_V
Hello!
I am trying to simulate the input matching network of the MRF13750H-915MHz reference circuit board using Usimmics (I don't have ADS neither AWR)
I am using the same width and length traces as those in NXP datasheet, but the results do not correspond to 915MHz. Does anyone know what I am doing wrong?
Best,
Luis Villanueva
  • RF
RafaR
Hello Luis_V
Good day!
Unfortunately, I haven't used the simulator you're using, so I can't make a complete comparison, but from what I can see, I can tell you the following:
In ADS/AWR, the original layout includes:
  • tee discontinuities,
  • mitered bends,
  • open-end effects,
  • coupling effects.
Your schematic uses ideal MLIN sections connected directly.
Furthermore, I understand that the AWR simulation "takes into account" the parasitic effects that may be present in the package.
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
Luis_V
Thank you for the information!
%3CLINGO-SUB%20id%3D%22lingo-sub-2399253%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMRF13750H%20Input%20Matching%20Design%20Simulation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399253%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello!%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20simulate%20the%20input%20matching%20network%20of%20the%20MRF13750H-915MHz%20reference%20circuit%20board%20using%20Usimmics%20(I%20don't%20have%20ADS%20neither%20AWR)%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20using%20the%20same%20width%20and%20length%20traces%20as%20those%20in%20NXP%20datasheet%2C%20but%20the%20results%20do%20not%20correspond%20to%20915MHz.%20Does%20anyone%20know%20what%20I%20am%20doing%20wrong%3F%3C%2FP%3E%3CP%3EBest%2C%3C%2FP%3E%3CP%3ELuis%20Villanueva%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2399253%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ERF%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MRF13750H%20Input%20Matching%20Design%20Simulation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399298%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20the%20information!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MRF13750H%20Input%20Matching%20Design%20Simulation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Luis_V%3C%2FP%3E%0A%3CP%3EGood%20day!%3C%2FP%3E%0A%3CP%3EUnfortunately%2C%20I%20haven't%20used%20the%20simulator%20you're%20using%2C%20so%20I%20can't%20make%20a%20complete%20comparison%2C%20but%20from%20what%20I%20can%20see%2C%20I%20can%20tell%20you%20the%20following%3A%3C%2FP%3E%0A%3CP%3EIn%20ADS%2FAWR%2C%20the%20original%20layout%20includes%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3Etee%20discontinuities%2C%3C%2FLI%3E%0A%3CLI%3Emitered%20bends%2C%3C%2FLI%3E%0A%3CLI%3Eopen-end%20effects%2C%3C%2FLI%3E%0A%3CLI%3Ecoupling%20effects.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EYour%20schematic%20uses%20ideal%20MLIN%20sections%20connected%20directly.%3C%2FP%3E%0A%3CP%3EFurthermore%2C%20I%20understand%20that%20the%20AWR%20simulation%20%22takes%20into%20account%22%20the%20parasitic%20effects%20that%20may%20be%20present%20in%20the%20package.%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20information%20has%20helped%20you%2C%20please%20let%20me%20know%20if%20you%20need%20help%20with%20anything%20else.%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E
