MQX io driver doubt
MQX io driver doubt
1,443 次查看
Jishnump
What is the diffrence between MQX io driver APIs lwgpio_get_value() and lwgpio_get_raw(). Please reply
1,397 次查看
danielchen
Hi @Jishnump :
lwgpio_get_value: this function gets the output buffer value rather than sampling pin voltage level of a pin.
lwgpio_get_raw: this funtion samples the pin to get the voltage value.
1,393 次查看
Purcell854
I have exactly the same problem. Anyone got a suggestion? This is quiet a common issue  Costco.com
