MP4 to RAW10 Frame Conversion
1,332件の閲覧回数
Mutreja_12
I want to convert an MP4 file into a Raw10 format file for testing purposes on a microprocessor. To transmit the Raw10 frames, I plan to use an FPGA equipped with MIPI CSI-2 TX.
However, I am currently stuck in the MP4 to Raw10 conversion process. Is there any way to achieve this?
2 返答(返信)
1,319件の閲覧回数
Bio_TICFSL
You can so it with the VPU of MX6, but generally this is done by an app.
1,308件の閲覧回数
Mutreja_12
Thanks for your response.
Can you tell me which app and also please tell me do i have to do something(some coding or script) for that conversion if i uses VPU of MX6 or it will be done by the MX6 only.
