MMPF0100F6ANES
MMPF0100F6ANES
995 次查看
RamakrishnaC
Hi Team,
What is the use of MMPF0100F6ANES I2C bus connection with i.Mx.
For your information We are not planning to programming the PMIC anymore.. We are just connecting the SCL & SDA signals to i.Mx. So please share the what are uses for this connection.
Thanks & Regards
2 回复数
969 次查看
Bio_TICFSL
If you have no plan to use MPF0100 then you are  not in EVK board since all the documentation and BSP works on EVK. So if you want to use i2C, it simple works a normal.
948 次查看
RamakrishnaC
Hi Team,
Otherthan programming what is the use of I2C communication with i.Mx.
please share those details.
Thnak you
