MIMXRT1176 LPSPI
MIMXRT1176 LPSPI
1,493 次查看
Ravi07011983
We have MIMXRT1170-EVk Evaluation board.We configured LPSPI1 sdk polling master transfer b2b cm7 core using external Jtag debugger but we are unable to the sck on evalution board.
same code is working with usb on board debugger and able to see the sck.
Request to provide the solution for lpspi sdk code for external jtag debugger.We are using mcxpresso IDE and debugger PE micro.
5 回复数
1,326 次查看
Ravi07011983
   We installed IDE: MCUXpresso IDE 25.06, But SDK:   25.12 is 2.16 version.Please confirm.
   Our Evaluation board is MIMXRT1170-EVK.
  MCUXPRESSO IDE SWD is available but How to select JTAG option .Please suggest.
We are interested to code debug through external JTAG using PE micro ,we do not connect the USB debugger.
In MIMXRT1170-EVK board J5,J6,J7 and J8 Jumpers is mentioned in evaluation schematics page no. 26. We removed all jumpers for external jtag our led blinky example code is working.If J5 is connect means it is connected to free link IC U24A.
can you send any lpspi tested full working code in MIMXRT1170-EVK using external JTAG debugger with out connect to USB debugger (J11).
 Request to provide the solution.
1,463 次查看
mayliu1
Hi @Ravi07011983 ,
Thank you so much for your interest in our products and for using our community.
I did a test on my side using the PE debugger with the SDK demo "evkbmimxrt1170_lpspi_polling_b2b_transfer_master_cm7", and I have test that it can run successfully. Please note that no code modifications were made.
  • IDE: MCUXpresso IDE 25.06
  • SDK:   25.12
  • Debugger: PE
I recommend that you first check the versions of your IDE and SDK to ensure they match .
Additionally, please use the default SDK debug interface(SWD). If you intend to use the JTAG interface, please be note that hardware modifications to the development board are required.
In MIMXRT1170EVKHUG, it describe below:
Wish it helps you
Best Regards
MayLiu
1,446 次查看
Ravi07011983
Thank you for your response,We will check the IDE: MCUXpresso IDE ,SDK: Version.
We are using MIMXRT1170-EVK eval board for our code development.We used default SDK debug interface(SWD)As per EVK Board Hardware User’s Guide we removed the resistors R187, R208, R195, and R78.
We are using external JTAG debugger make PE Micro for that purpose in MIMXRT1170-EVK board J5,J6,J7 and J8 Jumpers also removed to isolate the usb debugger frre link.
External JTAG debugger is working with demo led blink example code but LPSPI and UART interfaces are not working.
We tried LPSPI1 sdk example code using pins GPIO_AD_28,GPIO_AD_29,GPIO_AD_30 & GPIO_AD_31 board slave IC U27.
1,363 次查看
mayliu1
Hi @Ravi07011983 ,
1: Please check whether your board is MIMXRT1170-EVK or MIMXRT1170-EVKB board.
Regarding your note: "We used default SDK debug interface(SWD)As per EVK Board Hardware User’s Guide we removed the resistors R187, R208, R195, and R78."
If you are using SWD interface, you do  not need  to modify this hardware.
2: You mentioned: "We are using external JTAG debugger make PE Micro for that purpose in MIMXRT1170-EVK board J5,J6,J7 and J8 Jumpers also removed to isolate the usb debugger frre link.",
I believe you meant JP5, JP6, JP7, correct?
If so, please note that JP5 need  remain connected.
3: I did a test on my side, and I can debug and print successfully using PE Micro.
4: Regarding "We tried LPSPI1 sdk example code using pins GPIO_AD_28,GPIO_AD_29,GPIO_AD_30 & GPIO_AD_31 board slave IC U27.
Request to provide the solution."
Unfortunately, we do not provide an SDK example for this.
Wish it helps you
Best Regards
MayLiu
1,352 次查看
Ravi07011983
%3CLINGO-SUB%20id%3D%22lingo-sub-2339453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMXRT1176%20LPSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%9C%89%20mimxrt1170-EVK%20%E8%AF%84%E4%BC%B0%E6%9D%BF%E3%80%82%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%20Jtag%20%E8%B0%83%E8%AF%95%E5%99%A8%E9%85%8D%E7%BD%AE%E4%BA%86%20LPSPI1%20sdk%20%E8%BD%AE%E8%AF%A2%E4%B8%BB%E4%BC%A0%E8%BE%93%20b2b%20cm7%20%E5%86%85%E6%A0%B8%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E5%9C%A8%E8%AF%84%E4%BC%B0%E6%9D%BF%E4%B8%8A%E6%89%A7%E8%A1%8C%20sck%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%8C%E6%A0%B7%E7%9A%84%E4%BB%A3%E7%A0%81%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%9D%BF%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%8A%E4%BD%BF%E7%94%A8%20USB%20%E5%B9%B6%E4%B8%94%E8%83%BD%E5%A4%9F%E7%9C%8B%E5%88%B0%20sck%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20mcxpresso%20IDE%20%E5%92%8C%E8%B0%83%E8%AF%95%E5%99%A8%20PE%20micro%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20LPSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254817%22%20target%3D%22_blank%22%3E%40Ravi07011983%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E5%85%B3%E6%B3%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E5%B9%B6%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E7%A4%BE%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20PE%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%92%8C%20SDK%20%E6%BC%94%E7%A4%BA%22evkbmimxrt1170_lpspi_polling_b2b_transfer_master_cm7%22%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E8%A1%A8%E6%98%8E%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%BB%A3%E7%A0%81%E6%9C%AA%E4%BD%9C%E4%BB%BB%E4%BD%95%E4%BF%AE%E6%94%B9%E3%80%82%20%20%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EIDE%EF%BC%9AMCUXpresso%20IDE%2025.06%3C%2FLI%3E%0A%3CLI%3ESDK%EF%BC%9A%20%20%2025.12%3C%2FLI%3E%0A%3CLI%3E%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9APE%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380467i0ADD8246AC768119%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.png%22%20alt%3D%223.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E9%A6%96%E5%85%88%E6%A3%80%E6%9F%A5%20IDE%20%E5%92%8C%20SDK%20%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%8C%E7%A1%AE%E4%BF%9D%E5%AE%83%E4%BB%AC%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20SDK%20%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%20(SWD)%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%89%93%E7%AE%97%E4%BD%BF%E7%94%A8%20JTAG%20%E6%8E%A5%E5%8F%A3%EF%BC%8C%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E9%9C%80%E8%A6%81%E5%AF%B9%E5%BC%80%E5%8F%91%E6%9D%BF%E8%BF%9B%E8%A1%8C%E7%A1%AC%E4%BB%B6%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%20MIMXRT1170EVKHUG%20%E4%B8%AD%EF%BC%8C%E6%8F%8F%E8%BF%B0%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380466i3FBCB58A4C628610%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%224.png%22%20alt%3D%224.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EMayLiu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20LPSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E6%A3%80%E6%9F%A5%20IDE%EF%BC%9AMCUXpresso%20IDE%20%2CSDK%EF%BC%9A%E7%89%88%E6%9C%AC%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20MIMXRT1170-EVK%20%E8%AF%84%E4%BC%B0%E6%9D%BF%E8%BF%9B%E8%A1%8C%E4%BB%A3%E7%A0%81%E5%BC%80%E5%8F%91%E3%80%82%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%20SDK%20%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%20(SWD)%20%E6%A0%B9%E6%8D%AE%20EVK%20%E6%9D%BF%E7%A1%AC%E4%BB%B6%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%8C%E6%88%91%E4%BB%AC%E7%A7%BB%E9%99%A4%E4%BA%86%E7%94%B5%E9%98%BB%20R187%E3%80%81R208%E3%80%81R195%20%E5%92%8C%20R78%E3%80%82%3CBR%20%2F%3E%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%88%B6%E9%80%A0%20PE%20Micro%EF%BC%8C%E7%94%A8%E4%BA%8E%20MIMXRT1170-EVK%20%E6%9D%BF%20J5%E3%80%81J6%E3%80%81J7%20%E5%92%8C%20J8%20Jumpers%EF%BC%8C%E4%B8%BA%E4%BA%86%E9%9A%94%E7%A6%BB%20USB%20%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%E5%85%8D%E8%B4%B9%E9%93%BE%E6%8E%A5%EF%BC%8C%E8%BF%98%E7%A7%BB%E9%99%A4%E4%BA%86%E8%B7%B3%E7%BA%BF%E3%80%82%3CBR%20%2F%3E%E5%A4%96%E9%83%A8%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%BC%94%E7%A4%BA%E7%9A%84%20LED%20%E9%97%AA%E7%83%81%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%20LPSPI%20%E5%92%8C%20UART%20%E6%8E%A5%E5%8F%A3%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E5%BC%95%E8%84%9A%20GPIO_AD_28%E3%80%81GPIO_AD_29%E3%80%81GPIO_AD_30%20%26amp%3B%20GPIO_AD_31%20%E6%9D%BF%E4%BB%8E%20IC%20U27%20%E5%B0%9D%E8%AF%95%E4%BA%86%20LPSPI1%20sdk%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E6%B1%82%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2341909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20LPSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2341909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254817%22%20target%3D%22_blank%22%3E%40Ravi07011983%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%9C%80%E6%96%B0%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E1%EF%BC%9A%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%E6%9D%BF%E6%98%AF%20MIMXRT1170-EVK%20%E8%BF%98%E6%98%AF%20MIMXRT1170-EVKB%20%E6%9D%BF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%E4%BD%A0%E7%9A%84%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A1%B9%EF%BC%9A%22%20%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E4%BA%86%E9%BB%98%E8%AE%A4%20SDK%20%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%20(SWD)%20%E6%A0%B9%E6%8D%AE%20EVK%20%E6%9D%BF%E7%A1%AC%E4%BB%B6%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%8C%E6%88%91%E4%BB%AC%E7%A7%BB%E9%99%A4%E4%BA%86%E7%94%B5%E9%98%BB%E5%99%A8%20R187%E3%80%81R208%E3%80%81R195%20%E5%92%8C%20R78%E3%80%82%22%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20SWD%20%E6%8E%A5%E5%8F%A3%EF%BC%8C%E5%88%99%E6%97%A0%E9%9C%80%E4%BF%AE%E6%94%B9%E6%AD%A4%E7%A1%AC%E4%BB%B6%E3%80%82%20%3C%2FP%3E%0A%3CP%3E2%EF%BC%9A%E4%BD%A0%E6%8F%90%E5%88%B0%EF%BC%9A%22%20%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%88%B6%E4%BD%9C%E7%9A%84%20PE%20Micro%20%E6%9D%A5%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%AA%E7%9B%AE%E7%9A%84%EF%BC%8C%E5%9C%A8%20MIMXRT1170-EVK%20%E4%B8%BB%E6%9D%BF%20%3CFONT%20color%3D%22%23FF0000%22%3EJ5%E3%80%81J6%E3%80%81J7%20%E5%92%8C%20J8%20%E4%B8%AD%EF%BC%8C%E4%B8%BA%E4%BA%86%E9%9A%94%E7%A6%BB%20USB%20%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%E5%85%8D%E8%B4%B9%E9%93%BE%E6%8E%A5%EF%BC%8CJ%3C%2FFONT%3E%20umpers%20%E4%B9%9F%E8%A2%AB%E7%A7%BB%E9%99%A4%E4%BA%86%E3%80%82%22%2C%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%E6%88%91%E6%83%B3%E6%82%A8%E6%8C%87%E7%9A%84%E6%98%AF%3CSTRONG%3EJP5%E3%80%81JP6%20%E5%92%8C%20JP7%3C%2FSTRONG%3E%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E8%AF%B7%E6%B3%A8%E6%84%8F%3CSTRONG%3EJP5%20%E9%9C%80%E8%A6%81%E4%BF%9D%E6%8C%81%E8%BF%9E%E6%8E%A5%3C%2FSTRONG%3E%E3%80%82%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20id%3D%22tinyMceEditormayliu1_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E3%3A%20%E6%88%91%E8%BF%99%E8%BE%B9%E5%81%9A%E4%BA%86%E4%B8%80%E4%B8%AA%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BD%BF%E7%94%A8%20PE%20Micro%20%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E8%B0%83%E8%AF%95%E5%92%8C%E6%89%93%E5%8D%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380763i741F6C59FB029459%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E4%EF%BC%9A%E5%85%B3%E4%BA%8E%20%22%20%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E5%BC%95%E8%84%9A%20GPIO_AD_28%E3%80%81GPIO_AD_29%E3%80%81GPIO_AD_30%20%26amp%3B%20GPIO_AD_30%20GPIO_AD_31%20%E4%B8%BB%E6%9D%BF%E4%BB%8E%E5%B1%9E%20IC%20U27%20%E5%B0%9D%E8%AF%95%E4%BA%86%20LPSPI1%20sdk%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E6%B1%82%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%22%3C%2FP%3E%0A%3CDIV%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E4%B8%BA%E6%AD%A4%E6%8F%90%E4%BE%9B%20SDK%20%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%20%3C%2FDIV%3E%0A%3CDIV%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3EMayLiu%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2342291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20LPSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2342291%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%20%20%20%E6%88%91%E4%BB%AC%E5%AE%89%E8%A3%85%E4%BA%86%20IDE%EF%BC%9AMCUXpresso%20IDE%2025.06%E3%80%81%E4%BD%86%3CSTRONG%3ESDK%EF%BC%9A%20%20%2025.12%20%E6%98%AF%202.16%20%E7%89%88%E6%9C%AC%EF%BC%8C%E8%AF%B7%E7%A1%AE%E8%AE%A4%E3%80%82%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E8%AF%84%E4%BC%B0%E6%9D%BF%E6%98%AF%20MIMXRT1170-EVK%E3%80%82%3C%2FP%3E%3CP%3E%20%20MCUXPRESSO%20IDE%20SWD%20%E5%8F%AF%E7%94%A8%EF%BC%8C%E4%BD%86%E5%A6%82%E4%BD%95%E9%80%89%E6%8B%A9%3CSTRONG%3EJTAG%20%E9%80%89%E9%A1%B9%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E4%BD%BF%E7%94%A8%20PE%20micro%20%E9%80%9A%E8%BF%87%E5%A4%96%E9%83%A8%20JTAG%20%E8%BF%9B%E8%A1%8C%E4%BB%A3%E7%A0%81%E8%B0%83%E8%AF%95%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%20USB%20%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20MIMXRT1170-EVK%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%AD%3CFONT%20color%3D%22%23FF0000%22%3E%EF%BC%8C%E8%AF%84%E4%BC%B0%E5%8E%9F%E7%90%86%E5%9B%BE%E7%AC%AC%2026%20%E9%A1%B5%E4%B8%AD%E6%8F%90%E5%88%B0%E4%BA%86%E8%B7%B3%E7%BA%BF%20J5%E3%80%81J6%E3%80%81J7%20%E5%92%8C%20J8%3C%2FFONT%3E%E3%80%82%E6%88%91%E4%BB%AC%E7%A7%BB%E9%99%A4%E4%BA%86%E6%89%80%E6%9C%89%E7%94%A8%E4%BA%8E%E5%A4%96%E9%83%A8%20jtag%20%E7%9A%84%E8%B7%B3%E7%BA%BF%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%20LED%20%E9%97%AA%E7%83%81%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E5%A6%82%E6%9E%9C%20J5%20%E8%BF%9E%E6%8E%A5%EF%BC%8C%E5%88%99%E8%A1%A8%E7%A4%BA%E5%AE%83%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%87%AA%E7%94%B1%E9%93%BE%E6%8E%A5%20IC%20U24A%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%8F%91%E9%80%81%3CSTRONG%3E%E5%9C%A8%20MIMXRT1170-EVK%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%88%E4%B8%8D%E8%BF%9E%E6%8E%A5%20USB%20%E8%B0%83%E8%AF%95%E5%99%A8%20(J11)%EF%BC%89%E6%B5%8B%E8%AF%95%E7%9A%84%20lpspi%20%E5%AE%8C%E6%95%B4%E5%B7%A5%E4%BD%9C%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%A6%81%E6%B1%82%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2343164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1176%20LPSPI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2343164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%20%20%20%E6%88%91%E4%BB%AC%E5%AE%89%E8%A3%85%E4%BA%86%20IDE%EF%BC%9AMCUXpresso%20IDE%2025.06%E3%80%81%E4%BD%86%3CSTRONG%3ESDK%EF%BC%9A%20%20%2025.12%20%E6%98%AF%202.16%20%E7%89%88%E6%9C%AC%EF%BC%8C%E8%AF%B7%E7%A1%AE%E8%AE%A4%E3%80%82%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E8%AF%84%E4%BC%B0%E6%9D%BF%E6%98%AF%20MIMXRT1170-EVK%E3%80%82%3C%2FP%3E%3CP%3E%20%20MCUXPRESSO%20IDE%20SWD%20%E5%8F%AF%E7%94%A8%EF%BC%8C%E4%BD%86%E5%A6%82%E4%BD%95%E9%80%89%E6%8B%A9%3CSTRONG%3EJTAG%20%E9%80%89%E9%A1%B9%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E4%BD%BF%E7%94%A8%20PE%20micro%20%E9%80%9A%E8%BF%87%E5%A4%96%E9%83%A8%20JTAG%20%E8%BF%9B%E8%A1%8C%E4%BB%A3%E7%A0%81%E8%B0%83%E8%AF%95%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%20USB%20%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20MIMXRT1170-EVK%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%AD%3CFONT%20color%3D%22%23FF0000%22%3E%EF%BC%8C%E8%AF%84%E4%BC%B0%E5%8E%9F%E7%90%86%E5%9B%BE%E7%AC%AC%2026%20%E9%A1%B5%E4%B8%AD%E6%8F%90%E5%88%B0%E4%BA%86%E8%B7%B3%E7%BA%BF%20J5%E3%80%81J6%E3%80%81J7%20%E5%92%8C%20J8%3C%2FFONT%3E%E3%80%82%E6%88%91%E4%BB%AC%E7%A7%BB%E9%99%A4%E4%BA%86%E6%89%80%E6%9C%89%E7%94%A8%E4%BA%8E%E5%A4%96%E9%83%A8%20jtag%20%E7%9A%84%E8%B7%B3%E7%BA%BF%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%20LED%20%E9%97%AA%E7%83%81%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E5%A6%82%E6%9E%9C%20J5%20%E8%BF%9E%E6%8E%A5%EF%BC%8C%E5%88%99%E8%A1%A8%E7%A4%BA%E5%AE%83%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%87%AA%E7%94%B1%E9%93%BE%E6%8E%A5%20IC%20U24A%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%8F%91%E9%80%81%3CSTRONG%3E%E5%9C%A8%20MIMXRT1170-EVK%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%88%E4%B8%8D%E8%BF%9E%E6%8E%A5%20USB%20%E8%B0%83%E8%AF%95%E5%99%A8%20(J11)%EF%BC%89%E6%B5%8B%E8%AF%95%E7%9A%84%20lpspi%20%E5%AE%8C%E6%95%B4%E5%B7%A5%E4%BD%9C%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%A6%81%E6%B1%82%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
