MCUXpresso Software cannot recompile bin file with same hash
817 次查看
BetoGreen
Cant seem to ask question on MCUXpresso Software and Tools / MCUXpresso General as no option so I'm posting here. I have an NXP LPC project that I zipped up including bin files and I am trying 1 year later to recompile the project and I don't seem to get the same bin files. Is there a date or something the compiler changed that is different or maybe some references for error handing? Is there a way I can set up my configuration so that I can at any time later compile the same project and generate the same bin file with the same hash?
793 次查看
ZhangJennie
Hello BetoGreen,
Normally if the build enviroments are the same, the generated bin file should be same as well.
Could you please check if the MCUXpresso version and SDK version changed?
Best Regards
Jun Zhang
