Linux-driver for TJA1145
kschauties
Is there a Linux driver for the TJA1145? Comparable to the tja110x (c and h file)
Or can I use the nxp-tja11xx for the TJA1145 even if its PHY_ID is not listed?
I need a Treiber for the TJA1145 on the 4.1 kernel.  Thanks for your help.
TomasVaverka
Hello Karsten,
What MCU are you using? There might be such a driver available as part of the Linux BSP.
Otherwise the following drivers are available for the TJA1145A:
BRs, Tomas
