Linker Script
Linker Script
1,182 次查看
w_
I am working  on startup code of microcontroller 32 bit and codewarrior compiler , As we have to deal with linker script. Certain variables that used in startup code for initlization of RAM and stack come from linker script. Linker Script initialize these  variables with different address. Problem is one variable have wrong address. In linker script it initialzed by following command  _f_data_rom.
Could any one elaborate this command _f_data_rom ? if there is any document it will be good
标记 (2)
0 回复数
