Latest SDK,IDE issues
900 次查看
Pavani2
1.We take an example Hello world from SDK example and we are unable to dump into our customized application board with iMXRT1175 uC. This is happening when we are using latest SDK and IDE versions.. MCUXpresso IDE-11.9.1-2170 and SDK Version - 2.15.100.
But when we are using IDE Version - MCUXpresso IDE-11.5.1-7266 and SDK Version - 2.11.1 and take an same example from SDK, we are able to dump code into our customized application board with iMXRT1175 uC.
What is the issue with MCUXpresso IDE-11.9.1-2170 and SDK Version - 2.15.100...?
Thank you,
Pavani
1 回复
878 次查看
Harry_Zhang
Hi @Pavani2
Did you create a new project in MCUXpresso IDE-11.9.1 and fail to compile it successfully?
Can you provide more details? like pictures.
Hang
