The debug interface is described in the AN4977 - QorIQ LS2088A Family Design Checklist, 7.22 JTAG recommendations.
So it can be flashed using JTAG using the flex-installer?
Thank you,
Deepanraj
No.
Flex-installer is capable to deploy LSDK images on a target board storage device (SD, USB, or SATA).
CodeWarrior Flash Programmer has to be used to program firmware image into an on-board Flash device:
For using CodeWarrior Flash Programmer License is required or is it free for Programming .
Thank you,
Deepan
Yes.
But evaluation version is fully functional for one month.
How do we partition emmc / program rootfs using the codewarrior or is there separate method to programm emmc. Please share us if any document is available.
Thank you,
Deepanraj.A
LSDK Documentation, "Storage layout on SD/USB/SATA for LSDK images deployment":
layout wise we are able to understand but how do we program the emmc with the Linux image and rootfs.
whether we can parition the emmc using the codewarrior or only manual command from uboot. Please let us know in detail
