LS1028A Static IP
LS1028A Static IP
1,207 次查看
Sathian
How to configure Gbe and Switch Port with Static IP in LS1028A.
1. Changes to do in BSP LSDK.
2. In runtime Linux environment.
1 回复
1,196 次查看
bpe
For RAMDISK-based rootfs types: See LSDK User Guide Section 4.3.13 for steps to unpack, modify and rebuild rootfs image and the manpage for /etc/network/interfaces  for necessary changes.
For SD/eMMC rootfs: none. All necessary changes can be done in runtime.
Familiarize yourself with manpages for ifconfig and /etc/network/interfaces.
Hope this helps,
Platon
